- Released At: 11-10-2020
- Page Views:
- Downloads:
H3C S12500G-AF Switch Series Troubleshooting Guide
Software version: Release 7595
Document version: 6W100-20200930
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Collecting log and operating information
Collecting common log messages
Collecting diagnostic log messages
Collecting operating statistics
Dealing with console login password loss
Telnetting to the device to change the console login password
Using BootWare menus to change the console login password
Dealing with Telnet password loss
Troubleshooting configuration loss
Startup configuration file failure
Newly installed standby MPU boot failure
Newly installed service module boot failure
Operating power module failure
Newly installed power module failure
Troubleshooting system management
10-Gigabit SFP+ fiber port fails to come up
40-GE QSFP+ fiber port fails to come up
100-GE QSFP28 fiber port fails to come up
Reporting non-H3C transceiver modules
Failure to support digital diagnosis on a transceiver module
Error frames (for example, CRC errors) on a port
ACL application failure for unsupported ACL rules
ACL application failure for insufficient resources
ACL application failure without an error message
Service module assignment failure
Member ports of a DR interface cannot be selected
Introduction
This document provides information about troubleshooting common software and hardware issues with H3C S12500G-AF switches.
General guidelines
IMPORTANT: To prevent an issue from causing loss of configuration, save the configuration each time you finish configuring a feature. For configuration recovery, regularly back up the configuration to a remote server. |
When you troubleshoot the switch, follow these general guidelines:
· To help identify the cause of the issue, collect system and configuration information, including:
¡ Symptom, time of failure, and configuration.
¡ Network topology information, including the network diagram, port connections, and points of failure.
¡ Log messages and diagnostic information. For more information about collecting this information, see "Collecting log and operating information."
¡ Physical evidence of failure:
- Photos of the hardware.
- Status of the card, power, and fan status LEDs.
¡ Steps you have taken, such as reconfiguration, cable swapping, and reboot.
¡ Output from the commands executed during the troubleshooting process.
· To ensure safety, wear an ESD wrist strap when you replace or maintain a hardware component.
· If hardware replacement is required, use the release notes to verify the hardware and software compatibility.
IMPORTANT: By default, the information center is enabled. If the feature is disabled, you must use the info-center enable command to enable the feature for collecting log messages. |
Table 1 shows the types of files that the system uses to store operating log and status information. You can export these files by using FTP or TFTP.
These files are stored on the active MPU (in standalone mode) or global active MPU (in IRF mode). Multiple MPUs will have log files if active/standby or master/subordinate switchovers have occurred. You must collect log files from all these MPUs. To more easily locate log information, use a consistent rule to categorize and name files. For example, save log information files to a separate folder for each MPU, and include their chassis and slot numbers in the folder names.
Table 1 Log and operating information
Category |
File name format |
Content |
Common log |
logfile.log |
Command execution and operational log messages. |
Diagnostic log |
diagfile.log |
Diagnostic log messages about device operation, including the following items: · Parameter settings in effect when an error occurs. · Information about a card startup error. · Handshaking information between the MPU and interface module when a communication error occurs. |
Operating statistics |
file-basename.gz |
Current operating statistics for feature modules, including the following items: · Device status. · CPU status. · Memory status. · Configuration status. · Software entries. · Hardware entries. |
1. Save common log messages from the log buffer to a log file:
By default, the log file is saved in the logfile directory of the flash memory on the active MPU (in standalone mode) or global active MPU (in IRF mode).
# Save log messages to the log file on the default MDC (Admin).
<Sysname> logfile save
The contents in the log file buffer have been saved to the file flash:/logfile/logfile1.log
# Identify non-default MDCs created on the device.
<Sysname> display mdc
ID Name Status
1 Admin active
2 mdc2 active
3 mdc3 active
# Save log messages to the log file on each non-default MDC.
[Sysname] switchto mdc mdc2
* Copyright (c) 2004-2020 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
<Sysname> switchback
[Sysname] switchto mdc 3
2. On the default MDC, identify the log file on each MPU for each MDC:
# Display the log file on the active MPU (in standalone mode) or global active MPU (in IRF mode) for the default MDC.
<Sysname> dir flash:/logfile/
Directory of flash:/logfile
0 -rw- 97764 Apr 27 2020 15:55:32 logfile1.log
3710740 KB total (2508852 KB free)
# Display the log file on each standby MPU for the default MDC:
¡ In standalone mode, display the log file on the standby MPU.
<Sysname> dir slot1#flash:/logfile/
Directory of slot1#flash:/logfile
0 -rw- 21863 Apr 27 2020 16:00:37 logfile1.log
3710740 KB total (3002308 KB free)
¡ In IRF mode, display the log file on each standby MPU.
<Sysname> dir chassis2#slot1#flash:/logfile/
Directory of chassis2#slot1#flash:/logfile
3710740 KB total (3273812 KB free)
NOTE: If a subordinate chassis has two MPUs, make sure you identify and export the log files on both MPUs. |
# Display the log file on each MPU for each non-default MDC.
<Sysname> dir flash:/mdc/
Directory of flash:/mdc
0 drw- - Apr 27 2020 14:56:50 mdc2
1 drw- - Apr 27 2020 16:48:04 mdc3
<Sysname> dir flash:/mdc/mdc2/logfile/
Directory of flash:/mdc/mdc2/logfile
0 -rw- 465 Apr 27 2020 16:08:51 logfile1.log
<Sysname> dir flash:/mdc/mdc3/logfile/
Directory of flash:/mdc/mdc3/logfile
0 -rw- 465 Apr 27 2020 16:10:39 logfile1.log
3. Transfer the files to the desired destination by using FTP or TFTP. (Details not shown.)
1. Save diagnostic log messages from the diagnostic log file buffer to a diagnostic log file:
By default, the diagnostic log file is saved in the diagfile directory of the flash memory on each MPU.
# Save diagnostic log messages to the diagnostic log file on the default MDC (Admin).
<Sysname> diagnostic-logfile save
The contents in the diagnostic log file buffer have been saved to the file flash:/diagfile/diagfile1.log
ID Name Status
1 Admin active
2 mdc2 active
3 mdc3 active
# Save diagnostic log messages to the diagnostic log file on each non-default MDC.
The contents in the diagnostic log file buffer have been saved to the file flash :/diagfile/diagfile1.log
2. On the default MDC, identify the diagnostic log file on each MPU for each MDC:
# Display the diagnostic log file on the active MPU (in standalone mode) or global active MPU (in IRF mode) for the default MDC.
<Sysname> dir flash:/diagfile/
Directory of flash:/diagfile
0 -rw- 161321 Apr 27 2020 16:16:00 diagfile1.log
# Display the diagnostic log file on each standby MPU for the default MDC:
¡ In standalone mode, display the diagnostic log file on the standby MPU.
<Sysname> dir slot1#flash:/diagfile/
¡ In IRF mode, display the diagnostic log file on each standby MPU.
<Sysname> dir chassis2#slot0#flash:/diagfile/
Directory of chassis2#slot0#flash:/diagfile
NOTE: If a subordinate chassis has two MPUs, make sure you identify and export the diagnostic log files on both MPUs. |
# Display the diagnostic log file on each MPU for each non-default MDC.
<Sysname>dir flash:/diagfile/
0 -rw- 349 Apr 27 2020 16:21:38 diagfile1.log
0 -rw- 349 Apr 27 2020 16:24:41 diagfile1.log
You can collect operating statistics by saving the statistics to a file or displaying the statistics on the screen.
When you collect operating statistics, follow these guidelines:
· Log in to the device through a network port or management port instead of the console port, if possible. Network and management ports are faster than the console port.
· Do not execute commands while operating statistics are being collected.
· As a best practice, save operating statistics to a file to retain the information.
To collect operating statistics:
1. Disable pausing between screens of output if you want to display operating statistics on the screen. Skip this step if you are saving statistics to a file.
<Sysname> screen-length disable
2. Execute the display cpu-usage and display memory commands to verify that the CPU usage is lower than 100% and the memory usage is lower than 90%.
<Sysname> display cpu-usage
<Sysname> display memory
3. Collect operating statistics for multiple feature modules.
Save or display diagnostic information (Y=save, N=display)? [Y/N] :
4. At the prompt, choose to save or display operating statistics:
# To save operating statistics, enter y at the prompt and then specify the destination file path.
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_H3C_20200523-151204.tar.gz]:
Diagnostic information is outputting to flash:/diag_H3C_20200523-151204.tar.gz.
Please wait...
Save successfully.
Directory of flash:
9 -rw- 236011 May 23 2020 14:56:45 diag_H3C_20200523-151204.tar.gz
# To display operating statistics on the monitor terminal, enter n at the prompt. (Operating statistics vary by software version.)
Save or display diagnostic information (Y=save, N=display)? [Y/N] :N
10:27:16 UTC Wed 05/23/2020
H3C Comware Software, Version 7.1.070, Release 7595
H3C S12508G-AF uptime is 0 weeks, 1 day, 6 hours, 23 minutes
Last reboot reason : USER reboot
Boot image: flash:/S12500G-CMW710-BOOT-E7595.bin
Boot image version: 7.1.070, Release 7595
Compiled May 19 2020 11:00:00
System image: flash:/S12500G-CMW710-SYSTEM-E7595.bin
System image version: 7.1.070, Release 7595
Feature image(s) list:
flash:/S12500G-CMW710-DEVKIT-E7595.bin, version: 7.1.070, Release 7595
flash:/S12500G-CMW710-FREERADIUS-E7595.bin, version: 7.1.070, Release 7595
Patch image(s) list:
flash:/S12500G-CMW710-SYSTEM-E7595H01.bin, version: 7.1.070
MPU(M) 0:
Uptime is 0 weeks,1 days,8 hours,41 minutes
BOARD TYPE: LSXM2SUPT2
DRAM: 16384M bytes
FLASH: 3630M bytes
NVRAM: 512K bytes
PCB 1 Version: VER.A
PCB 2 Version: VER.A
PCB 3 Version: VER.A
PCB 4 Version: VER.B
Basic BootWare Version: 107
Extended BootWare Version: 302
CPLD 1 Version: 002
CPLD 2 Version: 002
CPLD 3 Version: 002
CPLD 4 Version: 002
PowChip Version: NONE
PLL Version: None
Release Version: H3C S12516G-AF-7595
Patch Version: None
Reboot Cause: UserReboot
MPU(S) 1:
DRAM: 16384M bytes
FLASH: 3630M bytes
NVRAM: 512K bytes
CPLD 1 Version: 002
CPLD 2 Version: 002
CPLD 3 Version: 002
CPLD 4 Version: 002
PLL Version: None
Patch Version: None
LPU 3:
Uptime is 0 weeks,1 day,8 hours,51 minutes
BOARD TYPE: LSXM1CGQ36TE2
DRAM: 8192M bytes
FLASH: 0M bytes
NVRAM: 0K bytes
PCB 4 Version: VER.A
Basic BootWare Version: 100
Extended Bootrom Version: 100
CPLD 1 Version: 001
CPLD 2 Version: 001
CPLD 3 Version: 002
FPGA 1 Version: 006
Power CPLD Version: 007
PLL Version: None
PCIE 1 Version: 001
PCIE 2 Version: 001
PCIE 3 Version: 001
PCIE 4 Version: 001
Patch Version: None
NPU 18:
BOARD TYPE: LSXM1SFT16F2
DRAM: 8192M bytes
FLASH: 0M bytes
NVRAM: 0K bytes
PCB 2 Version: VER.B
CPLD 1 Version: 001
CPLD 2 Version: 002
PLL Version: None
Patch Version: None
Contacting technical support
If an issue persists after you perform the troubleshooting procedures in this document, contact H3C Support. When you contact an authorized H3C support representative, be prepared to provide the following information:
· Information described in "General guidelines."
