手册下载
H3C S12500G-AF Switch Series Cards and Transceiver Modules Compatibility Matrixes-6W101-book.pdf (161.71 KB)
H3C S12500G-AF Switch Series |
Cards and Transceiver Modules |
Compatibility Matrixes |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
The following table shows the available transceiver modules for interface modules, MPUs, subcards, and devices.
For information about the specifications of transceiver modules and cables, see H3C Transceiver Modules User Guide.
· When you install GE transceiver modules on the 10GE fiber ports of the LSXM1TGS48TE2 and LSXM1TGS48TD2 cards, configure the ports to operate in full duplex mode at 1000 Mbps.
· The 10GE fiber port installed with a GE transceiver module on the LSXM1TGS48TE2 and LSXM1TGS48TD2 cards does not support auto-negotiating to the 100 Mbps speed when it is connected to an FE transceiver module.
· The 100GE fiber ports on the LSXM1CGQ18TE2, LSXM1CGQ36TE2, LSXM1CGQ8TD2, and LSXM1CGQ18TD2 cards do not support deceleration after the ports are split into 10GE breakout interfaces.
· The 100GE fiber ports on the LSXM1YGS24CGMODTE2 card cannot be split.
Table 1 Compatibility matrix between cards and transceiver modules
Hardware |
Port |
Available transceiver modules |
Device software version and remarks |
LSWM124TG2H |
1 to 24 |
CAB-0.5M-SFP+ |
R7624P07 |
CAB-1M-SFP+ |
R7624P07 |
CAB-3M-SFP+ |
R7624P07 |
LSTM1STK |
R7624P07 |
LSTM2STK |
R7624P07 |
LSWM1STK |
R7624P07 |
LSWM2STK |
R7624P07 |
LSWM3STK |
R7624P07 |
SFP-25G-D-AOC-10M |
R7624P07 |
SFP-25G-D-AOC-20M |
R7624P07 |
SFP-25G-D-AOC-3M |
R7624P07 |
SFP-25G-D-AOC-5M |
R7624P07 |
SFP-25G-D-AOC-7M |
R7624P07 |
SFP-25G-D-CAB-1M |
R7624P07 |
SFP-25G-D-CAB-3M |
R7624P07 |
SFP-25G-D-CAB-5M |
R7624P07 |
SFP-25G-LR-SM1310 |
R7624P07 |
SFP-25G-SR-MM850 |
R7624P07 |
SFP-XG-D-AOC-10M |
R7624P07 |
SFP-XG-D-AOC-20M |
R7624P07 |
SFP-XG-D-AOC-7M |
R7624P07 |
SFP-XG-LH40-SM1270-BIDI |
R7624P07 |
SFP-XG-LH40-SM1330-BIDI |
R7624P07 |
SFP-XG-LH40-SM1550 |
R7624P07 |
SFP-XG-LH40-SM1550-D |
R7624P07 |
SFP-XG-LH80-SM1490-BIDI |
R7624P07 |
SFP-XG-LH80-SM1550 |
R7624P07 |
SFP-XG-LH80-SM1550-BIDI |
R7624P07 |
SFP-XG-LH80-SM1550-D |
R7624P07 |
SFP-XG-LX-SM1270-BIDI |
R7624P07 |
SFP-XG-LX-SM1310 |
R7624P07 |
SFP-XG-LX-SM1310-D |
R7624P07 |
SFP-XG-LX-SM1310-E |
R7624P07 |
SFP-XG-LX-SM1310-S |
R7624P07 |
SFP-XG-LX-SM1330-BIDI |
R7624P07 |
SFP-XG-SX-MM850-A |
R7624P07 |
SFP-XG-SX-MM850-D |
R7624P07 |
SFP-XG-SX-MM850-E |
R7624P07 |
SFP-XG-SX-MM850-S |
R7624P07 |
25 and 26 |
LSWM1QSTK0 |
R7624P07 |
LSWM1QSTK1 |
R7624P07 |
LSWM1QSTK2 |
R7624P07 |
QSFP-100G-CWDM4-SM1300-A |
R7624P07 |
QSFP-100G-D-AOC-10M |
R7624P07 |
QSFP-100G-D-AOC-20M |
R7624P07 |
QSFP-100G-D-AOC-7M |
R7624P07 |
QSFP-100G-D-CAB-1M |
R7624P07 |
QSFP-100G-D-CAB-3M |
R7624P07 |
QSFP-100G-D-CAB-5M |
