- 04-Network Connectivity
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-VLAN commands
- 04-Loop detection commands
- 05-Spanning tree commands
- 06-LLDP commands
- 07-Layer 2 forwarding commands
- 08-Port isolation commands
- 09-PPP commands
- 10-ARP commands
- 11-IP addressing commands
- 12-DHCP commands
- 13-DHCPv6 commands
- 14-DNS commands
- 15-NAT commands
- 16-IP performance optimization commands
- 17-IPv6 basics commands
- 18-Basic IP routing commands
- 19-Static routing commands
- 20-IPv6 static routing commands
- 21-IGMP snooping commands
- 22-MLD snooping commands
18-Basic IP routing commands | 211.91 KB |
display ip routing-table ip-address
display ip routing-table protocol
display ip routing-table statistics
display ip routing-table summary
display ipv6 routing-table acl
display ipv6 routing-table ipv6-address
display ipv6 routing-table protocol
display ipv6 routing-table statistics
display ipv6 routing-table summary
reset ip routing-table statistics protocol
reset ipv6 routing-table statistics protocol
address-family ipv4
Use address-family ipv4 to create the RIB IPv4 address family and enter its view, or enter the view of the existing RIB IPv4 address family.
Use undo address-family ipv4 to delete the RIB IPv4 address family and all settings in the view.
address-family ipv4
No RIB IPv4 address family exists.
RIB view
# Create the RIB IPv4 address family and enter its view.
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4]
address-family ipv6
Use address-family ipv6 to create the RIB IPv6 address family and enter its view, or enter the view of the existing RIB IPv6 address family.
Use undo address-family ipv6 to delete the RIB IPv6 address family and all settings in the view.
address-family ipv6
No RIB IPv6 address family exists.
RIB view
# Create the RIB IPv6 address family and enter its view.
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6]
Use display ip routing-table to display routing table information.
display ip routing-table [ verbose ]
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays only brief information about active routes.
If you do not specify any parameters, the command displays routing table information for the public network.
# Display brief information about active routes in the routing table.
<Sysname> display ip routing-table
Destinations : 12 Routes : 12
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.0/24 Direct 0 0 192.168.1.40 Vlan11
192.168.1.0/32 Direct 0 0 192.168.1.40 Vlan11
192.168.1.40/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.255/32 Direct 0 0 192.168.1.40 Vlan11
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
Destinations |
Number of destination addresses. |
Routes |
Number of routes. |
Destination/Mask |
Destination address/mask length. |
Proto |
Protocol that installed the route. |
Pre |
Preference of the route. |
Cost |
Cost of the route. |
NextHop |
Next hop address of the route. |
Output interface for packets to be forwarded along the route. |
Summary count |
Number of routes. |
# Display detailed information about all routes in the routing table.
<Sysname> display ip routing-table verbose
Destinations : 2 Routes : 2
Destination: 0.0.0.0/32
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 08h34m37s
Cost: 0 Preference: 0
IpPre: N/A QosLocalID: N/A
Tag: 0 State: Active NoAdv
TableID: 0x2 OrigAs: 0
NibID: 0x10000000 LastAs: 0
AttrID: 0xffffffff Neighbor: 0.0.0.0
Flags: 0x1000c OrigNextHop: 127.0.0.1
Label: NULL RealNextHop: 127.0.0.1
BkLabel: NULL BkNextHop: N/A
Tunnel ID: Invalid Interface: InLoopBack0
BkTunnel ID: Invalid BkInterface: N/A
FtnIndex: 0x0 TrafficIndex: N/A
Connector: N/A VpnPeerId: N/A
Dscp: N/A
Destination: 1.1.1.0/24
Protocol: Static
Process ID: 0
SubProtID: 0x0 Age: 04h20m37s
Cost: 0 Preference: 60
Tag: 0 State: Active Adv
NibID: 0x10000003 LastAs: 0
Flags: 0x1008c OrigNextHop: 192.168.47.4
Label: NULL RealNextHop: 192.168.47.4
Tunnel ID: Invalid Interface: Vlan-interface11
Dscp: N/A
Destinations |
Routes |