· Product serial numbers.
This information will help the support engineer assist you as quickly as possible.
You can contact H3C Support at mailto:service@h3c.com.
Removing deployment errors
Use the deployment checklist in Table 2 to eliminate issues that might be introduced at the deployment stage. Select items that are suitable for your site.
Question |
Command or method |
Result |
Remarks |
Environment and card hardware status |
Is the switch temperature 20°C (68°F) lower than the warning temperature threshold? |
display environment |
□OK □Not OK □Not related |
Make sure the temperature of the switch is 20°C (68°F) lower than the warning temperature threshold. |
Are the fan trays operating correctly? |
display fan |
Make sure the fan trays are operating correctly. |
Are sufficient power supplies installed and are they operating correctly? |
display power |
Make sure the following conditions are met: · You have installed sufficient power supplies to provide power redundancy. · The power supplies are operating correctly. The display power command shows that their state is Normal. |
Are the LEDs all displaying correct statuses? |
Visually check the RUN LED and alarm LED on each card |
Verify that the RUN LED flashes slowly, and the alarm LED is off. |
Are all cards operating correctly? |
display device |
Make sure all cards are operating correctly. · All service cards are in Normal state. · The active MPU is in Master state. · The standby MPUs are in Standby state. |
Active and standby MPUs |
Are the software versions of the active and standby MPUs the same? |
display boot-loader |
Make sure the software versions of the active and standby MPUs are the same. |
Do the standby MPUs have a startup configuration file? |
dir |
If any standby MPUs do not have a startup configuration file, execute the save command without specifying any parameters. This command enables you to save the running configuration to a configuration file and specifies the file as the next-startup configuration file on each MPU. |
CPU and memory usage |
Does the CPU usage change rate of any cards (MPUs and LPUs) exceed 10%? Does the sustained CPU usage exceed 60%? |
display cpu-usage |
Execute the display cpu-usage command repeatedly. If the CPU of a card sustains a usage level of over 60% or has a change rate higher than 10%, execute the debug ip packet command to view the packets delivered to the CPU for analysis. |
Does the memory usage of the MPUs and service modules exceed 60%? |
display memory |
If memory usage exceeds 60%, execute the display system internal kernel memory pool slot command in probe view to identify the module that is using the most memory. |
Ports |
Is there a port operating in half-duplex mode? |
display interface brief |
If there is a port operating in half-duplex mode, identify whether the two ends are consistent in configuration. |
Is flow control unnecessarily enabled on ports? |
display current-configuration interface |
Execute the undo flow-control command if flow control is not needed on a port. |
Are large numbers of error packets generated continuously in the outbound or inbound direction of the port? |
display interface |
If an error counter displays a non-zero value and the value is increasing, check for the following errors: · Link and optical-electrical converter errors. · Port setting inconsistencies with the peer port. |
Does the port change between an up and down state frequently? |
display logbuffer |
If the port state flaps, check for the following errors: · Link and optical-electrical converter errors. · Optical power threshold crossing events if the port is a fiber port. · Port setting inconsistencies with the peer port. |
Fiber ports |
Do the ports at the two ends use the same port settings? |
To connect an H3C device to a device from another vendor, set the same port rate and duplex mode settings at the two ends as a best practice. |
Are CRC errors present on any fiber port? Is the number of CRC errors increasing? |
display interface |
If CRC errors persist, replace the transceiver module or pigtail fiber, or clean the transceiver module connector. |
Trunk port configuration |
Do the peer trunk ports use the same PVID? |
Make sure the same PVID is configured on the trunk ports between two devices. |
Are the peer ports assigned to the same VLANs? |
Make sure the trunk ports between two devices are assigned to the same VLANs. For example, if you assign a trunk port to all VLANs, also assign its peer port to all VLANs. |
Are the peer ports set to the same link type? |
Make sure the ports between two devices use the same link type. |
Is a loop present in VLAN 1? |
loopback-detection global enable vlan 1 |
Remove ports from VLAN 1 as needed. |
Spanning tree feature |
Is the timeout factor correctly set? |
display current-configuration |
As a best practice to avoid unnecessary recalculations, set a timeout factor in the range of 5 to 7 on a stable network. |
Are ports connected to end-user devices configured as edge ports? |
Verify that the output from the display current-configuration interface command contains the "stp edged-port enable" string for ports connected to end-user devices. As a best practice, configure ports connected to end-user devices (PCs, for example) as edge ports, or disable the spanning tree feature on the ports. |
Is the device running MSTP, STP, or RSTP, and working with a Cisco PVST+ device? |
display stp |
As a best practice to avoid interoperability issues, set up a Layer 3 connection to the Cisco device. |
Do the topologies of MSTIs meet the design? Are there as few overlapping paths as possible among MSTIs? |
If the topologies deviate from the design, reassign ports to VLANs and revise the VLAN and instance mappings. For optimal load balancing, plan VLANs and VLAN-to-instance mappings to minimize overlapping paths among different MSTIs. |
Does a TC attack exist to cause frequent STP status changes on any ports? |
display stp tc display stp history |
Examine the following items in the command output for TC attacks: · Incoming and outgoing TC/TCN BPDU statistics. · Historical port role calculation information. There is a risk of TC attack if frequent STP status changes occur on a stable network. Make sure you have configured the following settings: · Configure ports connected to end-user devices as edge ports, and enable BPDU guard. Alternatively, disable the spanning tree feature on the ports. · Disable the spanning tree feature on ports connected to devices that do not support spanning tree protocols. · Do not disable TC-BPDU guard. |
VRRP |
Is the handshake interval correctly set? Are the handshake intervals of the two ends the same? |
display vrrp |
Change the handshake interval to 3 seconds if the number of VRRP groups is smaller than 5. If five or more VRRP groups exist, assign three or five VRRP groups to one group, and configure the handshake interval as 3 seconds, 5 seconds, and 7 seconds for the groups, respectively. |
ARP |
Are there ARP conflicts? |
display logbuffer |
If the log contains ARP conflict records, verify that the hosts in conflict are legitimate, and remove the conflicts. |
OSPF |
Is the router ID of the device unique on the network? |
display ospf peer |
Change the router ID if it is not unique on the network. To restart route learning after you remove the router ID conflict, you must execute the reset ospf process command. |
Are there a lot of errors in the output from the display ospf statistics error command? |
display ospf statistics error |
If a large number of OSPF errors has occurred and the number continues to increase, collect the error information for further analysis. |
Are there severe route flappings? |
display ip routing-table statistics |
Examine the statistics for added and deleted routes during the system uptime. If route flapping occurs, locate the flapping route and the source device to analyze the cause. You can use the display ospf lsdb command multiple times to view the age of routes and locate the flapping route. |
Is the OSPF status stable? |
display ospf peer |
View the up time of the OSPF neighbor. |
Routes |
Is the default route correct? Are there any routing loops? |
tracert debug ip packet |
Use the tracert command to trace the path to a nonexistent network (1.1.1.1, for example) to check for routing loops. If a routing loop exists, check the configuration of the involved devices for errors. Adjust the route to remove the loop. Use the debug ip packet command to check for packets with TTL 0 or 1. If TTL exceeded packets are received, check for network route errors. |
CPU security |
Are there packet attacks on the CPU? |
debug rxtx softcar show |
Execute the debug rxtx softcar show command in probe view to view packet rate limit information for cards. The CPU is under attack if the number of packets of a type keeps increasing unusually. |
Dealing with password loss
Use either of the following methods:
· (Preferred.) Telnetting to the device to change the console login password
· Using BootWare menus to change the console login password
Before you Telnet to the device, make sure the following requirements are met:
· You can log in to the device by using Telnet.
· After login, you are assigned the user role network-admin or level-15.
To Telnet to the device to change the console login password:
1. Telnet to the device. (Details not shown.)
2. Determine the user line you are using.
<Sysname> display users
Idx Line Idle Time Pid Type
1 AUX 1/1 00:00:36 Jun 14 16:35:09 543
+ 16 VTY 0 00:00:00 Jun 14 17:02:03 566 TEL
Following are more details.
VTY 0 :
+ : Current operation user.
F : Current operation user works in async mode.
The output shows that two users are online. You are using VTY 0. Your IP address is 192.168.29.1. The other user is using AUX 1/1.
3. Display the user roles assigned to the user line you are using.
[Sysname] line vty 0
[Sysname-line-vty0] display this
line aux 1/1
user-role network-operator
line vty 0
authentication-mode none
user-role level-15
user-role network-admin
return
The output shows that VTY 0 has the user role level-15. You have the right to change the console login password.
4. Configure password authentication for console login and set the password. You can also configure a different login authentication mode.
[Sysname] line aux 1/1
[Sysname-line-aux1/1] authentication-mode password
[Sysname-line-aux1/1] set authentication password simple abc123
[Sysname-line-aux1/1] return
5. Save the running configuration to use the configuration at the next reboot.
<Sysname> save
The current configuration will be written to the device. Are you sure? [Y/N] :y
Please input the file name(*.cfg)[flash:/default.cfg]
(To leave the existing filename unchanged, press the enter key):default.cfg
Validating file. Please wait....