R7624P07 |
QSFP-100G-ER4L-WDM1300 |
R7624P07 |
QSFP-100G-eSR4-MM850 |
R7624P07, a QSFP28 port cannot be split into four 25G SFP28 ports |
QSFP-100G-LR4L-WDM1300 |
R7624P07 |
QSFP-100G-LR4-WDM1300 |
R7624P07 |
QSFP-100G-LR4-WDM1300-A |
R7624P07 |
QSFP-100G-PSM4-SM1310 |
QSFP-100G-SR4-MM850 |
QSFP-100G-SR4-MM850-A |
QSFP-100G-SWDM4-MM850 |
R7624P07 |
QSFP-40G-BIDI-SR-MM850 |
R7624P07 |
QSFP-40G-BIDI-WDM850 |
R7624P07 |
QSFP-40G-CSR4-MM850 |
R7624P07, a QSFP+ port cannot be split into four 10G SFP+ ports |
QSFP-40G-D-AOC-10M |
R7624P07 |
QSFP-40G-D-AOC-20M |
R7624P07 |
QSFP-40G-D-AOC-7M |
R7624P07 |
QSFP-40G-ER4-WDM1300 |
R7624P07 |
QSFP-40G-LR4L-WDM1300 |
R7624P07 |
QSFP-40G-LR4-PSM1310 |
R7624P07 |
QSFP-40G-LR4-WDM1300 |
R7624P07 |
QSFP-40G-SR4-MM850 |
LSWM124XG2Q |
1 to 24 |
CAB-0.5M-SFP+ |
R7624P07 |
CAB-1M-SFP+ |
R7624P07 |
CAB-3M-SFP+ |
R7624P07 |
LSTM1STK |
R7624P07 |
LSTM2STK |
R7624P07 |
LSWM1STK |
R7624P07 |
LSWM2STK |
R7624P07 |
LSWM3STK |
R7624P07 |
SFP-GE-LH100-SM1550 |
R7624P07 |
SFP-GE-LH40-SM1310 |
R7624P07 |
SFP-GE-LH40-SM1310-BIDI |
R7624P07 |
SFP-GE-LH40-SM1310-D |
R7624P07 |
SFP-GE-LH40-SM1550 |
R7624P07 |
SFP-GE-LH40-SM1550-BIDI |
R7624P07 |
SFP-GE-LH70-SM1490-BIDI |
R7624P07 |
SFP-GE-LH70-SM1550-BIDI |
R7624P07 |
SFP-GE-LH80-SM1550 |
R7624P07 |
SFP-GE-LH80-SM1550-D |
R7624P07 |
SFP-GE-LX-SM1310-A |
R7624P07 |
SFP-GE-LX-SM1310-BIDI |
R7624P07 |
SFP-GE-LX-SM1310-D |
R7624P07 |
SFP-GE-LX-SM1310-S |
R7624P07 |
SFP-GE-LX-SM1490-BIDI |
R7624P07 |
SFP-GE-SX-MM850-A |
R7624P07 |
SFP-GE-SX-MM850-D |
R7624P07 |
SFP-GE-SX-MM850-S |
R7624P07 |
SFP-GE-T |
R7624P07 |
SFP-GE-T-D |
R7624P07 |
SFP-XG-D-AOC-10M |
R7624P07 |
SFP-XG-D-AOC-20M |
R7624P07 |
SFP-XG-D-AOC-7M |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
SFP-XG-LX-SM1310 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
SFP-XG-SX-MM850-A |
R7624P07 |
SFP-XG-SX-MM850-D |
R7624P07 |
SFP-XG-SX-MM850-E |
R7624P07 |
SFP-XG-SX-MM850-S |
R7624P07 |
25 and 26 |
LSWM1QSTK0 |
R7624P07 |
LSWM1QSTK1 |
R7624P07 |
LSWM1QSTK2 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
QSFP-40G-D-AOC-7M |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
LSWM124XGT2Q |
25 and 26 |
LSWM1QSTK0 |
R7624P07 |
LSWM1QSTK1 |
R7624P07 |
LSWM1QSTK2 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
QSFP-40G-D-AOC-7M |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
LSWM18QC |
1 to 8 |
LSWM1QSTK0 |
R7624P07 |
LSWM1QSTK1 |
R7624P07 |
LSWM1QSTK2 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
QSFP-40G-D-AOC-7M |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
LSXM1CGQ18TD2 |
1 and 2, 17 and 18 |
LSWM1QSTK0 |
R7595 |
LSWM1QSTK1 |
R7595 |
LSWM1QSTK2 |
R7595 |
QSFP-100G-BIDI-MM850 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595, a QSFP28 port cannot be split into four 25G SFP28 ports |