Number of routes. |
Destination |
Protocol |
SubProtID |
ID of the subprotocol for routing. |
Age |
Time for which the route has been in the routing table. |
Cost |
Preference |
IpPre |
IP precedence. |
QosLocalID |
Local QoS ID. |
Tag |
Route tag. |
State |
Route status: · Active—Active unicast route. · Adv—Route that can be advertised. · Inactive—Inactive route. · NoAdv—Route that the router must not advertise. · Vrrp—Routes generated by VRRP. · Nat—Routes generated by NAT. · TunE—Tunnel. |
OrigTblID |
Original routing table ID. |
OrigVrf |
This field is not supported in the current software version. Original VPN instance that the route belongs to. This field displays default-vrf if the route is on the public network. |
TableID |
ID of the routing table. |
OrigAs |
This field is not supported in the current software version. Original AS number. |
NibID |
ID of the next hop. |
LastAs |
This field is not supported in the current software version. Last AS number. |
AttrID |
Attribute ID. |
Neighbor |
Address of the neighbor determined by the routing protocol. |
Flags |
Flags of the route. |
OrigNextHop |
RealNextHop |
Real next hop of the route. |
BkLabel |
Backup label. |
BkNexthop |
Backup next hop. |
Tunnel ID |
This field is not supported in the current software version. Tunnel ID. |
BkTunnel ID |
This field is not supported in the current software version. Backup tunnel ID. |
BkInterface |
Backup output interface. |
FtnIndex |
Index of the FTN entry. |
TrafficIndex |
Traffic index in the range of 1 to 64. This field displays N/A when the value is invalid. |
Connector |
This field is not supported in the current software version. BGP connector attribute exchanged between BGP peers along with a VPN IPv4 route. The value of the attribute is the IP address of the remote PE device. The BGP connector attribute is used for MD VPN. This field displays N/A if the BGP connector attribute is not supported. |
VpnPeerId |
This field is not supported in the current software version. ID of the VPN peer to which the route belongs, in the range of 1 to 134217727. This field displays N/A when the value is invalid. |
Dscp |
DSCP value of the route, in the range of 0 to 63. This field displays N/A when the value is invalid. |
Summary count |
Number of routes. |
display ip routing-table acl
Use display ip routing-table acl to display information about routes permitted by a basic ACL.
display ip routing-table acl ipv4-acl-number [ verbose ]
ipv4-acl-number: Specifies a basic ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the basic ACL. If you do not specify this keyword, the command displays only brief information about active routes permitted by the basic ACL.
If the specified ACL does not exist or has no rules configured, the command displays information about all routes.
# Define basic ACL 2000 and set the route filtering rules.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-basic-2000] rule deny source any
# Display brief information about active routes permitted by basic ACL 2000.
[Sysname-acl-ipv4-basic-2000] display ip routing-table acl 2000
Summary count : 4
192.168.1.0/24 Direct 0 0 192.168.1.111 Vlan11
192.168.1.0/32 Direct 0 0 192.168.1.111 Vlan11
192.168.1.111/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.255/32 Direct 0 0 192.168.1.111 Vlan11
For command output, see Table 1.
# Display detailed information about all routes permitted by basic ACL 2000.
<Sysname> display ip routing-table acl 2000 verbose
Summary count : 4
Destination: 192.168.1.0/24
Protocol: Direct
Process ID: 0
SubProtID: 0x1 Age: 04h20m37s
Flags: 0x10080 OrigNextHop: 192.168.1.111
Label: NULL RealNextHop: 192.168.1.111
Dscp: N/A
Destination: 192.168.1.0/32
Protocol: Direct
Process ID: 0
Flags: 0x1008c OrigNextHop: 192.168.1.111
Dscp: N/A
Destination: 192.168.1.111/32
Protocol: Direct
Process ID: 0
Flags: 0x10004 OrigNextHop: 127.0.0.1
Dscp: N/A
Destination: 192.168.1.255/32
Protocol: Direct
Process ID: 0
Dscp: N/A
For command output, see Table 2.