CAUTION: · Use this method only if you cannot access the CLI. A reboot is required to access BootWare menus. · Do not power off the device while you are using this method. |
The procedure for using BootWare menus to change the console login password depends on whether password recovery capability is enabled:
· If password recovery capability is enabled, you can use the Skip Authentication for Console Login option to skip console login authentication and configure a new password.
· If password recovery capability is disabled, you can use the Restore to Factory Default Configuration option to restore the factory-default configuration and configure a new password.
To determine whether password recovery capability is enabled, use either of the following methods:
· Telnet to the device and display the running configuration. If the password-recovery enable command is configured, password recovery capability is enabled.
<Sysname> display current-configuration
version 7.1.070, Release 7595
mdc Admin id 1
sysname Sysname
· View the bootstrap information displayed when you access the extended BootWare menu. If the message "Password recovery capability is enabled." is displayed, password recovery capability is enabled.
Changing the console login password when password recovery capability is enabled
1. Connect a configuration terminal to the console port of the device.
2. Power on the device.
System is Starting...
Press Ctrl+D Into xmodem mode
Press Ctrl+T to start memory test
Booting Normal Extend Bootware
Press Ctrl+V to start heavy memory test
* MPU BootWare, Version 3.02 *
Compiled Date : Apr 28 2019 10:27:24
Basic BootWare : 0107
CPU Type : C2538
CPU Clock Speed : 2400MHz
Memory Type : DDR3 SDRAM
Memory Size : 16384MB
Memory Speed : 1333MHz
Flash Size : 3630MB
BASIC CPLD Version : 2.0
EXTENDED CPLD Version : 2.0
PCB Version1 : Ver.A
PCB Version2 : Ver.A
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
3. Press Ctrl + B within 3 seconds after the "Press Ctrl+B to access EXTENDED-BOOTWARE MENU..." prompt message appears.
The extended BootWare menu is displayed:
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System |
|<2> Enter Ethernet SubMenu |
|<3> File Control |
|<4> Restore to Factory Default Configuration |
|<5> Skip Current System Configuration |
|<6> Skip Authentication for Console Login |
|<7> BootWare Operation Menu |
|<8> Storage Device Operation |
|<0> Reboot |
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Enter your choice(0-8):
4. Enter 6 to skip console login authentication.
Enter your choice(0-8): 6
Clear Image Password Success!
The extended BootWare menu is displayed again:
|<1> Boot System |
|<3> File Control |
|<0> Reboot |
5. Enter 0 to reboot the device. The device will ignore the console login password to access the CLI and load the next-startup configuration file.
Enter your choice(0-8): 0
6. After the device starts up, configure a new console login password. You can also configure a different login authentication mode.
7. Save the running configuration to use the configuration at the next reboot.
<Sysname> save
Changing the console login password when password recovery capability is disabled
IMPORTANT: Restoring the factory-default configuration deletes the next-startup configuration files. |
To change the console login password when password recovery capability is disabled:
CPU Type : C2538
Flash Size : 3630MB
Password recovery capability is disabled.
|<1> Boot System |
|<3> File Control |
|<0> Reboot |
4. Enter 4 and press Y to delete the next-startup configuration files.
Enter your choice(0-8): 4
Because the password recovery capability is disabled, this operation can
cause the configuration files to be deleted, and the system will start up
with factory defaults. Are you sure to continue?[Y/N] Y
Setting...Done.
|<1> Boot System |
|<3> File Control |
|<0> Reboot |
5. Enter 0 to reboot the device. The device will reboot with the factory defaults.
6. Save the running configuration to use the configuration at the next reboot.
<Sysname> save
1. Log in to the device through the console port.
2. Configure password authentication and a new password for VTY lines. You can also configure a different login authentication mode.
[Sysname] line vty 0 63
[Sysname-line-vty0-63] authentication-mode password
[Sysname-line-vty0-63] set authentication password simple abc123
[Sysname-line-vty0-63] return
3. Save the running configuration to enable the configuration to survive a reboot.
<Sysname> save
This section provides troubleshooting information for common configuration management problems.
Symptom
The device starts up with factory defaults because both the main and backup startup configuration files are not available or do not exist.
Solution
CAUTION: Do not execute the save command before you complete the tasks in this section. The save operation overwrites the restored startup configuration file with the running configuration. |
To resolve the issue:
1. Transfer a backup copy of the startup configuration file to the root directory of the default storage medium on each MPU:
IMPORTANT: The device loads startup configuration files from the default storage medium. · Make sure all MPUs use the same type of storage medium as the default storage medium. In this section, the flash memory is used on each MPU. · If a partitioned USB disk is used, make sure the configuration file is transferred to the root directory of the first partition on the USB disk. |
a. Download configuration file config.cfg from the FTP server to the root directory of the flash memory on the active MPU.
<Sysname> ftp 192.168.29.1
Press CTRL+C to abort.
Connected to 192.168.29.1 (192.168.29.1).
User (192.168.29.1:(none)): 1
Password:
230 Logged in successfully
Remote system type is MSDOS.
ftp> binary
200 Type is Image (Binary)
ftp> get config.cfg flash:/config.cfg
227 Entering Passive Mode (192,168,29,1,209,24)
150 "F:\config.cfg" file ready to send (18494 bytes) in IMAGE / Binary mode
226 Transfer finished successfully.
18494 bytes received in 0.0383 seconds (471.1 kbyte/s)
ftp> quit
221 Windows FTP Server (WFTPD, by Texas Imperial Software) says goodbye
b. Copy the configuration file to the root directory of the flash memory on the standby MPU.
<Sysname> copy config.cfg slot1#flash:/config.cfg
Copy flash:/config.cfg to slot1#flash:/config.cfg?[Y/N] :y
Coping file flash:/config.cfg to slot1#flash:/config.cfg...Done.
2. Specify the configuration file as the main startup configuration file. Skip this step if the configuration file uses the same name as the corrupt main startup configuration file.
<Sysname> startup saved-configuration config.cfg
3. Reboot the device.
4. If the issue persists, contact H3C Support.
This section lists the commands that you might use for troubleshooting configuration loss.
Command |
binary |
Sets the file transfer mode to binary. |
copy |
Copies a file and saves the file to the destination directory. |
ftp |
Logs in to an FTP server and enters FTP client view. |
get |
Downloads a file from the FTP server and saves the file. |
startup saved-configuration |
Specifies a file as a startup configuration file for each MPU. |
Troubleshooting hardware
This section provides troubleshooting information for common hardware issues.
NOTE: This section describes how to troubleshoot MPUs, service modules, power modules, and fan trays. To troubleshoot transceiver modules, ports, and temperature alarms, see "Troubleshooting system management" and "Troubleshooting ports." |
MPU reboot failure
Symptom
An MPU fails to reboot.
Troubleshooting flowchart
Figure 1 Troubleshooting MPU reboot failure
Solution
1. Verify that the system software image on the MPU is correct.
a. Log in to the MPU through the console port and restart the switch. If the system reports that a CRC error occurs or that no system software image is available during the BootWare loading process, reload the system software image.
b. Verify that the system software image in the flash memory is the same size as the one on the server. If no system software image is available in the flash memory, or if the image size is different from the one on the server, reload the system software image. Then set the reloaded system software image to the current system software image.
The system software image in the flash memory is automatically set to the current system software image during the BootWare loading process.
2. Verify that the MPU memory is running correctly.
Reboot the MPU, and immediately press CTRL+T to examine the memory. If a memory fault is detected, replace the MPU.
3. Verify that no error is reported during the BootWare loading process.
If there are still errors reported during the BootWare loading process, identify the faulty module and verify that the MPU is installed securely.
¡ If the MPU is not installed securely, remove and reinstall the MPU.
¡ If the MPU is installed securely, replace the MPU.
Symptom
An MPU designated as the standby MPU fails to boot after installation.
Figure 2 Troubleshooting newly installed standby MPU boot failure
Solution
1. Verify that the newly installed standby MPU is the same model as the active MPU. If they are not the same model, replace the standby MPU with one that is the same model as the active MPU.
2. Verify that the standby MPU runs the same software version as the active MPU. If the two MPUs run different software versions, upgrade the software version of the standby MPU to make sure the two MPUs run the same software version.
3. If the issue persists, contact H3C Support.
Service module reboot failure
Symptom
A service module fails to reboot.
Figure 3 Troubleshooting service module reboot failure
Solution
1. Verify that the system software image is available and that the image is the same size as the one on the server. If no system software image is available, or the system software image size is different from the one on the server, reload the system software image.
<Sysname> display boot-loader
Software images on slot 0:
Current software images:
flash:/S12500G-CMW710-SYSTEM- E7595.bin
Main startup software images:
Backup startup software images:
None
<Sysname> dir
Directory of flash:
0 drw- - Apr 26 2020 16:18:06 core
1 drw- - Apr 30 2020 11:32:34 diagfile
2 -rw- 7122 Apr 23 2020 10:02:46 ifindex.dat
3 drw- - Apr 23 2020 19:00:37 license
4 drw- - Apr 30 2020 11:51:15 logfile
5 -rw- 20529152 Apr 22 2020 14:28:40 S12500G-cmw710-boot-e7595.bin
6 -rw- 178325504 Apr 22 2020 14:39:02 S12500G-cmw710-system-e7595.bin
7 drw- - Apr 30 2020 11:32:34 seclog
8 -rw- 17175 Apr 23 2020 10:02:48 startup.cfg
9 -rw- 276535 Apr 23 2020 10:02:48 startup.mdb
10 drw- - Apr 22 2020 11:11:54 versionInfo
3710740 KB total (2882156 KB free)
2. Install another service module into the slot.
¡ If the new service module boots successfully, no failure occurs on the MPU and backplane. Go to step 3.
¡ If the new service module fails to boot, replace the MPU.
3. Verify that the service module has loaded files.
<Sysname> display logbuffer
%May 3 13:27:17:086 2020 H3C DEVM/4/BOARD_LOADING: Board is loading file on Chassis 1 Slot 7.
%May 3 13:27:17:647 2020 H3C DEVM/5/LOAD_FINISHED: Board has finished loading file on Chassis 1 Slot 7.
¡ If there are loading records about the service module, install the service module into another slot to verify that the service module can boot successfully.
¡ If there are no loading records about the service module, go to step 4.
Symptom
A newly installed service module fails to boot.
Figure 4 Troubleshooting service module boot failure
Solution
None
<Sysname> dir
Directory of flash:
2. See the release notes to determine whether the system software image supports the service module. If the system software image does not support the service module, upgrade the system software image to the version that supports the service module.
3. Remove the service module and contact the customer service to check whether the connectors of the service module and slot are damaged.
