Title | Size | Downloads |
LSUM1GT48FD0 Card Manual-6PW102-book.pdf | 20.02 KB |
48-port 10/100/1000BASE-T electrical Ethernet interface card—LSUM1GT48FD0
1 Card identifier
The card identifier LSUM1GT48FD0 is at the upper right of the front panel.
2 Specifications
Table 1 Card specifications
Item |
Specification |
Card size (H × W × D) |
40 × 399 × 355 mm (1.57 × 15.71 × 13.98 in) |
SDRAM (DDR3) |
2GB |
Power consumption |
48W to 65W |
Connector type |
RJ-45 |
Ports |
48 |
Port rate |
10/100/1000 Mbps |
NOTE: To verify the compatibility of the card with the software release you are using, see the release notes. |
A 10/100/1000BASE-T copper port uses an RJ-45 connector. It supports Category 5 or above twisted pair cables and provides a transmission distance of 100 m (328.08 ft).
Figure 1 RJ-45 connector
Table 2 RJ-45 GE connector pin assignment
Pin |
10BASE-T/100BASE-TX/1000BASE-T |
Signal |
Function |
1 |
MX_0+ |
Transmits and receives data |
2 |
MX_0- |
3 |
MX_1+ |
4 |
MX_2+ |
5 |
MX_2- |
6 |
MX_1- |
7 |
MX_3+ |
8 |
MX_3- |
3 Related documentation
For module installation, see the installation guide for the device.
For software upgrade, see the release notes for the device.
Copyright © 2016-2019 New H3C Technologies Co., Ltd.