Use display ip routing-table ip-address to display information about routes to a specific destination address.
Use display ip routing-table ip-address1 to ip-address2 to display information about routes to a range of destination addresses.
display ip routing-table ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
display ip routing-table ip-address1 to ip-address2 [ verbose ]
ip-address: Specifies a destination IP address in dotted decimal notation.
mask-length: Specifies the mask length, an integer in the range of 0 to 32.
mask: Specifies the IP address mask in dotted decimal notation.
longer-match: Displays the route entry with the longest mask.
ip-address1 to ip-address2: Specifies a destination IP address range.
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays brief information about active routes.
Executing the command with different parameters yields different outputs.
· display ip routing-table ip-address
¡ The system ANDs the entered destination IP address with the subnet mask in each active route entry.
¡ The system ANDs the destination IP address in each active route entry with its own subnet mask.
If the two operations yield the same result for an entry, the entry is displayed.
· display ip routing-table ip-address mask
¡ The system ANDs the entered destination IP address with the entered subnet mask.
¡ The system ANDs the destination IP address in each active route entry with the entered subnet mask.
If the two operations yield the same result for an entry with a subnet mask not greater than the entered subnet mask, the entry is displayed.
· display ip routing-table ip-address longer-match
If the two operations yield the same result for multiple entries, the entry with the longest mask length is displayed.
· display ip routing-table ip-address mask longer-match
If the two operations yield the same result for multiple entries with a mask not greater than the entered subnet mask, the entry with the longest mask length is displayed.
· display ip routing-table ip-address1 to ip-address2
The system displays active route entries with destinations in the range of ip-address1/32 to ip-address2/32.
# Display brief information about the routes to the destination IP address 11.0.0.1.
<Sysname> display ip routing-table 11.0.0.1
Summary count : 3
11.0.0.0/8 Static 60 0 0.0.0.0 NULL0
11.0.0.0/16 Static 60 0 0.0.0.0 NULL0
11.0.0.0/24 Static 60 0 0.0.0.0 NULL0
# Display brief information about the routes to the destination IP address 11.0.0.1 and mask length 20.
<Sysname> display ip routing-table 11.0.0.1 20
Summary count : 2
# Display brief information about the most specific route to the destination address 11.0.0.1.
<Sysname> display ip routing-table 11.0.0.1 longer-match
Summary count : 1
# Display brief information about the most specific route to the destination IP address 11.0.0.1 and mask length 20.
<Sysname> display ip routing-table 11.0.0.1 20 longer-match
Summary count : 1
# Display brief information about the routes to destination addresses in the range of 1.1.1.0 to 5.5.5.0.
<Sysname> display ip routing-table 1.1.1.0 to 5.5.5.0
Summary count : 4
1.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
2.2.2.0/24 Direct 0 0 2.2.2.1 Vlan2
3.3.3.1/32 Direct 0 0 127.0.0.1 InLoop0
4.4.4.1/32 Direct 0 0 127.0.0.1 InLoop0
# Display detailed information about the routes to the destination IP address 1.2.3.4.
<Sysname> display ip routing-table 1.2.3.4 verbose
Summary count : 1
Destination: 1.2.3.4/32
Protocol: O_INTRA
Process ID: 0
SubProtID: 0x1 Age: 00h00m37s
Cost: 0 Preference: 255
TableID: 0x2 OrigAs: 200
NibID: 0x15000000 LastAs: 200
AttrID: 0x0 Neighbor: 192.168.47.2
Flags: 0x10060 OrigNextHop: 192.168.47.2
Label: NULL RealNextHop: 192.168.47.2
Dscp: N/A
Use display ip routing-table protocol to display information about routes installed by a protocol.
display ip routing-table protocol protocol [ inactive | verbose ]
protocol: Specifies a routing protocol.
inactive: Displays information about inactive routes. If you do not specify this keyword, the command displays information about both active and inactive routes.
verbose: Displays detailed routing table information. If you do not specify this keyword, the command displays brief routing information.