Before installing the service module in another slot, make sure the connectors of the service module are not damaged. Before installing another service module in the slot, make sure the connectors of the slot are not damaged.
4. Install another service module that is compatible with the system software image into the slot to verify that the service module can boot successfully. If the service module boots successfully, no failure occurs on the MPU and backplane. If the service module fails to boot, replace the MPU.
5. Execute the display logbuffer command to verify that the service module has loaded files.
[Sysname]display logbuffer
¡ If the service module has loaded files, install the service module into another slot to verify that the service module can load files successfully.
¡ If the service module has not leaded files, go to step 6.
6. If the issue persists, contact H3C Support.
Symptom
An operating power module fails.
Figure 5 Troubleshooting operating power supply failure
Solution
1. Identify the operating state of the power module.
¡ Execute the display power command to view the operating state of the power module.
<H3C>display power
Input Power: 2364.0 W
PowerID State Mode Current(A) Voltage(V) Power(W) FanDirection
1 Absent -- -- -- -- --
2 Absent -- -- -- -- --
3 Absent -- -- -- -- --
4 Absent -- -- -- -- --
5 Absent -- -- -- -- --
6 Absent -- -- -- -- --
7 Absent -- -- -- -- --
8 Absent -- -- -- -- --
9 Absent -- -- -- -- --
10 Absent -- -- -- -- --
11 Normal AC 24.5 54.9 1345.5 --
12 Absent -- -- -- -- --
13 Absent -- -- -- -- --
14 Absent -- -- -- -- --
15 Absent -- -- -- -- --
16 Absent -- -- -- -- --
<H3C>
¡ Execute the display alarm command to view alarm information about the power module.
<H3C>display alarm
Slot CPU Level Info
- - INFO Power 1 is absent.
- - INFO Power 2 is absent.
- - INFO Power 3 is absent.
- - INFO Power 4 is absent.
- - INFO Power 5 is absent.
- - INFO Power 6 is absent.
- - INFO Power 7 is absent.
- - INFO Power 8 is absent.
- - INFO Power 9 is absent.
- - INFO Power 10 is absent.
- - INFO Power 12 is absent.
- - INFO Power 13 is absent.
- - INFO Power 14 is absent.
- - INFO Power 15 is absent.
- - INFO Power 16 is absent.
<H3C>
If the power module is in Absent state, go to step 2. If the power module is in Faulty state, go to step 3.
2. Verify that the power module is installed securely.
Remove and reinstall the power module to make sure the power module is installed securely. Then execute the display power command to verify that the power module has changed to Normal state. If the power module remains in Absent state, replace the power module.
3. Verify that the power module is operating correctly.
a. Verify that the power cord is connected to the power module securely.
<H3C>display power
2 Faulty -- -- -- -- --
If the power cord is disconnected, the power module state is Faulty. Connect the power cord securely to the power module. Then execute the display power command to verify that the power module has changed to Normal state.
b. Determine whether the power module is in high temperature. If dust accumulation on the power module causes the high temperature, remove the dust. Then remove and reinstall the power module. Execute the display power command to verify that the power module has changed to Normal state.
c. Install the power module into an empty power module slot. Then execute the display power command to verify that the power module has changed to Normal state in the new slot. If the power module remains in Faulty state, replace the power module.
Symptom
A newly installed power module fails.
Figure 6 Troubleshooting newly installed power module failure
Solution
<H3C>display power
<H3C>
<H3C>display alarm
Slot CPU Level Info
<H3C>
a. Remove and reinstall the power module to make sure the power module is installed securely. Then execute the display power command to verify that the power module has changed to Normal state.
b. Remove and install the power module into an empty power module slot. Then execute the display power command to check the power module state. If the power module remains in Absent state, go to step 4.
a. Verify that the power module is connected to the power source correctly. If it is not, connect it to the power source correctly. Then execute the display power command to verify that the power module has changed to Normal state.
b. Remove and install the power module into an empty power module slot. Then execute the display power command to check the power module state. If the power module remains in Faulty state, go to step 4.
Fan tray failure
Symptom
An operating fan tray or a newly installed fan tray fails.
Figure 7 Troubleshooting fan tray failure
Solution
1. Execute the display fan command to view the operating state of the fan tray.
<H3C>display fan
Fan Frame 1 State: Normal
Fan Frame 2 State: Normal
If the fan tray is in Absent state, go to step 2. If the fan tray is in Fault state, go to step 3.
2. Verify that the fan tray is installed securely.
Remove and reinstall the fan tray to make sure the fan tray is installed securely. Then execute the display fan command to verify that the fan tray has changed to Normal state. If the fan tray remains in Absent state, replace the fan tray.
3. Verify that the fan tray is operating correctly.
a. Identify whether the fan tray is faulty.
- Execute the display environment command to view temperature information.
If the temperature continues to rise, put your hand at the air outlet to feel if air is being expelled out of the air outlet. If no air is being expelled out of the air outlet, the fan tray is faulty.
- Execute the debug sysm fan fan-id get-speed command in probe view to view the fan speed information.
If the fan speed is less than 500 rpm, the fan tray is faulty.
b. If the fan tray is faulty, remove and reinstall the fan tray to make sure the fan tray is installed securely. Then execute the display fan command to verify that the fan tray has changed to Normal state.
c. If the fan tray remains in Fault state, replace the fan tray.
You must make sure the switching operating temperature is below 60°C (140°F) while you replace the fan tray. If a new fan tray is not readily available, power off the switch to avoid damage caused by high temperature.
This section lists the commands that you might use for troubleshooting the hardware.
Command |
debug sysm fan fan-id get-speed |
Displays fan speed information. |
dir |
Displays information about files and directories. |
display alarm |
Displays alarm information. |
Displays current configuration files and system software images. |
Displays temperature information. |
display fan |
Displays the operating states of the fan tray. |
display logbuffer |
Displays the state of the log buffer and the log information in the log buffer. |
display power |
Displays power module information. |
display process slot slot-id |
Displays process state information. |
probe |
Enters probe view. |
This section provides troubleshooting information for common system management problems.
High CPU usage on a module
Symptom
The sustained CPU usage is over 80% on a module.
Figure 8 Troubleshooting high CPU usage
Solution
1. Identify the job that has a high CPU usage. For example:
[H3C-probe] display process cpu slot 1
CPU utilization in 5 secs: 2.4%; 1 min: 2.5%; 5 mins: 2.4%
JID 5Sec 1Min 5Min Name
1 0.0% 0.0% 0.0% scmd
2 0.0% 0.0% 0.0% [kthreadd]
3 0.0% 0.0% 0.0% [migration/0]
4 0.0% 0.0% 0.0% [ksoftirqd/0]
5 0.0% 0.0% 0.0% [watchdog/0]
6 0.0% 0.0% 0.0% [migration/1]
7 0.0% 0.0% 0.0% [ksoftirqd/1]
8 0.0% 0.0% 0.0% [watchdog/1]
9 0.0% 0.0% 0.0% [migration/2]
10 0.0% 0.0% 0.0% [ksoftirqd/2]
11 0.0% 0.0% 0.0% [watchdog/2]
The output shows the average CPU usage values of jobs for the last 5 seconds, 1 minute, and 5 minutes. Typically, the average CPU usage of a job is less than 5%
2. Display the job's stack. Perform this step for a minimum of five times. In this example, the job uses the ID of 145.
[H3C-probe] follow job 145 slot 1
Attaching to process 145 ([mIPC] )
Iteration 1 of 5
Kernel stack:
[<ffffffff8045e858> ] schedule+0x738/0x1050
[<ffffffff8045f418> ] schedule_timeout+0x98/0xe0
[<ffffffff8030d084> ] ep_poll+0x4b4/0x5e0
[<ffffffffc01e7640> ] drv_mac_async_ipc_process+0x70/0x100 [system]
[<ffffffffc3f4d344> ] thread_boot+0x84/0xa0 [system]
[<ffffffff80260730> ] kthread+0x130/0x140
[<ffffffff8021aec0> ] kernel_thread_helper+0x10/0x20
Iteration 2 of 5
Kernel stack:
Iteration 3 of 5
Kernel stack:
Iteration 4 of 5
Kernel stack:
Iteration 5 of 5
Kernel stack:
3. Collect the information displayed in the previous steps and operating statistics to contact H3C Support.
High memory usage on a module
Symptom
The memory usage on a module is over 60% for more than 30 minutes.
Figure 9 Troubleshooting high memory usage
Solution
IMPORTANT: As a best practice, do not reboot the device before you contact H3C Support. You might lose critical diagnostic information if you reboot the device. |
1. Execute the display system internal kernel memory pool command multiple times to display memory usage information.
[Sysname-probe] display system internal kernel memory pool slot 1
Active Number Size Align Slab Pg/Slab ASlabs NSlabs Name
9126 9248 64 8 32 1 289 289 kmalloc-64
105 112 16328 0 2 8 54 56 kmalloc-16328
14 14 2097096 0 1 512 14 14 kmalloc-2097096
147 225 2048 8 15 8 12 15 kmalloc-2048
7108 7232 192 8 32 2 226 226 kmalloc-192
22 22 524232 0 1 128 22 22 kmalloc-524232
1288 1344 128 8 21 1 64 64 kmalloc-128
0 0 67108808 0 1 16384 0 0 kmalloc-67108808
630 651 4096 8 7 8 93 93 kmalloc-4096
68 70 131016 0 1 32 68 70 kmalloc-131016
1718 2048 8 8 64 1 31 32 kmalloc-8
1 1 16777160 0 1 4096 1 1 kmalloc-16777160
2 15 2048 0 15 8 1 1 sgpool-64
0 0 40 0 42 1 0 0 inotify_event_cache
325 330 16328 8 2 8 165 165 kmalloc_dma-16328
0 0 72 0 30 1 0 0 LFIB_IlmEntryCache
0 0 1080 0 28 8 0 0 LFIB_IlmEntryCache
0 0 1464 0 21 8 0 0 MFW_FsCache
1 20 136 0 20 1 1 1 L2VFIB_Ac_cache
0 0 240 0 25 2 0 0 CCF_JOBDESC
0 0 88 0 26 1 0 0 NS4_Aggre_TosSrcPre
0 0 128 0 21 1 0 0 IPFS_CacheHash_cachep
---- More ----
Each value line shows the memory information for a slab. The Number field shows the number of objects (memory blocks) allocated to the module. The Active field shows the number of objects used. If the percentage of the used objects keeps increasing, the slab might have memory leakage issues.
2. Display the memory call information for the slabs that might have leak problems. This example uses the kmalloc-2048 slab.
