Title | Size | Downloads |
LSUM2GP24TSSE0 Card Manual-6PW104-book.pdf | 17.34 KB |
24-port 1000BASE-X-SFP + 4-port 10GBASE-R-SFP+ optical Ethernet interface card—LSUM2GP24TSSE0
1 Card identifier
The card identifier LSUM2GP24TSSE0 is at the upper right corner of the front panel.
2 Specifications
Table 1 Card specifications
Item |
Specifications |
Card size (H × W × D) |
40 × 399 × 355 mm (1.57 × 15.71 × 13.98 in) |
SDRAM (DDR3) |
1GB |
Power consumption |
36 W to 55 W |
Ports |
· 24 x 1000BASE-X-SFP fiber ports · 4 x 10GBASE-R-SFP+ fiber ports |
Port rate |
· 1000 Mbps · 10 Gbps |
NOTE: · To verify the compatibility of the card with the software release you are using, see the release notes. · For information about transceiver modules and cables available for the card, see the cards and transceiver modules compatibility matrixes for the device. |
IMPORTANT: For the card to operate correctly, make sure a switching fabric module is installed in one of the two lowest numbered switching fabric module slots on the S10504, S10508, S10508-V, and S10512. |
3 Related documentation
For information about card installation, see the installation guide for the device.
For software upgrade, see the release notes for the device.
Copyright © 2014-2019 New H3C Technologies Co., Ltd.