# Display brief information about direct routes.
<Sysname> display ip routing-table protocol direct
Summary count : 9
Direct Routing table status : <Active>
Summary count : 9
2.2.2.0/32 Direct 0 0 2.2.2.1 Vlan2
2.2.2.2/32 Direct 0 0 127.0.0.1 InLoop0
2.2.2.255/32 Direct 0 0 2.2.2.1 Vlan2
Direct Routing table status : <Inactive>
Summary count : 0
# Display brief information about static routes.
<Sysname> display ip routing-table protocol static
Summary count : 1
Static Routing table status : <Active>
Summary count : 0
Static Routing table status : <Inactive>
Summary count : 1
1.2.3.0/24 Static 60 0 1.2.4.5 Vlan10
Use display ip routing-table statistics to display IPv4 route statistics, including numbers of total routes, routes installed by the protocol, routes marked as deleted, and active routes.
If you do not specify any parameters, the command displays IPv4 route statistics for the public network.
# Display IPv4 route statistics for the public network.
<Sysname> display ip routing-table statistics
Total prefixes: 15 Active prefixes: 15
Proto route active added deleted
DIRECT 12 12 30 18
STATIC 3 3 5 2
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
Total 15 15 35 20
Proto |
route |
Number of routes installed by the protocol. |
active |
Number of active routes. |
added |
Number of routes added to the routing table after the router started up or the routing table was cleared most recently. |
deleted |
Number of routes marked as deleted, which will be cleared after a period. |
Total |
Total number of routes. |
Use display ip routing-table summary to display brief routing table information, including maximum number of ECMP routes, maximum number of active routes, and number of remaining active routes.
# Display brief routing table information for the public network.
<Sysname> display ip routing-table summary
Max ECMP: 32
Max Active Route: 262144
Remain Active Route: 262126
Max ECMP |
This field is not supported in the current software version. Maximum number of ECMP routes supported by the system. |
Max Active Route |
Maximum number of supported routes. |
Remain Active Route |
Number of the remaining inactive routes. |
display ipv6 rib nib
Use display ipv6 rib nib to display next hop information in the IPv6 RIB.
self-originated: Displays information about next hops of self-originated routes in the IPv6 RIB.
nib-id: Specifies a NIB by its ID, a hexadecimal string in the range of 1 to ffffffff.
verbose: Displays detailed next hop information in the IPv6 RIB. If you do not specify this keyword, the command displays brief next hop information in the IPv6 RIB.
protocol protocol: Specifies a protocol by its name.
# Display brief next hop information in the IPv6 RIB.
<Sysname> display ipv6 rib nib
Total number of nexthop(s): 151
NibID: 0x20000000 Sequence: 0
Type: 0x1 Flushed: Yes
UserKey0: 0x0 VrfNthp: 0
UserKey1: 0x0 Nexthop: ::
IFIndex: 0x111 LocalAddr: ::
TopoNthp: Invalid
NibID: 0x20000001 Sequence: 1
UserKey1: 0x0 Nexthop: ::1
IFIndex: 0x112 LocalAddr: ::1
TopoNthp: Invalid
# Display detailed next hop information in the IPv6 RIB.
<Sysname> display ipv6 rib nib verbose
TopoNthp: Invalid
RefCnt: 4 FlushRefCnt: 1
Flag: 0x84 Version: 1
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: ::
RelyDepth: 0 RealNexthop: ::
Interface: NULL0 LocalAddr: ::
TunnelCnt: 0 Vrf: default-vrf
TunnelID: N/A Topology:
Weight: 0
TopoNthp: Invalid
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: ::1
RelyDepth: 0 RealNexthop: ::1
Interface: InLoop0 LocalAddr: ::1
Weight: 0
NibID: 0x26000001 Sequence: 1
UserKey1: 0x0 Nexthop: 121::2
TopoNthp: Invalid
NibID: 0x26000002 Sequence: 1
UserKey1: 0x0 Nexthop: 122::2
TopoNthp: Invalid
For command output, see Table 8 and Table 9.
display ipv6 route-direct nib
Use display ipv6 route-direct nib to display next hop information for IPv6 direct routes.
verbose: Displays detailed next hop information for IPv6 direct routes. If you do not specify this keyword, the command displays brief next hop information for IPv6 direct routes.