[Sysname-probe]view /sys/kernel/slab/kmalloc-2048/alloc_calls
23 kque_create+0x58/0x260 age=4262117/4404939/4692659 pid=128-372 cpus=0,2-3
2 sys_init_module+0x1bdc/0x1e50 age=4746250/4748179/4750108 pid=109-128 cpus=9,12
4 __vmalloc_area_node+0x154/0x1b0 age=4652363/4677089/4747310 pid=128-166
cpus=0-1,12
16 percpu_populate+0x3c/0x60 age=4322758/4322758/4322758 pid=128 cpus=0
21 alloc_pipe_info+0x24/0x60 age=4/3888025/4320768 pid=1-564 cpus=0-4,9,11
29 alloc_pci_dev+0x18/0x40 age=4758366/4758366/4758368 pid=1 cpus=15
2 init_dev+0x1c0/0x870 age=510128/2630142/4750157 pid=1-542 cpus=0,2
1 init_dev+0x4dc/0x870 age=510128 pid=542 cpus=2
2 kobj_map_init+0x2c/0xd0 age=4758371/4758535/4758700 pid=0-1 cpus=0,15
2 usb_alloc_dev+0x38/0x200 age=4750540/4750605/4750671 pid=1 cpus=15
1 usb_create_hcd+0x34/0x120 age=4750540 pid=1 cpus=15
16 exception_notifier_init+0x298/0x4f8 age=4750380/4750380/4750381 pid=1 cpus=15
1 drv_port_module_varialbe_init+0x24/0x80 [system] age=4651959 pid=128 cpus=0
1 DRV_VLAN_BasicFunc_Init+0x1ec/0x700 [system] age=4651871 pid=128 cpus=0
1 drv_vlan_maccash_init+0x124/0x240 [system] age=4651869 pid=128 cpus=0
1 drv_ipmc_spec_init+0x54/0x840 [system] age=4650355 pid=128 cpus=0
1 drv_evb_add_broadcast_group+0x964/0xa50 [system] age=4264182 pid=312 cpus=1
2 DRV_EVB_MAP_AddRec+0x160/0x2a0 [system] age=4264142/4264175/4264209 pid=288 cpus=9
1 drv_evi_localmac_init+0x160/0x650 [system] age=4651896 pid=128 cpus=0
1 DRV_QINQ_Init+0x278/0x890 [system] age=4650270 pid=128 cpus=0
1 DRV_QINQ_Init+0x478/0x890 [system] age=4650270 pid=128 cpus=0
1 Drv_Qacl_InitAddUdfTemplate+0x68/0xb30 [system] age=4651968 pid=128 cpus=0
1 drv_qacl_sal_rsc_init+0xc8/0x210 [system] age=4651968 pid=128 cpus=0
---- More ----
The first field of the output shows the number of objects. The remaining fields show the call information.
3. Save the information displayed in the previous steps and contact H3C Support.
Temperature alarms
Symptom
Temperature alarms occur.
Figure 10 Troubleshooting temperature alarms
Solution
1. Check the ambient temperature. If the ambient temperature is higher than 22 °C (71.6°F), lower the ambient temperature by adding air conditioners or taking other heat dissipation measures.
2. Check the device temperature. If the device temperature is higher than the high-temperature warning threshold, use the display fan command to verify that the fan tray is operating correctly. If the status field displays Fault, see H3C S12500G-AF Switch Series Installation Guide to resolve the issue.
3. Check whether the air filters are clean. If they are not, clean them.
4. Use the temperature-limit command to adjust the temperature alarm thresholds for the module.
5. Use the display environment command to identify whether the temperature alarm thresholds have been adjusted successfully. If the thresholds have not been adjusted, replace the module.
This section lists the commands that you might use for troubleshooting system management.
Command |
Remarks |
display cpu-usage |
Displays the current CPU usage statistics. |
Displays temperature information, including the current temperature and the temperature alarm thresholds. |
display fan |
Displays the operating status of all fans on the device. |
display memory |
Displays memory usage statistics. |
display process cpu |
Displays the CPU usage statistics for jobs. This command is available in probe view. |
display system internal kernel memory pool |
Displays memory block usage statistics. This command is available in probe view. |
follow job job-id |
Displays the stack of a job. This command is available in probe view. |
temperature-limit |
Sets temperature alarm thresholds. |
view /sys/kernel/slab/<modulename>/alloc_calls |
Displays the number of allocated memory blocks and the call information. |
This section provides troubleshooting information for common port problems.
Symptom
A 10-Gigabit SFP+ fiber port cannot come up.
Figure 11 Troubleshooting link up failure on a port
Solution
1. Verify that the speed and duplex mode of the local port match the speed and duplex mode of the peer port:
a. Execute the display interface brief command to examine whether the speed and duplex mode of the port match the speed and duplex mode of the peer port.
b. If they do not match, use the speed command and the duplex command to set the speed and duplex mode for the port.
2. Verify that the speed and duplex mode of the port match the speed and duplex mode of the transceiver module:
a. Execute the display interface brief command to examine whether the speed and duplex mode of the port match the speed and duplex mode of the transceiver module.
3. Verify that the local and peer ports are operating correctly:
a. Use a 10-GE SFP+ cable to directly connect the local port and another 10-GE SFP+ of the same interface module. A 10-GE SFP+ cable is suitable for short connections.
b. If the local port can come up, replace the peer port with a new one to verify that the peer port is operating correctly.
c. If the local port cannot come up, replace the local port with a new one to verify that the local port is operating correctly.
4. Verify that the transceiver module is operating correctly:
a. Execute the display transceiver alarm interface command to examine the alarms present on the transceiver module.
- The device displays None if no error occurs.
- The device displays alarms if the transceiver module fails or the type of the transceiver module does not match the port type.
b. Use an optical power meter to verify that the Tx power and Rx power of the transceiver module are stable and are within the correct range.
c. Execute the display transceiver interface command to verify that the wavelength and transmission distance of the local transceiver module are consistent with the wavelength and transmission distance of the peer transceiver module.
d. If the transceiver module is not operating correctly, replace it with a new H3C transceiver module that matches the fiber port.
For more information about transceiver modules, see related installation guides.
5. Verify that the fiber matches the transceiver module. If they do not match, replace the fiber with a new one that matches the transceiver module.
Symptom
A 40-Gigabit QSFP+ fiber port cannot come up.
Figure 12 Troubleshooting link up failure on a port
Solution
1. Verify that the local and peer ports are operating correctly:
a. Use a QSFP+ cable to directly connect the local port and another 40-GE QSFP+ fiber port of the same interface module. A QSFP+ cable is suitable for short connections.
b. If the local port can come up, replace the peer port with a new one (on an interface module of the same type, if possible) to verify that the peer port is operating correctly.
c. If the local port cannot come up, replace the local port with a new one (on an interface module of the same type, if possible) to verify that the local port is operating correctly.
2. Verify that the transceiver module is operating correctly:
IMPORTANT: If a QSFP+ to SFP+ cable is used, use an optical attenuator to make sure the Tx power of the QSFP+ module stays below the Rx power of the SFP+ module. |
3. Verify that the fiber matches the transceiver module. If they do not match, replace the fiber with a new one that matches the transceiver module.
Symptom
A 100-GE QSFP28 fiber port fails to come up.
Figure 13 Troubleshooting link up failure on a port
Solution
Use a QSFP28 cable to connect the local port directly to another 100-GE QSFP28 fiber port on the same card.
¡ If the local port can come up, replace the peer port with a new one (on a card of the same type, if possible).
¡ If the local port cannot come up, replace the local port with a new one (on a card of the same type, if possible).
2. Verify that the transceiver module and cable are operating correctly:
a. Execute the display transceiver alarm interface command to check for alarms on the transceiver module.
- The device displays None if no error has occurred.
- The device displays alarms if the transceiver module has failed or if the type of the transceiver module does not match the port type.
c. Execute the display transceiver interface command to verify that the local transceiver module has the same wavelength and transmission distance as the peer transceiver module.
d. If the transceiver module or cable is not operating correctly, replace it with a new H3C transceiver module or cable that matches the fiber port.
For more information about transceiver modules and cables, see the installation guide for the switch.
Symptom
When you use the display logbuffer command to view the system logs, the following reports about non-H3C transceiver modules appear in the system logs:
%Oct 17 21:37:24:812 2011 nl-denbo-ro01 OPTMOD/4/PHONY_MODULE:
-Chassis=2-Slot=3;
Ten-GigabitEthernet2/3/0/5: This transceiver is NOT sold by H3C. H3C therefore shall NOT guarantee the normal function of the device or assume the maintenance responsibility thereof!
Figure 14 Troubleshooting non-H3C transceiver module reports
Solution
1. Identify the vendor of the transceiver module plugged into the port:
a. Use the display transceiver interface command to display the transceiver information.
If the Vendor Name field is H3C, the transceiver module might be an H3C transceiver module without an electrical label or a non-H3C transceiver module.
b. If the Vendor Name field is not H3C, you can determine that this is not an H3C transceiver module. Replace it with an H3C transceiver module.
2. Contact H3C Support to determine whether the transceiver module vendor is H3C:
a. Use the debug port optical-eeprom command in probe view to collect the transceiver module information. Send the bar code of the transceiver module to H3C Support to identify the vendor of the transceiver module.
b. If you determine that the transceiver module vendor is not H3C, replace it with an H3C transceiver module.
3. If the transceiver module vendor is identified as H3C but the issue persists, contact H3C Support.
Symptom
When you use the display transceiver diagnosis interface command to display the diagnostic information of a transceiver module, the system displays a message that the transceiver module does not support digital diagnosis.
<Sysname> display transceiver diagnosis interface ten-gigabitethernet 1/0/1
Error: The transceiver does not support this function.
Figure 15 Troubleshooting the failure to support digital diagnosis on a transceiver module
Solution
1. Verify that the vendor of the transceiver module is H3C:
b. Determine whether the value of the Vendor Name field is H3C.
c. Use the display transceiver manuinfo interface command to collect the transceiver module information. Send the bar code of the transceiver module to H3C Support to verify that the vendor of the transceiver module is H3C.
2. Verify that the transceiver module supports digital diagnosis:
a. Use the display transceiver interface command to display transceiver module information.
b. Determine whether the value of the Digital Diagnostic Monitoring field is Yes.
c. Consult H3C Support about whether the transceiver module supports digital diagnosis.
3. If the transceiver module vendor is identified as H3C and the transceiver module supports digital diagnosis but the issue persists, contact H3C Support.
