H3C SecPath NSQM2QG4A0 Interface Module Card Manual-6PW104
HomeSupportSecurityH3C SecPath M9000-AI-EInstall & UpgradeInterface Module Card ManualsH3C SecPath NSQM2QG4A0 Interface Module Card Manual-6PW104
Download Book
H3C SecPath NSQM2QG4A0 interface module
1  Identifier
The module identifier NSQM2QG4A0 is in the upper right corner of the front panel.
2  About the module
The NSQM2QG4A0 interface module provides four 40G fiber ports.
3  Specifications
Figure 1 Front panel
(1) 40G fiber ports
(2) Ejector lever
(3) 40G fiber port LEDs
(4) Captive screw
Table 1 Module specifications
Item
Specification
Dimensions (H × W × D)
37.4 × 173.5 × 191.9 mm (1.47 × 6.83 × 7.56 in)
Power consumption
4 W to 15 W
Net weight
0.7 kg (1.54 lb)
Hot swapping
Not supported
Ports
4 × 40GBASE-R QSFP+ ports
Connector type
·     LC
·     MPO
Available transceiver modules
See Table 2.
Compatible devices and slots
·     M9000-AD6 application delivery appliance (slots 2/3 and 2/4)
·     M9000-AI-E4 multiservice security gateway (slots 2/3 and 2/4)
·     L5000-AD920 application delivery security gateway (slots 2/3 and 2/4)
The 40GBASE-R QSFP+ ports support QSFP+ transceiver modules in Table 2.
Table 2 QSFP+ transceiver modules available for the 40GBASE-R QSFP+ ports
Module
Central wavelength
Connector type
Cable specifications
Modal bandwidth
Maximum transmission distance
QSFP-40G-SR4-MM850
850 nm
MPO
50/125 µm, MMF
2000 MHz*km
100 m (328.08 ft)
QSFP-40G-LR4-WDM1300
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
QSFP-40G-CSR4-MM850
850 nm
MPO
50/125 µm, MMF
2000 (MHz*km)
300 m (984.25 ft)
4  LEDs
The module provides a LED for each 40G fiber port to indicate their operating status.
Table 3 40G fiber port LED description
Status
Flashing
The port is sending or receiving data.
On
A link is present on the port.
Off
No link is present on the port.
5  Related documentation
For information about installing the module, see the installation guide for the device.
Copyright © 2022 New H3C Technologies Co., Ltd.
  • Become a Partner
  • Partner Resources
