- Released At: 20-10-2021
- Page Views:
- Downloads:
H3C SecPath NS-C100-TG16B1 interface module
1 Identifier
The module identifier NS-C100-TG16B1 is in the upper right corner of the front panel.
2 About the module
The NS-C100-TG16B1 interface module provides sixteen 10G fiber ports.
3 Specifications
Figure 1 Front panel
(1) 10G fiber ports |
(2) Ejector lever |
(3) 10G fiber port LEDs |
(4) Captive screw |
Table 1 Module specifications
Item |
Specifications |
Dimensions (H × W × D) |
37.4 × 174 × 192 mm (1.47 × 6.85 × 7.56 in) |
Power consumption |
5 W to 23 W |
Weight |
0.84 kg (1.85 lb) |
Hot swapping |
Not supported |
Ports |
16 × 10GBASE-R SFP+ ports |
Connector type |
LC |
Available transceiver modules |
See Table 2. |
Compatible devices and slots |
M9000-AI-E4 multiservice security gateway (slots 2/3 and 2/4) |
Table 2 describes the specifications of SFP+ transceiver modules available for the 10GBASE-R SFP+ ports.
Table 2 SFP+ transceiver modules available for the 10GBASE-R SFP+ ports
Module |
Central wavelength |
Connector type |
Cable specifications |
Maximum transmission distance |
SFP-XG-SX-MM850-A |
850 nm |
LC |
50/125 µm MMF |
300 m (984.25 ft) |
SFP-XG-LX-SM1310 |
1310 nm |
LC |
9/125 µm SMF |
10 km (6.21 miles) |
SFP-XG-LH40-SM1550 |
1550 nm |
LC |
9/125 µm SMF |
40 km (24.85 miles) |
4 LEDs
The module provides a LED for each 10G fiber port to indicate their operating status.
Table 3 10G fiber port LED description
Status |
Flashing |
The port is sending or receiving data. |
On |
A link is present on the port. |
Off |
No link is present on the port. |
5 Related documentation
For information about installing the module, see the installation guide for the device.
Copyright © 2021 New H3C Technologies Co., Ltd.