Symptom
Figure 16 Troubleshooting error frames (for example, CRC errors) on a port
Solution
1. (Optional.) Use the reset counter interface command in user view to clear the packet statistics of the port.
This command resets the values of each statistical field to 0, so that you can view the statistics changes more clearly.
2. If the port is a fiber port, verify that the optical power of the transceiver module is operating correctly:
a. Use the display transceiver diagnosis interface command in probe view to view the present measured values of the digital diagnosis parameters for the transceiver module.
b. If the optical power of the transceiver module is not within the correct range, replace the transceiver module with a transceiver module of the same model that is operating correctly.
[Sysname-probe] display transceiver diagnosis interface ten-gigabitethernet 1/0/1
Ten-GigabitEthernet1/0/1 transceiver diagnostic information:
[module] Temp.(°C)
1stTX 2ndTX 1stRX 2ndRX
N/A N/A N/A N/A
Voltage(V)
3.3VTX 12VTX 3.3VRX 12VRX
3.29 N/A 3.40 N/A
[channel] TX Bias(mA) RX power(dBm) TX power(dBm)
1 6.09 0.91 -0.77
2 5.95 1.09 -0.16
3 6.05 1.58 -0.17
4 5.85 1.58 -0.14
5 6.07 2.23 -0.30
6 5.72 2.85 -0.47
7 6.11 3.01 -0.08
8 5.50 1.17 -0.02
9 5.89 -0.85 -0.17
10 5.94 -40.00 0.29
11 6.05 -40.00 0.18
12 5.78 -40.00 -0.30
Alarm thresholds:
[module] Temp.(°C) Voltage(V) Bias(mA) RX power(dBM) TX power(dBM)
High 0 3.63 10.00 1.58 5.44
Low 0 2.97 0.50 3.13 -11.61
3. Verify that the port configurations are correct:
a. Execute the display interface brief command.
b. Determine whether the speed and duplex mode of the port match the speed and duplex mode of the peer port.
c. If they do not match, use the speed command and the duplex command to set the speed and duplex mode for the port.
4. Verify that the port and the link medium are operating correctly:
a. Plug the link medium into another port that is operating correctly, and determine whether the same problem occurs.
b. If the problem still occurs, verify that the following items are operating correctly:
- Intermediate links and devices, including optical-to-electrical converters, cable terminal racks, and transmission devices.
- Transmission medium, including network cables, optical fibers, and transceiver modules.
c. Examine the port:
- If the port is a copper port, directly connect the port to a PC.
- If the port is a fiber port, replace the transceiver module plugged into the port.
5. Determine whether the port has received a large amount of flow control frames:
a. Use the display interface command to view the number of pause frames.
If the number of pause frames is accumulating, you can determine that the port has sent or received a large amount of flow control frames.
b. Verify that the incoming traffic and outgoing traffic have not exceeded the maximum traffic processing capability of the local device and the peer device.
Failure to receive packets
Symptom
A port is up, but it cannot receive packets.
Figure 17 Troubleshooting the failure to receive packets
Solution
1. Examine the packet statistics of the port:
a. (Optional.) Use the reset counter interface command in user view to clear the packet statistics of the port.
b. Determine whether the ports at both ends are always up, and use the display interface command to determine whether the number of incoming packets is accumulating. At the same time, examine the outgoing packet statistics of the peer port.
c. View the values of the error packet fields and determine whether the number of error packets is accumulating.
2. Verify that the port configurations do not affect packet receiving:
a. Use the display interface brief command to verify that the port configurations are correct.
The port configurations include the duplex mode, speed, port type, and VLAN configurations of the ports at both ends of the link.
b. If configuration errors exist, modify the port configurations. If the number of incoming packets in the output from the display interface command is accumulating, you can determine that the port can receive packets.
c. If the port fails to receive packets, use the shutdown command and then the undo shutdown command to re-enable the port. If the number of incoming packets in the output from the display interface command is accumulating, you can determine that the port can receive packets.
d. If the port is configured with STP, use the display stp brief command to verify that the port is not in the discarding state.
e. If a port is set to the discarding state by STP, examine and modify the STP-related configurations to resolve the issue.
As a best practice, configure the port as an edge port or disable STP on the port if it is directly connected to a terminal.
f. If the port is assigned to an aggregation group, use the display link-aggregation summary command to verify that the status of the port is Selected.
g. If the status of the port is Unselected, the port cannot send or receive data packets.
h. Determine the reasons why the port becomes Unselected, for example, the attribute configurations of the port are different from the reference port. Modify the attribute configurations of the port to make the port become Selected.
3. Verify that the port and the link medium are operating correctly:
Failure to send packets
Symptom
A port is up, but it cannot send packets.
Figure 18 Troubleshooting failure to send packets
Solution
1. Verify that the ports at both ends are up.
2. Examine the packet statistics of the port:
This command resets all packet counters to 0, so that you can view the statistics changes more clearly.
b. Use the display interface command to verify that the number of outgoing packets is accumulating.
c. Verify that the number of error frames is not accumulating.
If the number of error frames is accumulating, remove the errors. For more information, see "Error frames (for example, CRC errors) on a port."
3. Verify that the port configurations do not affect packet sending:
The port configurations include the duplex mode, speed, port type, and VLAN configurations of the ports at both ends of the link. If configuration errors exist, modify the port configurations. If the port fails to send packets, use the shutdown command and then the undo shutdown command to re-enable the port.
b. If the port is configured with the spanning tree feature, use the display stp brief command to verify that the port is not in the discarding state.
If the port is set to the discarding state by the spanning tree feature, examine and modify the spanning tree feature configurations to resolve the issue.
H3C recommends that you configure the port as an edge port or disable the spanning tree feature on the port if it is directly connected to a terminal.
c. If the port is in an aggregation group, use the display link-aggregation summary command to verify that the status of the port is Selected.
If the status of the port is Unselected, the port cannot send or receive data packets. Determine the reasons why the port becomes Unselected, for example, the attribute configurations of the port are different from the reference port. Modify the attribute configurations of the port to make the port become Selected.
5. If the issue persists, contact H3C Support.
This section lists the commands that you might use for troubleshooting ports.
Command |
display diagnostic-information |
Displays or saves operating information for features and hardware modules. |
display interface |
Displays Ethernet interface information. |
Displays brief interface information. |
display link-aggregation summary |
Displays brief information about all aggregation groups. |
display logbuffer |
display stp brief |
Displays brief information about the spanning tree status and statistics. |
display transceiver alarm interface |
Displays the alarms present on the transceiver module. |
display transceiver diagnosis |
Displays the current values of the digital diagnosis parameters on the transceiver module. |
display transceiver interface |
Displays the key parameters of the transceiver module. |
Troubleshooting IRF
This section provides troubleshooting information for common IRF issues.
IRF fabric setup failure
Symptom
A chassis cannot be added to an IRF fabric.
Figure 19 Troubleshooting IRF fabric setup failure
Solution
1. Verify that the number of member chassis in the IRF fabric does not exceed the upper limit.
The upper limit varies by software version. Execute the display version command to identify the software version of the IRF fabric. If the member chassis upper limit is reached for the software version, you cannot add new chassis to the IRF fabric.
For more information about the upper limit, see H3C S12500G-AF Switch Series Virtual Technologies Configuration Guide for the software version.
2. Verify that the chassis is the same model as other member chassis.
An S12500G-AF switch can form an IRF fabric only with devices of the same model.
3. Verify that the chassis is operating in IRF mode:
a. Execute the display interface brief command to verify that the physical port numbers on the chassis have changed from three segments to four segments. In IRF mode, the member ID is added to physical port numbers as the first segment (for example, Ten-GigabitEthernet 1/4/0/1).
b. If the chassis is not operating in IRF mode, execute the chassis convert mode irf command to change the operating mode to IRF.
4. Verify that the member ID of the chassis does not conflict with any member chassis in the IRF fabric:
a. Execute the display irf command to view member IDs.
b. Verify that the member ID of the chassis is unique and meets all other member ID requirements (if any). For information about the member ID requirements, see IRF configuration in H3C S12500G-AF Switch Series Virtual Technologies Configuration Guide for the software version.
c. If the member ID of the chassis does not meet the member ID requirements, use the irf member renumber command to assign a new member ID to the chassis.
5. Verify that the physical IRF links are connected correctly:
IMPORTANT: When you connect two neighboring IRF members, you must connect the physical interfaces of IRF-port 1 on one member to the physical interfaces of IRF-port 2 on the other. |
a. Execute the display irf configuration command on each member chassis, and check the IRF-Port1 and IRF-Port2 fields for IRF port bindings.
b. Verify that the physical IRF connections are consistent with the IRF port bindings.
c. If there are inconsistencies, reconfigure the IRF port bindings or reconnect the IRF physical interfaces.
6. Verify that all IRF links are up:
a. Execute the display irf topology command, and then check the Link field.
b. If the Link field for an IRF port displays DOWN, execute the display interface command.
c. Check the current state field for each physical interface bound to the IRF port. If the IRF port is down when it contains a minimum of one up link, verify that the MPUs of the chassis are operating correctly. If all IRF physical interfaces in the IRF port are down, handle the issue as follows:
- If the current state field displays DOWN ( Administratively ), execute the undo shutdown command to bring up the interfaces.
- If the current state field displays DOWN, verify that the transceiver modules and fibers or DAC cables used for IRF connection are operating correctly.
NOTE: The switch might support different transceiver modules or DAC cables depending on the software version and interface module model. For more information, see the latest installation guide and the configuration guides of the H3C S12500G-AF switch series for the software version in use. |
7. Verify that the member chassis is running the same software version as the IRF fabric:
a. Execute the display version command to identify the software version.
b. Upgrade the MPUs in the chassis to use the same software version as the IRF fabric.
NOTE: Typically, the irf auto-update enable command can automatically synchronize a member chassis with the software version of the master chassis. However, the synchronization might fail when the gap between the software versions is large. |
8. Verify that the chassis has the same settings as other IRF member chassis for features that require configuration consistency across the IRF fabric.
For example, all member chassis must have the same settings for the ecmp mode enhanced command to join the same IRF fabric.
Features that require fabric-wide configuration consistency vary by software version. For more information about these features, see H3C S12500G-AF Switch Series Virtual Technologies Configuration Guide for the software version.
9. Verify that the chassis has a unique bridge MAC address:
a. Execute the display interface vlan-interface 1 command, and then check the Hardware Address field.