# Display brief next hop information for IPv6 direct routes.
<Sysname> display ipv6 route-direct nib
Total number of nexthop(s): 115
TopoNthp: Invalid
TopoNthp: Invalid
# Display detailed next hop information for IPv6 direct routes.
<Sysname> display ipv6 route-direct nib verbose
RefCnt: 1 FlushRefCnt: 0
Flag: 0x2 Version: 1
1 nexthop(s):
Weight: 0
1 nexthop(s):
Weight: 0
For command output, see Table 10 and Table 11.
Use display ipv6 routing-table to display IPv6 routing table information.
display ipv6 routing-table [ verbose ]
If you do not specify any parameters, the command displays IPv6 routing table information for the public network.
# Display brief information about active routes in the IPv6 routing table.
<Sysname> display ipv6 routing-table
Destination: ::1/128 Protocol : Direct
NextHop : ::1 Preference: 0
Interface : InLoop0 Cost : 0
Destination: FE80::/10 Protocol : Direct
NextHop : :: Preference: 0
Destinations |
Routes |
Number of routes. |
Destination |
IPv6 address and prefix of the destination network or host. |
NextHop |
Preference |
Protocol |
Cost |
Summary count |
Number of routes. |
# Display detailed information about all routes in the IPv6 routing table.
<Sysname> display ipv6 routing-table verbose
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 19h23m02s
TableID: 0xa OrigAs: 0
NibID: 0x20000000 LastAs: 0
AttrID: 0xffffffff Neighbor: ::
Flags: 0x10004 OrigNextHop: ::1
Label: NULL RealNextHop: ::1
Dscp: N/A
Destination: 12::/96
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h01m47s
NibID: 0x20000003 LastAs: 0
Flags: 0x10080 OrigNextHop: ::
Dscp: N/A
Destination |
Protocol |
SubProtID |
Age |
Cost |
Preference |
IpPre |
IP precedence. |
QosLocalID |
Local QoS ID. |
Tag |
Tag of the route. |
State |
OrigTblID |
OrigVrf |
TableID |
OrigAs |
NibID |
LastAs |
AttrID |
Attribute ID. |
Neighbor |
Flags |
OrigNextHop |
RealNextHop |
BkLabel |
Backup label. |
BkNexthop |
Backup next hop. |
Tunnel ID |
BkTunnel ID |
BkInterface |
FtnIndex |
TrafficIndex |
Connector |
This field is not supported in the current software version. BGP connector attribute exchanged between BGP peers along with a VPN IPv4 route. The value of the attribute is the IP address of the remote PE device. The BGP connector attribute is used for MD VPN. This field displays N/A if BGP connector attribute is not supported. |
VpnPeerId |
Dscp |
Summary count |
Number of routes. |
Use display ipv6 routing-table acl to display routing information permitted by an IPv6 basic ACL.
display ipv6 routing-table acl ipv6-acl-number [ verbose ]
ipv6-acl-number: Specifies a basic IPv6 ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the basic IPv6 ACL. If you do not specify this keyword, the command displays only brief information about active routes permitted by the basic IPv6 ACL.
If the specified IPv6 ACL does not exist or has no rules configured, the command displays information about all IPv6 routes.
# Display brief information about active routes permitted by IPv6 ACL 2000.
<Sysname> display ipv6 routing-table acl 2000
Summary count : 6
Destination : ::1/128 Protocol : Direct
Destination: 12::/96 Protocol : Direct
Interface : Vlan11 Cost : 0
Destination: 12::1/128 Protocol : Direct
Destination: 11::1/128 Protocol : O_INTER
NextHop : FE80::A1F:3FFF:FE45:206 Preference: 10
Interface : Vlan11 Cost : 2
Destination: FF00::/8 Protocol : Direct
Interface : NULL0 Cost : 0
For command output, see Table 5.