R7595 |
R7595 |
QSFP-100G-SR4-MM850-H |
E775303 |
R7595 |
R7595 |
R7595 |
R7595, a QSFP+ port cannot be split into four 10G SFP+ ports |
R7595 |
R7595 |
QSFP-40G-D-AOC-7M |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
3 to 16 |
LSWM1QSTK0 |
R7595 |
LSWM1QSTK1 |
R7595 |
LSWM1QSTK2 |
R7595 |
LSWM1QSTK3 |
R7595 |
LSWM1QSTK4 |
R7595 |
LSWM1QSTK5 |
R7595 |
QSFP-100G-4SFP-25G-CAB-1M |
R7595 |
QSFP-100G-4SFP-25G-CAB-3M |
R7595 |
QSFP-100G-4SFP-25G-CAB-5M |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
E775303 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
QSFP-40G-D-AOC-7M |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
LSXM1CGQ18TE2 |
1 to 8, 10 to 17 |
LSWM1QSTK0 |
R7595 |
LSWM1QSTK1 |
R7595 |
LSWM1QSTK2 |
R7595 |
LSWM1QSTK3 |
R7595 |
LSWM1QSTK4 |
R7595 |
LSWM1QSTK5 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
QSFP-40G-D-AOC-7M |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
9, 18 |
LSWM1QSTK0 |
R7595 |
LSWM1QSTK1 |
R7595 |
LSWM1QSTK2 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
QSFP-40G-D-AOC-7M |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
LSXM1CGQ36TE2 |
1 to 9, 11 to 16, 18 to 27, 29 to 34, 36 |
LSWM1QSTK0 |
R7595 |
LSWM1QSTK1 |
R7595 |
LSWM1QSTK2 |
R7595 |
LSWM1QSTK3 |
R7595 |
LSWM1QSTK4 |
R7595 |
LSWM1QSTK5 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
E775303 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
QSFP-40G-D-AOC-7M |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
10, 17, 28, 35 |
LSWM1QSTK0 |
R7595 |
LSWM1QSTK1 |
R7595 |
LSWM1QSTK2 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
E775303 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
QSFP-40G-D-AOC-7M |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
LSXM1CGQ8TD2 |
1 to 7 |
LSWM1QSTK0 |
R7595 |
LSWM1QSTK1 |
R7595 |
LSWM1QSTK2 |
R7595 |
LSWM1QSTK3 |
R7595 |
LSWM1QSTK4 |
R7595 |
LSWM1QSTK5 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
E775303 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
QSFP-40G-D-AOC-7M |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
8 |
LSWM1QSTK0 |
R7595 |
LSWM1QSTK1 |
R7595 |
LSWM1QSTK2 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
E775303 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
QSFP-40G-D-AOC-7M |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
LSXM1GT24GPSE2 |
25 to 48 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
SFP-GE-SX-MM850-A |
R8043P06 |
SFP-GE-SX-MM850-D |
R8043P06 |
SFP-GE-T |
R8043P06 |
SFP-GE-T-D |
R8043P06 |
LSXM1QGS36TD2 |
1 to 36 |
LSWM1QSTK0 |
R7595 |
LSWM1QSTK1 |
R7595 |
LSWM1QSTK2 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
QSFP-40G-D-AOC-7M |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
LSXM1QGS36TE2 |
1 to 36 |
LSWM1QSTK0 |
R7595 |
LSWM1QSTK1 |