[Sysname] display interface vlan-interface 1
Vlan-interface1 current state: UP
Description: Vlan-interface1 Interface
The Maximum Transmit Unit is 1500
Internet protocol processing : disabled
IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 0023-8912-3d07
IPv6 Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 0023-8912-3d07
b. If the chassis has the same bridge MAC address as the IRF fabric, remove the bridge MAC conflict.
10. If the issue persists, contact H3C Support.
IRF split
Symptom
An IRF fabric splits.
Figure 20 Troubleshooting IRF split
Solution
1. Verify that the IRF physical interfaces are operating correctly:
a. Execute the display trapbuffer command or view system logs to check for physical IRF link down events that occurred around the split time.
b. If the split followed an IRF link down event, execute the display interface command to check port statistics for CRC errors.
c. If transceiver modules and fibers are used, execute the display transceiver diagnosis command. Make sure the transmit and receive power has not exceeded the power specifications of the fiber module.
d. Remove hardware issues that might cause recurring IRF split events:
e. Execute the display version command to identify the uptime of MPUs and interface modules that have IRF links.
f. Compare the uptime of MPUs and interface modules to determine whether a member chassis or interface module had rebooted before the IRF split.
g. If the IRF split is caused by a member chassis or interface module reboot, use the methods described in "MPU reboot failure" and "Service module reboot failure" to resolve the issue.
2. If the issue persists, contact H3C Support.
BFD MAD failure
Symptom
BFD MAD fails to detect an IRF split event. Two IRF fabrics are operating with the same Layer 3 settings, including the same IP address.
Figure 21 Troubleshooting BFD MAD failure
Solution
1. Verify that BFD MAD link connections are correct:
¡ If you do not use an intermediate device, verify that each pair of member chassis has a dedicated BFD MAD link.
¡ If you use an intermediate device, verify that each member chassis has a dedicated BFD MAD link with the intermediate device.
2. Verify that all physical ports used for BFD MAD are up:
a. Execute the display interface command.
b. Check the current state field in the command output:
- If the field displays DOWN ( Administratively ) for a port, execute the undo shutdown command to bring up the port.
- If the field displays DOWN for a port, check the physical link for a link failure.
3. Verify that the BFD MAD VLAN interface is configured correctly:
a. Execute the display mad verbose command.
b. Check the MAD BFD enabled interface field to verify that VLAN-interface 1 is not used for BFD MAD.
c. If VLAN-interface 1 is used for BFD MAD, disable BFD MAD on VLAN-interface 1, and then enable BFD MAD on another VLAN interface.
d. Verify that the BFD MAD-enabled VLAN interface does not have any other features, including VPN.
e. Execute the display interface command to verify that the interface does not have the following IP addresses:
- IP address assigned by using the ip address command.
- VRRP virtual IP address.
4. Verify that the BFD MAD VLAN and physical ports in the VLAN are configured correctly:
a. Execute the display vlan command to verify the following items:
- The BFD VLAN contains all physical ports used for BFD MAD.
- The BFD VLAN does not contain physical ports that are not used for BFD MAD.
If an intermediate device is used, you must also perform this step on the intermediate device.
b. Execute the display interface command to verify that the physical ports in the BFD VLAN are not configured with any features.
For BFD MAD to operate correctly, you must disable all features on the physical ports in the BFD MAD VLAN, including the spanning tree feature, ARP, and LACP.
5. Verify that the MAD IP addresses are correct:
b. Check the mad ip address field to verify the following items:
- Each member chassis has a MAD IP address.
- All MAD IP addresses are on the same subnet.
- The MAD IP addresses are not addresses being used on the IRF fabric.
6. If the network has multiple IRF fabrics, execute the display mad verbose command to verify that their BFD MAD VLANs are different.
7. Verify that the physical ports in the BFD MAD VLAN are always up:
a. Execute the display trapbuffer command or use system logs to check for BFD MAD port-down events that occurred around the split time.
b. Identify the cause of the events, and remove the issue.
8. If the issue persists, contact H3C Support.
LACP MAD failure
Symptom
LACP MAD fails to detect an IRF split event. Two IRF fabrics are operating with the same Layer 3 settings, including the same IP address.
Figure 22 Troubleshooting LACP MAD failure
Solution
1. Verify that the intermediate device supports extended LACPDUs for MAD.
If the intermediate device does not support extended LACPDUs for MAD, replace the intermediate device, or use BFD MAD for split detection.
2. Verify that each member chassis has a link in the link aggregation with the intermediate device.
3. Verify that the link aggregation is operating in dynamic mode.
To enable dynamic aggregation mode, use the link-aggregation mode dynamic command.
4. Verify that the aggregate interface and its member ports are up:
b. Check the current state field of the aggregate interface:
- If the field displays DOWN ( Administratively ), execute the undo shutdown command to bring up the interface.
- If the field displays DOWN, check the state of all its physical ports.
An aggregate interface goes down only if all its physical ports are down.
c. Check the current state field of each member port:
- If the field displays DOWN ( Administratively ), execute the undo shutdown command to bring up the port.
- If the field displays DOWN, check the physical link of the port for a link failure.
5. If the intermediate device is also an IRF fabric, verify that the IRF domain IDs of the two IRF fabrics are unique:
CAUTION: he IRF member devices send extended LACPDUs with TLVs that convey the domain ID and the active ID of the IRF fabric. To avoid split detection failure, make sure the IRF fabric has a unique domain ID. |
a. Execute the display irf command to identify the domain ID of each IRF fabric.
b. If the IRF fabrics use the same domain ID, execute the irf domain command to change the domain ID on one IRF fabric.
6. Verify that the physical ports in the link aggregation are always up:
a. Execute the display trapbuffer command or use system logs to check for port-down events around the split time.
b. Identify the event cause and remove the issue.
7. If the issue persists, contact H3C Support.
This section lists the commands that you might use for troubleshooting IRF:
Command |
Displays or saves the operating statistics for multiple feature modules. |
display interface |
Displays interface information. |
display interface brief |
display irf |
Displays IRF fabric information, including the member ID, role, priority, bridge MAC address, and description of each IRF member. |
display irf configuration |
Displays the IRF configuration on each member chassis. |
display irf topology |
Displays the IRF topology. |
display mad verbose |
Displays detailed MAD configuration. |
Displays the present measured values of the digital diagnosis parameters for transceiver modules. |
display trapbuffer |
Displays trap buffer information and buffered notifications. |
display version |
Displays system version information. |
display vlan |
Displays VLAN information. |
Troubleshooting QoS and ACL
This section provides troubleshooting information for common QoS and ACL problems.
ACL application failure for unsupported ACL rules
Symptom
The system fails to apply a packet filter or an ACL-based QoS policy to the hardware. It displays an error message that an unsupported rule exists in the ACL. The following is a sample error message:
Figure 23 Troubleshooting ACL application failure
Solution
1. Delete the unsupported rule and apply the packet filter or QoS policy again.
If the rule is indispensable and cannot be deleted, go to step 2.
2. If the issue persists, collect device information and contact H3C Support.
ACL application failure for insufficient resources
Symptom
The system fails to apply a packet filter or an ACL-based QoS policy to the hardware. It displays an error message that the hardware resources are not sufficient. The following are sample error messages:
Error: Slot=2 Fail to apply or refresh packet filter policy 3001 rule 25 on interface Vlan-interface6 due to lack of resources.
Warning: Classifier-behavior test in policy test applied on vlan 4079 failed in slot 2.
Reason: Not enough hardware resource.
Figure 24 Troubleshooting ACL application failure
Solution
Insufficient hardware resources might be insufficient Counter, Meter, or ACL resources.
1. Check the ACL, Counter, and Meter resource usage for insufficiency.
Execute the display qos-acl resource command to display the resource usage. If the number of ACLs to be applied is higher than the value of the Remaining field, resources are insufficient. If the ACLs are to be applied globally, check remaining resource usage on all cards.
[Sysname] display qos-acl resource
Interfaces: XGE2/1/0/1 to XGE2/1/0/21, XGE2/1/0/22
XGE2/1/0/23 to XGE2/1/0/24
Type Total Reserved Configured Remaining Usage
VFP ACL 1024 768 0 256 75%
IFP ACL 2048 1792 1 255 87%
IFP Meter 1024 896 0 128 87%
IFP Counter 1024 896 0 128 87%
EFP ACL 1024 0 0 1024 0%
EFP Meter 512 0 0 512 0%
EFP Counter 512 0 0 512 0%
Interfaces: XGE2/1/0/25 to XGE2/1/0/48
IFP ACL 2048 1536 1 511 75%
IFP Meter 1024 768 0 256 75%
IFP Counter 1024 768 0 256 75%
¡ IFP—Resource usage for inbound traffic.
¡ EFP—Resource usage for outbound traffic.
2. Delete unnecessary ACLs to release resources if the failure is caused by ACL resource insufficiency. Delete unnecessary ACLs that use Meter or Counter resources if the failure is caused by Meter or Counter resource insufficiency.
If you cannot release enough resources, go to step 4.
If the ACL resources are sufficient, the reason might be that the ACL conflicts with a specific algorithm in the ASIC chip. In this case, go to step 4.
3. Apply the packet filter or QoS policy again.
4. If the issue persists, collect device information and contact H3C Support.
ACL application failure without an error message
Symptom
Figure 25 Troubleshooting ACL application failure
Solution
1. Check the ACLs used by QoS policies and packet filters for overlapping rules:
a. Use the following commands to display ACLs that are used by QoS policies and packet filters:
- display packet-filter
- display qos policy user-defined
- display traffic classifier user-defined
b. Execute the display acl command to check for overlapping rules in the ACLs.
For example, the following sample output shows that rule 0 in ACL 3100 and rule 0 in ACL 3009 can both match traffic sourced from 2.2.2.1.
ACL number 3100
rule 0 permit ip source 2.2.2.2 0.0.255.255
ACL number 3009
rule 0 permit ip source 2.2.2.2 0.0.0.255
2. Check the filters and policies that use overlapping ACLs for a behavior conflict.
If two behaviors conflict, the device performs the behavior that has higher priority, as shown in Table 3.
Table 3 Rules for selecting a higher priority behavior from conflicting behaviors
Conflicting behaviors |
Higher priority behavior |
· redirect · filter permit |
redirect |
· redirect · filter deny |
filter deny |
· filter permit · filter deny |
The behavior configured first. |
3. Revise ACLs, packet filters, or QoS policies to remove the behavior conflict.
This section lists the commands that you might use for troubleshooting QoS and ACLs.