# Display detailed information about all routes permitted by IPv6 ACL 2000.
<Sysname> display ipv6 routing-table acl 2000 verbose
Summary count : 6
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 19h29m12s
Dscp: N/A
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h07m57s
Dscp: N/A
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h07m55s
Dscp: N/A
Protocol: O_INTER
Process ID: 1
SubProtID: 0x2 Age: 00h06m43s
Cost: 2 Preference: 10
NibID: 0x23000003 LastAs: 0
AttrID: 0x ffffffff Neighbor: ::
Flags: 0x10041 OrigNextHop: FE80::A1F:3FFF:FE45:206
Label: NULL RealNextHop: FE80::A1F:3FFF:FE45:206
Dscp: N/A
Protocol: Direct
Process ID: 0
NibID: 0x20000002 LastAs: 0
Flags: 0x10084 OrigNextHop: ::
Dscp: N/A
Protocol: Direct
Process ID: 0
NibID: 0x20000001 LastAs: 0
Flags: 0x10014 OrigNextHop: ::
Tunnel ID: Invalid Interface: NULL0
Dscp: N/A
For command output, see Table 6.
Use display ipv6 routing-table ipv6-address to display information about routes to an IPv6 destination address.
Use display ipv6 routing-table ipv6-address1 to ipv6-address2 to display information about routes to a range of IPv6 destination addresses.
display ipv6 routing-table ipv6-address [ prefix-length ] [ longer-match ] [ verbose ]
display ipv6 routing-table ipv6-address1 to ipv6-address2 [ verbose ]
ipv6-address: Specifies a destination IPv6 address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
longer-match: Displays the route entry with the longest prefix.
ipv6-address1 to ipv6-address2: Specifies a destination IPv6 address range.
Executing the command with different parameters yields different output.
· display ipv6 routing-table ipv6-address
¡ The system ANDs the entered destination IPv6 address with the prefix length in each active route entry.
¡ The system ANDs the destination IPv6 address in each active route entry with the prefix length in the entry.
· display ipv6 routing-table ipv6-address prefix-length
¡ The system ANDs the entered destination IPv6 address with the entered prefix length.
¡ The system ANDs the destination IPv6 address in each active route entry with the entered prefix length.
If the two operations yield the same result for an entry with a prefix length not greater than the entered prefix length, the entry is displayed.
· display ipv6 routing-table ipv6-address longer-match
If the two operations yield the same result for multiple entries, the entry with the longest prefix length is displayed.
· display ipv6 routing-table ipv6-address prefix-length longer-match
If the two operations yield the same result for multiple entries with a prefix length not greater than the entered prefix length, the entry with the longest prefix length is displayed.
· display ipv6 routing-table ipv6-address1 to ipv6-address2
The system displays route entries with destinations in the range of ipv6-address1/128 to ipv6-address2/128.
# Display brief information about the routes to the destination IPv6 address 10::1 127.
<Sysname> display ipv6 routing-table 10::1 127
Summary count: 3
Destination: 10::/64 Protocol : Static
NextHop : :: Preference: 60
Destination: 10::/68 Protocol : Static
Destination: 10::/120 Protocol : Static
# Display brief information about the most specific route to the destination IPv6 address 10::1 and prefix length 127.
<Sysname> display ipv6 routing-table 10::1 127 longer-match
Summary count : 1
# Display brief information about the routes to destination addresses in the range of 100:: to 300::.
<Sysname> display ipv6 routing-table 100:: to 300::
Summary count : 3
Destination: 100::/64 Protocol : Static
Destination: 200::/64 Protocol : Static
Destination: 300::/64 Protocol : Static
# Display detailed information about the routes to destination IPv6 addresses 1:2::3:4/128.
<Sysname> display ipv6 routing-table 1:2::3:4 128 verbose
Summary count : 1
Destination: 1:2::3:4/128
Protocol: O_INTRA
Process ID: 1
SubProtID: 0x1 Age: 00h01m14s
Cost: 1 Preference: 10
NibID: 0x23000002 LastAs: 0
Dscp: N/A
Use display ipv6 routing-table protocol to display information about IPv6 routes installed by a protocol.