R7595 |
LSWM1QSTK2 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
QSFP-40G-D-AOC-7M |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
LSXM1SEERBA2 |
1 and 2, network ports 1 and 2 |
SFP-XG-SX-MM850-D |
R7624P68 |
SFP-XG-SX-MM850-E |
R7624P68 |
SFP-XG-SX-MM850-S |
R7624P68 |
LSXM1SEERBG2 |
SFP-XG-SX-MM850-D |
R7595 |
SFP-XG-SX-MM850-E |
R7595 |
SFP-XG-SX-MM850-S |
R7595 |
LSXM1SEERBXC2 |
SFP-XG-SX-MM850-D |
R7595 |
SFP-XG-SX-MM850-E |
R7595 |
SFP-XG-SX-MM850-S |
R7595 |
LSXM1SEERBXD2 |
SFP-XG-SX-MM850-D |
R7595 |
SFP-XG-SX-MM850-E |
R7595 |
SFP-XG-SX-MM850-S |
R7595 |
LSXM1SUP04T2 |
ALL |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
SFP-GE-SX-MM850-A |
R7595 |
SFP-GE-SX-MM850-D |
R7595 |
SFP-GE-SX-MM850-S |
R7595 |
SFP-GE-T |
R7595 |
SFP-GE-T-D |
R7595 |
LSXM1SUPS2 |
ALL |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
SFP-GE-SX-MM850-A |
R8043P06 |
SFP-GE-SX-MM850-D |
R8043P06 |
LSXM1TGS24XT24C4Q2TE2 |
1 to 24 |
CAB-0.5M-SFP+ |
R7624P68 |
CAB-1M-SFP+ |
R7624P68 |
CAB-3M-SFP+ |
R7624P68 |
LSTM1STK |
R7624P68 |
LSWM1STK |
R7624P68 |
LSWM2STK |
R7624P68 |
LSWM3STK |
R7624P68 |
SFP-10G-D-CAB-3M-Z |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
SFP-XG-SX-MM850-D |
R7624P68 |
SFP-XG-SX-MM850-E |
R7624P68 |
SFP-XG-SX-MM850-S |
R7624P68 |
25 to 28 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
53 and 54, 25 to 28 |
LSWM1QSTK0 |
R7624P68 |
LSWM1QSTK1 |
R7624P68 |
LSWM1QSTK2 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
QSFP-40G-D-AOC-7M |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
R7624P68 |
LSXM1TGS48SE2 |
1 to 48 |
CAB-0.5M-SFP+ |
R8043P06 |
CAB-1M-SFP+ |
R8043P06 |
CAB-3M-SFP+ |
R8043P06 |
LSTM1STK |
R8043P06 |
LSWM1STK |
R8043P06 |
LSWM2STK |
R8043P06 |
LSWM3STK |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
SFP-GE-SX-MM850-A |
R8043P06 |
SFP-GE-SX-MM850-D |
R8043P06 |
SFP-GE-T |
R8043P06 |
SFP-GE-T-D |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
R8043P06 |
SFP-XG-LX-SM1310 |
R8043P06 |
R8043P06 |
R8043P06 |
SFP-XG-SX-MM850-A |
R8043P06 |
SFP-XG-SX-MM850-D |
R8043P06 |
SFP-XG-SX-MM850-E |
R8043P06 |
SFP-XG-SX-MM850-F1 |
R8043P06 |
LSXM1TGS48TD2 |
1 to 48 |
CAB-0.5M-SFP+ |
R7595 |
CAB-1M-SFP+ |
R7595 |
CAB-3M-SFP+ |
R7595 |
LSTM1STK |
R7595 |
LSTM2STK |
R7595 |
LSWM1STK |
R7595 |
LSWM2STK |
R7595 |
LSWM3STK |
R7595 |
SFP-10GE-T |
E7633P01, |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
SFP-GE-SX-MM850-A |
R7595 |
SFP-GE-SX-MM850-D |
R7595 |
SFP-GE-T |
R7595 |
SFP-GE-T-D |
R7595 |
SFP-XG-D-AOC-10M |
R7595 |
SFP-XG-D-AOC-20M |
R7595 |
SFP-XG-D-AOC-7M |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
SFP-XG-LH80-Tunable |
R7595 |
R7595 |
SFP-XG-LX-SM1310 |
R7595 |
R7595 |
R7595 |
R7595 |
SFP-XG-SX-MM850-A |
R7595 |
SFP-XG-SX-MM850-D |
R7595 |
SFP-XG-SX-MM850-E |
