Title | Size | Downloads |
H3C SecPath NS-C300-TG16A1 Interface Module Card Manual-5PW100-book.pdf | 209.84 KB |
H3C SecPath NS-C300-TG16A1 interface module
1 Identifier
The module identifier NS-C300-TG16A1 is in the upper right corner of the front panel.
2 About the module
The NS-C300-TG16A1 interface module provides sixteen 10-GE fiber ports.
3 Specifications
Figure 1 Front panel
(1) Ejector lever |
(2) 10-GE fiber ports |
(3) 10-GE fiber port LEDs |
Table 1 Module specifications
Item |
Specification |
Dimensions (H × W × D) |
44 × 191 × 365 mm (1.73 × 7.52 × 14.37 in) |
Power consumption |
5 W to 36 W |
Net weight |
1.52 kg (3.35 lb) |
Hot swapping |
Not supported |
Ports |
16 × 10GBASE-R SFP+ fiber ports |
Connector type |
LC |
Available transceiver modules |
See Table 2. |
Compatible devices and slots |
M9000-AI-E4 multiservice security gateway (subslots 2/1 and 2/2), At most one slot can be fitted |
Table 2 describes the SFP+ transceiver modules available for the 10GBASE-R SFP+ fiber ports.
Table 2 SFP+ transceiver modules available for the 10GBASE-R SFP+ fiber ports
Module |
Central wavelength |
Connector type |
Cable specifications |
Maximum transmission distance |
SFP-XG-SX-MM850-A |
850 nm |
LC |
50/125 µm, MMF |
300 m (984.25 ft) |
SFP-XG-LX-SM1310 |
1310 nm |
LC |
9/125 µm, SMF |
10 km (6.21 miles) |
SFP-XG-LH40-SM1550 |
1550 nm |
LC |
9/125 µm, SMF |
40 km (24.85 miles) |
4 LEDs
The module provides a LED for each 10-GE fiber port to indicate their operating status.
Table 3 10-GE fiber port LED description
Status |
Flashing |
The port is sending or receiving data. |
Steady on |
A link is present on the port. |
Off |
No link is present on the port. |
5 Related documentation
For information about installing the module, see the installation guide for the device.
Copyright © 2021 New H3C Technologies Co., Ltd.
