Title | Size | Downloads |
10-iCC Online Help.rar | 481.07 KB |
Intelligent Configuration Center
There are different types of devices in a network, which use different configuration commands and run different software versions. Even the devices of the same model may have different configurations based on their locations and functions, and use different software versions to meet network requirements. As a result, too many configuration files and software versions need to be managed, making network management more complex.
The ICC is designed to help you easily manage device configuration files and software versions at a central location. In addition, it provides configuration file baseline management that allows you to trace the changes of configuration files, and stores history versions of device software to help you quickly restore a historical version. These functions greatly facilitate device management and improve network maintainability.
The ICC also provides the Configuration Templates and device software library for resources reuse and easy maintenance.
