- Released At: 22-09-2022
- Page Views:
- Downloads:
H3C SecPath NSQM2QG2TG8A0 interface module
1 Identifier
The module identifier NSQM2QG2TG8A0 is in the upper right corner of the front panel.
2 Specifications
The NSQM2QG2TG8A0 interface module provides eight 10G fiber ports and two 40G fiber ports.
Figure 1 Front panel
(1) 10G fiber ports |
(2) 40G fiber ports |
(3) Ejector lever |
(4) 40G fiber port LEDs |
(5) 10G fiber port LEDs |
(6) Captive screw |
Table 1 Module specifications
Item |
Specification |
Dimensions (H × W × D) |
37.4 × 173.5 × 191.9 mm (1.47 × 6.83 × 7.56 in) |
Power consumption |
4 W to 18 W |
Net weight |
0.8 kg (1.76 lb) |
Hot swapping |
Not supported |
Ports |
· 8 × 10GBASE-R SFP+ ports · 2 × 40GBASE-R QSFP+ ports |
Connector type |
· LC · MPO |
Available transceiver modules |
· 10GBASE-R SFP+ port: see Table 2. · 40GBASE-R QSFP+ port: see Table 3. |
Compatible devices and slots |
· M9000-AD6 application delivery appliance (slots 2/3 and 2/4) · M9000-AI-E4 multiservice security gateway (slots 2/3 and 2/4) · M9008-S-V multiservice security gateway installed with NSQM2MBFEB0 interface switch modules · L5000-AD920 application delivery security gateway (slots 2/3 and 2/4) |
The 10GBASE-R-SFP+ ports support SFP+ transceiver modules described in Table 2.
Table 2 SFP+ transceiver modules available for the 10GBASE-R SFP+ ports
Module |
Central wavelength |
Connector type |
Cable specifications |
Maximum transmission distance |
SFP-XG-SX-MM850-A |
850 nm |
LC |
50/125 µm MMF |
300 m (984.25 ft) |
SFP-XG-LX-SM1310 |
1310 nm |
LC |
9/125 µm SMF |
10 km (6.21 miles) |
SFP-XG-LH40-SM1550 |
1550 nm |
LC |
9/125 µm SMF |
40 km (24.85 miles) |
The 40GBASE-R QSFP+ ports support QSFP+ transceiver modules described in Table 3.
Table 3 QSFP+ transceiver modules available for the 40GBASE-R QSFP+ ports
Module |
Connector type |
Modal bandwidth |
QSFP-40G-SR4-MM850 |
850 nm |
MPO |
50/125 µm, MMF |
2000 (MHz*km) |
100 m (328.08 ft) |
QSFP-40G-LR4-WDM1300 |
1310 nm |
LC |
9/125 µm, SMF |
N/A |
QSFP-40G-CSR4-MM850 |
850 nm |
MPO |
50/125 µm, MMF |
2000 (MHz*km) |
300 m (984.25 ft) |
3 LEDs
The module provides a LED for each 10G fiber port and 40G fiber port to indicate their operating status.
Table 4 10G fiber port LED description
Status |
Flashing |
The port is sending or receiving data. |
On |
A link is present on the port. |
Off |
No link is present on the port. |
Table 5 40G fiber port LED description
Status |
Flashing |
On |
Off |
4 Related documentation
For information about installing the module, see the installation guide for the device.
Copyright © 2022 New H3C Technologies Co., Ltd.