R7595 |
R7595 |
LSXM1TGS48TE2 |
1 to 48 |
CAB-0.5M-SFP+ |
R7595 |
CAB-1M-SFP+ |
R7595 |
CAB-3M-SFP+ |
R7595 |
LSTM1STK |
R7595 |
LSTM2STK |
R7595 |
LSWM1STK |
R7595 |
LSWM2STK |
R7595 |
LSWM3STK |
R7595 |
SFP-10GE-T |
E7633P01, |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
SFP-GE-SX-MM850-A |
R7595 |
SFP-GE-SX-MM850-D |
R7595 |
SFP-GE-T |
R7595 |
SFP-GE-T-D |
R7595 |
SFP-XG-D-AOC-10M |
R7595 |
SFP-XG-D-AOC-20M |
R7595 |
SFP-XG-D-AOC-7M |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
SFP-XG-LX-SM1310 |
R7595 |
R7595 |
R7595 |
R7595 |
SFP-XG-SX-MM850-A |
R7595 |
SFP-XG-SX-MM850-D |
R7595 |
SFP-XG-SX-MM850-E |
R7595 |
R7595 |
LSXM1YGS24CGMODTE2 |
1 to 24 |
CAB-0.5M-SFP+ |
E7634P04 |
CAB-1M-SFP+ |
E7634P04 |
CAB-3M-SFP+ |
E7634P04 |
LSTM1STK |
E7634P04 |
LSTM2STK |
E7634P04 |
LSWM1STK |
E7634P04 |
LSWM2STK |
E7634P04 |
LSWM3STK |
E7634P04 |
SFP-10GE-T |
E7634P04, |
SFP-25G-D-AOC-10M |
R7624P07 |
SFP-25G-D-AOC-20M |
R7624P07 |
SFP-25G-D-AOC-3M |
R7624P07 |
SFP-25G-D-AOC-5M |
R7624P07 |
SFP-25G-D-AOC-7M |
R7624P07 |
SFP-25G-D-CAB-1M |
R7624P07 |
SFP-25G-D-CAB-3M |
R7624P07 |
SFP-25G-D-CAB-5M |
R7624P07 |
SFP-25G-LR-SM1310 |
R7624P07 |
SFP-25G-SR-MM850 |
R7624P07 |
SFP-XG-D-AOC-10M |
E7634P04 |
SFP-XG-D-AOC-20M |
E7634P04 |
SFP-XG-D-AOC-7M |
E7634P04 |
E7634P04 |
E7634P04 |
E7634P04 |
E7634P04 |
E7634P04 |
E7634P04 |
E7634P04 |
SFP-XG-LX-SM1310 |
E7634P04 |
E7634P04 |
E7634P04 |
E7634P04 |
SFP-XG-SX-MM850-A |
E7634P04 |
SFP-XG-SX-MM850-D |
E7634P04 |
SFP-XG-SX-MM850-E |
E7634P04 |
E7634P04 |
25 to 28 |
LSWM1QSTK0 |
R7624P07 |
LSWM1QSTK1 |
R7624P07 |
LSWM1QSTK2 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
QSFP-40G-D-AOC-7M |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
R7624P07 |
LSXM2SUPT2 |
ALL |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
R7595 |
SFP-GE-SX-MM850-A |
R7595 |
SFP-GE-SX-MM850-D |
R7595 |
SFP-GE-T |
R7595 |
SFP-GE-T-D |
R7595 |
LSXM3CDQ16SF2 |
1 to 16 |
CAB-400G-QSFP-DD-2m |
R8054 |
LSWM1QSTK0 |
R8054 |
LSWM1QSTK1 |
R8054 |
LSWM1QSTK2 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
QSFP-40G-D-AOC-7M |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
QSFPDD-400G-FR4-WDM1300 |
R8054 |
QSFPDD-400G-SR8-MM850 |
R8054 |
LSXM3CDQ8SF2 |
1 to 8 |
R8054 |
LSWM1QSTK0 |
R8054 |
LSWM1QSTK1 |
R8054 |
LSWM1QSTK2 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
QSFP-40G-D-AOC-7M |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
R8054 |
LSXM3CGQ18SF2 |
1 to 18 |
LSWM1QSTK0 |
E8051P02 |
LSWM1QSTK1 |
E8051P02 |
LSWM1QSTK2 |
E8051P02 |
LSWM1QSTK3 |
E8051P02 |
LSWM1QSTK4 |
E8051P02 |
LSWM1QSTK5 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
QSFP-40G-D-AOC-7M |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
LSXM3CGQ36SF2 |
1 to 36 |
LSWM1QSTK0 |
E8045P10 |
LSWM1QSTK1 |
E8045P10 |
