Title | Size | Downloads |
LSUM1TGS24FD0 Card Manual-6PW104-book.pdf | 16.52 KB |
24-port 10GBASE-R-SFP+ optical Ethernet interface card—LSUM1TGS24FD0
1 Card identifier
The card identifier LSUM1TGS24FD0 is in the upper right corner of the front panel.
2 Specifications
Table 1 Card specifications
Item |
Specification |
Card size (H × W × D) |
40 × 399 × 355 mm (1.57 × 15.71 × 13.98 in) |
SDRAM (DDR3) |
2GB |
Power consumption |
50W to 104W |
Ports |
24 x 10GBASE-R-SFP+ fiber port |
Port speed |
10 Gbps |
NOTE: · To verify the compatibility of the card with the software release you are using, see the release notes. · For information about transceiver modules and cables available for the card, see the cards and transceiver modules compatibility matrixes for the device. |
3 Related documentation
For module installation, see the installation guide for the device.
For software upgrade, see the release notes for the device.
Copyright © 2016-2019 New H3C Technologies Co., Ltd.
