Title | Size | Downloads |
07-Report Online Help.rar | 2.79 MB |
Report Manager
As a platform providing centralized management of reports, the report management system allows you to customize reports of each iMC component and display them vividly.
The report management system features as follows:
· Provides realtime reports that can be viewed on web pages to help you obtain the most recent data.
· Provides multiple types of scheduled reports to help you obtain data at a specific interval for data comparison and trend analysis. For example, you can define daily, weekly, monthly, quarterly, half-yearly, or yearly reports.
· Provides centralized management of reports by allowing you to enter the same page for report management and query.
· Provides reports in diversified illustration ways, such as pie chart, line chart, bar chart, and tabular form; thus allowing you to query and analyze data from different angles.
· Provides multiple processing policies of a report, where you can export it in pdf or excel format, print it, or send it through Email; thus allowing you to check the reports anywhere at anytime.