LSWM1QSTK2 |
E8045P10 |
LSWM1QSTK3 |
E8045P10 |
LSWM1QSTK4 |
E8045P10 |
LSWM1QSTK5 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
QSFP-40G-D-AOC-7M |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
LSXM3GP48SE2 |
1 to 48 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
SFP-GE-SX-MM850-A |
R7743P06 |
SFP-GE-SX-MM850-D |
R7743P06 |
SFP-GE-T |
R7743P06 |
SFP-GE-T-D |
R7743P06 |
LSXM3GT24GPSE2 |
25 to 48 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
SFP-GE-SX-MM850-A |
R7743P06 |
SFP-GE-SX-MM850-D |
R7743P06 |
SFP-GE-T |
R7743P06 |
SFP-GE-T-D |
R7743P06 |
LSXM3QGS36SF2 |
1 to 36 |
LSWM1QSTK0 |
E8051P02 |
LSWM1QSTK1 |
E8051P02 |
LSWM1QSTK2 |
E8051P02 |
LSWM1QSTK3 |
E8051P02 |
LSWM1QSTK4 |
E8051P02 |
LSWM1QSTK5 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
QSFP-40G-D-AOC-7M |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
E8051P02 |
LSXM3SUP04S2 |
ALL |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
SFP-GE-SX-MM850-A |
E8045P10 |
SFP-GE-SX-MM850-D |
E8045P10 |
SFP-GE-SX-MM850-S |
E8045P10 |
LSXM3SUPS2 |
ALL |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
R7743P06 |
SFP-GE-SX-MM850-A |
R7743P06 |
SFP-GE-SX-MM850-D |
R7743P06 |
LSXM3TGS48SF2 |
1 to 48 |
CAB-0.5M-SFP+ |
E8045P10 |
CAB-1M-SFP+ |
E8045P10 |
CAB-3M-SFP+ |
E8045P10 |
LSTM1STK |
E8045P10 |
LSWM1STK |
E8045P10 |
LSWM2STK |
E8045P10 |
LSWM3STK |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
SFP-GE-SX-MM850-A |
E8045P10 |
SFP-GE-SX-MM850-D |
E8045P10 |
SFP-GE-SX-MM850-S |
E8045P10 |
SFP-GE-T |
E8045P10 |
SFP-GE-T-D |
E8045P10 |
E8045P10 |
E7745P10 |
E8045P10 |
E8045P10 |
E7745P10 |
E8045P10 |
E7745P10 |
E8045P10 |
E8045P10 |
SFP-XG-LX-SM1310 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
SFP-XG-SX-MM850-A |
E8045P10 |
SFP-XG-SX-MM850-D |
E8045P10 |
SFP-XG-SX-MM850-E |
E8045P10 |
SFP-XG-SX-MM850-S |
E8045P10 |
LSXM3YGS48SF2 |
1 to 48 |
CAB-0.5M-SFP+ |
E8045P10 |
CAB-1M-SFP+ |
E8045P10 |
CAB-3M-SFP+ |
E8045P10 |
LSTM1STK |
E8045P10 |
LSWM1STK |
E8045P10 |
LSWM2STK |
E8045P10 |
LSWM3STK |
E8045P10 |
E8045P10 |
SFP-25G-D-AOC-10M |
E8045P10 |
SFP-25G-D-AOC-20M |
E8045P10 |
SFP-25G-D-AOC-3M |
E8045P10 |
SFP-25G-D-AOC-5M |
E8045P10 |
SFP-25G-D-AOC-7M |
E8045P10 |
SFP-25G-D-CAB-1M |
E8045P10 |
SFP-25G-D-CAB-3M |
E8045P10 |
SFP-25G-D-CAB-5M |
E8045P10 |
SFP-25G-LR-SM1310 |
E8045P10 |
SFP-25G-SR-MM850 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
SFP-GE-SX-MM850-A |
E8045P10 |
SFP-GE-SX-MM850-D |
E8045P10 |
SFP-GE-SX-MM850-S |
E8045P10 |
SFP-GE-T |
E8045P10 |
SFP-GE-T-D |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
SFP-XG-LX-SM1310 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
E8045P10 |
SFP-XG-SX-MM850-A |
E8045P10 |
SFP-XG-SX-MM850-D |
E8045P10 |
SFP-XG-SX-MM850-E |
E8045P10 |
SFP-XG-SX-MM850-S |
E8045P10 |
