04-iMC iCC Configuration Examples-book(chm).rar(1.07 MB)
04-iMC iCC Configuration Examples-book.rar(830.05 KB)
- Released At: 29-08-2023
- Page Views:
- Downloads:
The iCC is designed to help you easily manage device configuration files and software versions at a central location. In addition, it provides configuration file baseline management that allows you to trace the changes of configuration files, and stores history versions of device software to help you quickly restore a historical version. These functions greatly facilitate device management and improve network maintainability. The iCC also provides the Configuration Templates and device software library for resources reuse and easy maintenance.
The iCC configuration examples are intended to help customers deploy various iCC features in typical network scenarios. These documents provide not only step-by-step configuration procedures but also configuration analysis and guidelines to help customers understand the configuration.
The following are available configuration examples:
· iMC iCC Device Software Import and Deployment Examples