Command |
display acl |
Displays configuration and match statistics for ACLs. |
Displays operating statistics for multiple feature modules in the system. |
display packet-filter |
Displays ACL application information for packet filtering. |
display qos-acl resource |
Displays ACL resource usage. |
display qos policy user-defined |
Displays user-defined QoS policies. |
display traffic classifier user-defined |
Displays user-defined traffic classes. |
Troubleshooting MDC
This section provides troubleshooting information for common MDC problems.
Service module assignment failure
Symptom
The location command fails to assign a service module to an MDC.
Figure 26 Troubleshooting service module assignment failure
Solution
Typical service module assignment failure reasons include:
· The available hardware resources are insufficient.
· The service module belongs to another MDC. A service module can belong to only one MDC. Before you assign a service module to a non-default MDC, you must remove the existing assignment of the service module.
1. Display the CPU, disk space, and memory space resources for MDCs.
[Sysname]display mdc resource
Memory usage:
Slot 0 CPU 0:
Used 788.4MB, Free 15164.2MB, Total 15952.6MB
ID Name Quota(MB) Used(MB) Available(MB)
1 Admin 15952.6 788.4 15164.2
Slot 3 CPU 0:
Used 143.0MB, Free 7757.7MB, Total 7900.6MB
1 Admin 7900.6 143.0 7757.7
CPU usage:
Slot 0 CPU 0:
ID Name Weight Usage(%)
1 Admin 10 0
Slot 3 CPU 0:
1 Admin 10 10
2. Display MDC configuration.
[Sysname] display current-configuration configuration mdc
mdc Admin id 1
mdc mdcA id 2
mdc start
Return
The output shows that all service modules belongs to the default MDC.
3. Reclaim the service module in slot 3 of chassis 1 from the default MDC.
[Sysname] mdc Admin
[Sysname-mdc-1-Admin] undo location chassis 1 slot 3
The configuration associated with the specified slot of MDC will be lost. Continue? [Y/N] :y
4. Verify that the service module does not belong to the default MDC.
[Sysname-mdc-1-Admin] display this
mdc Admin id 1
Return
5. Assign the service module to the mdcB.
[Sysname-mdc-2-mdcA] mdc mdcB
[Sysname-mdc-3-mdcB] location chassis 1 slot 3
6. Verify that the service module belongs to mdcB.
[Sysname-mdc-3-mdcB] display this
mdc mdcB id 3
mdc start
Return
Interface assignment failure
Symptom
Interfaces on a service module fail to be assigned to a non-default MDC, or the interfaces are not available in MDC view.
Figure 27 Troubleshooting interface assignment failure
Solution
To successfully assign interfaces to a non-default MDC, make sure the following requirements are met:
· A service module on the device can belong to only one MDC.
· All interfaces on a service module must be assigned to the same MDC by using a single command.
· Before assigning a service module to an MDC, assign all interfaces on the service module to the MDC by using a single allocate command.
To reclaim a service module from the default MDC, only the undo location command is required. You do not need to use the undo allocate command.
1. Display the interfaces of MDCs.
[Sysname] display mdc interface
MDC Admin's interface(s):
M-GigabitEthernet1/0/0/0
MDC mdcA's interface(s):
M-GigabitEthernet1/0/0/0 Ten-GigabitEthernet1/3/0/1
Ten-GigabitEthernet1/3/0/2 Ten-GigabitEthernet1/3/0/3
Ten-GigabitEthernet1/3/0/4 Ten-GigabitEthernet1/3/0/5
Ten-GigabitEthernet1/3/0/6 Ten-GigabitEthernet1/3/0/7
Ten-GigabitEthernet1/3/0/8 Ten-GigabitEthernet1/3/0/9
Ten-GigabitEthernet1/3/0/10 Ten-GigabitEthernet1/3/0/11
Ten-GigabitEthernet1/3/0/12 Ten-GigabitEthernet1/3/0/13
Ten-GigabitEthernet1/3/0/14 Ten-GigabitEthernet1/3/0/15
Ten-GigabitEthernet1/3/0/16 Ten-GigabitEthernet1/3/0/17
Ten-GigabitEthernet1/3/0/18 Ten-GigabitEthernet1/3/0/19
Ten-GigabitEthernet1/3/0/20 Ten-GigabitEthernet1/3/0/21
Ten-GigabitEthernet1/3/0/22 Ten-GigabitEthernet1/3/0/23
Ten-GigabitEthernet1/3/0/24 Ten-GigabitEthernet1/3/0/25
Ten-GigabitEthernet1/3/0/26 Ten-GigabitEthernet1/3/0/27
Ten-GigabitEthernet1/3/0/28 Ten-GigabitEthernet1/3/0/29
Ten-GigabitEthernet1/3/0/30 Ten-GigabitEthernet1/3/0/31
Ten-GigabitEthernet1/3/0/32 Ten-GigabitEthernet1/3/0/33
Ten-GigabitEthernet1/3/0/34 Ten-GigabitEthernet1/3/0/35
Ten-GigabitEthernet1/3/0/36 Ten-GigabitEthernet1/3/0/37
Ten-GigabitEthernet1/3/0/38 Ten-GigabitEthernet1/3/0/39
Ten-GigabitEthernet1/3/0/40 Ten-GigabitEthernet1/3/0/41
Ten-GigabitEthernet1/3/0/42 Ten-GigabitEthernet1/3/0/43
Ten-GigabitEthernet1/3/0/44 Ten-GigabitEthernet1/3/0/45
Ten-GigabitEthernet1/3/0/46 Ten-GigabitEthernet1/3/0/47
Ten-GigabitEthernet1/3/0/48
MDC mdcB's interface(s):
[Sysname-mdc-2-mdcA] display this
mdc mdcA id 2
mdc start
allocate interface Ten-GigabitEthernet1/3/0/1 to Ten-GigabitEthernet1/3/0/48
Return
The output shows that the service module in slot 3 of member device 1 and its interfaces belong to mdcA.
2. Reclaim the service module in slot 3 on member device 1 and its interfaces from mdcA.
[Sysname-mdc-2-mdcA] undo allocate interface Ten-GigabitEthernet 1/3/0/1 to Ten-GigabitEthernet 1/3/0/48
Configuration of the interfaces will be lost. Continue? [Y/N] :y
[Sysname-mdc-2-mdcA] undo location chassis 1 slot 3
mdc mdcA id 2
mdc start
Return
3. Assign the service module in slot 3 on member device 1 and its interface to mdcB.
[Sysname]mdc mdcB
[Sysname-mdc-3-mdcB] allocate interface Ten-GigabitEthernet 1/3/0/1 to Ten-GigabitEthernet 1/3/0/48
[Sysname-mdc-3-mdcB] quit
mdc mdcB id 3
mdc start
return
This section lists the commands that you might use for troubleshooting MDC.
Command |
allocate interface |
Assigns physical interfaces to an MDC. |
display mdc interface |
Displays the interfaces of MDCs. |
display mdc resource |
Displays CPU, disk space, and memory space usage of MDCs. |
location |
Assigns a service module to an MDC. |
Troubleshooting DRNI
DR system setup failure
Symptom
Two DRNI devices configured cannot form a DR system.
Figure 28 Flowchart for troubleshooting DR system setup failure
Solution
1. Verify that the DR member devices use unique DR system numbers:
a. Execute the display drni system command to identify the DR system numbers of the DR member devices.
b. If the DR member devices use the same DR system number, use the drni system-number command to change the DR system number of one DR member device.
2. Verify that the DR member devices use the same DR system MAC address:
a. Execute the display drni system command to identify the DR system MAC addresses of the DR member devices.
b. If the DR member devices use different DR system MAC addresses, use the drni system-mac command to change the DR system MAC addresses of the DR member devices to the same value.
3. Verify that the DR member devices use the same DR system priority:
a. Execute the display drni system command to identify the DR system priorities of the DR member devices.
b. If the DR member devices use different DR system priorities, use the drni system-priority command to change the DR system priorities of the DR member devices to the same value.
4. Verify that an aggregate interface has been configured as the IPP:
a. Execute the display drni verbose command to identify IPP information.
b. If an IPP is not configured, use the intra-portal-port command to configure an available aggregate interface as the IPP.
5. Verify that the IPP is up:
a. Execute the display interface command to examine the state of the interface that acts as the IPP.
b. If the IPP is in DOWN (Administratively) state, use the undo shutdown command to bring it up. If the IPP is in DOWN state, examine the member ports of the IPP and make sure the following requirements are met:
- Their optical fibers or copper cables are correctly installed.
- Their transceiver modules are operating correctly.
NOTE: The transceiver modules and optical fibers supported for IPL setup vary by software version and hardware. To obtain DRNI hardware compatibility information, see the configuration guides for the DR member devices. |
DR system split
Symptom
The DR system splits unexpectedly.
Figure 29 Flowchart for troubleshooting DR system split
Solution
To resolve the issue:
1. Verify that the IPP is operating correctly:
a. Execute the display interface command to examine the IPP for faults such as CRC errors.
b. If the physical ports at the two ends of the IPL are SFP+ or QSFP+ ports that use optical fibers and transceiver modules for physical connections, execute the display transceiver diagnosis command. Verify that the receive power and transmit power of each port do not exceed the upper limits of the transceiver module.
2. Examine each card that contains IPP physical member ports for a reboot event:
a. Execute the display version command to identify the uptime of the card.
b. If the card has rebooted, resolve the issue as described in "Service module reboot failure."
3. Examine each DR member device for a reboot event:
a. Execute the display version command to identify the uptime of the MPUs on the device.
b. If one of the DR member devices has rebooted, resolve the issue as described in "Troubleshooting hardware."
Member ports of a DR interface cannot be selected
Solution
Some or all member ports of a DR interface cannot be selected.
Troubleshooting flowchart
Figure 30 Flowchart for troubleshooting member port selection failure on a DR interface
Solution
1. Verify that the member ports of the DR interface are operating correctly:
a. Execute the display interface command to identify the states of the member ports.
b. If the member ports are down, locate the cause and resolve the issue.
2. Verify that the DR system has not split:
a. Execute the display drni verbose command to identify the state of the DR system.
b. If the DR system has split, resolve the issue as described in "DR system split."
3. Verify that the DR member devices have configuration consistency:
a. Execute the display drni consistency command to check for inconsistent type-1 configuration.
b. If type-1 configuration inconsistency exists, modify the inconsistent settings.
This section lists the commands that you might use for troubleshooting DRNI.
Command |
display drni consistency |
Displays information about the configuration consistency check done by DRNI. |
display drni system |
Displays the DR system settings. |
display drni verbose |
Displays detailed information about the IPP and DR interfaces. |
display interface |
display version |
