Title | Size | Downloads |
08-ACL Online Help.rar | 1.03 MB |
ACL Management
ACL Management is included in Enterprise and Standard editions of iMC.
The ACLM implements the following functions:
· ACL definition
· ACL use
· Packet filtering
· Configuration history for individual devices
· A user-friendly guide to ACL configuration for multiple devices by flexible use of batch deployment templates
· A powerful deployment mechanism and all-aspect task views for easy management and task deployment
The ACLM is a fundamental network resource manager. With this component installed, the ACL resource options can be integrated into the related service configuration options for easy service configuration.