display ipv6 routing-table protocol protocol [ inactive | verbose ]
# Display brief information about IPv6 direct routes.
<Sysname> display ipv6 routing-table protocol direct
Summary count : 3
Summary count : 3
Summary count : 0
# Display brief information about IPv6 static routes.
<Sysname> display ipv6 routing-table protocol static
Summary count : 3
Summary count : 3
Destination: 2::2/128 Protocol : Static
NextHop : fe80::2 Preference: 60
Interface : Vlan12 Cost : 0
NextHop : fe80::3 Preference: 60
Destination: 3::3/128 Protocol : Static
NextHop : 2::2 Preference: 60
Summary count : 0
Use display ipv6 routing-table statistics to display IPv6 route statistics, including numbers of total routes, routes installed and deleted by the protocol, and active routes.
If you do not specify any parameters, the command displays IPv6 route statistics for the public network.
# Display IPv6 route statistics for the public network.
<Sysname> display ipv6 routing-table statistics
Total prefixes: 8 Active prefixes: 8
DIRECT 5 5 5 0
STATIC 3 3 3 0
RIPng 0 0 0 0
Total 8 8 8 0
Table 7 Command output
Proto |
route |
active |
added |
deleted |
Total |
Use display ipv6 routing-table summary to display brief IPv6 routing table information, including maximum number of ECMP routes, maximum number of active routes, and number of remaining active routes.
# Display brief IPv6 routing table information for the public network.
<Sysname> display ipv6 routing-table summary
Max ECMP: 32
For command output, see Table 4.
display rib nib
Use display rib nib to display next hop information in the RIB.
self-originated: Displays information about next hops of self-originated routes in the RIB.
verbose: Displays detailed next hop information in the RIB. If you do not specify this keyword, the command displays brief next hop information in the RIB.
# Display brief next hop information in the RIB.
<Sysname> display rib nib
Total number of nexthop(s): 176
NibID: 0x10000000 Sequence: 0
UserKey1: 0x0 Nexthop: 0.0.0.0
IFIndex: 0x111 LocalAddr: 0.0.0.0
TopoNthp: 0
NibID: 0x10000001 Sequence: 1
UserKey1: 0x0 Nexthop: 127.0.0.1
IFIndex: 0x112 LocalAddr: 127.0.0.1
TopoNthp: 0
NibID: 0x10000002 Sequence: 2
Type: 0x5 Flushed: Yes
TopoNthp: 0
NibID: 0x16000000 Sequence: 3
Type: 0x21 Flushed: No
UserKey1: 0x0 Nexthop: 12.1.1.2
IFIndex: 0x0 LocalAddr: 0.0.0.0
TopoNthp: 0
NibID |
Sequence |
Sequence number of the next hop. |
Type |
Type of the next hop. |
Flushed |
Indicates whether the route with the next hop has been flushed to the FIB. |
UserKey0 |
Reserved data 1. |
UserKey1 |
Reserved data 2. |
VrfNthp |
This field is not supported in the current software version. Index of the VPN instance that the next hop belongs to. This field displays 0 if the next hop is on the public network. |
Nexthop |
Next hop address. |
IFIndex |
Interface index. |
LocalAddr |
Local interface address. |
TopoNthp |
This field is not supported in the current software version. Index of the topology that contains the next hop. This field displays 0 if the next hop is on the IPv4 public network. This field displays Invalid if the next hop is on an IPv6 network, because the router does not support non-base topologies. |
SubNibID |
ID of the sub-next hop. |
SubSeq |
Sequence number of the sub-next hop. |
NthpCnt |
Number of sub-next hops. |
Samed |
Number of the same sub-next hops. |
# Display detailed next hop information in the RIB.
<Sysname> display rib nib verbose
TopoNthp: 0
RefCnt: 6 FlushRefCnt: 2
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 0.0.0.0
RelyDepth: 0 RealNexthop: 0.0.0.0
Interface: NULL0 LocalAddr: 0.0.0.0
TunnelID: N/A Topology: base
Weight: 0
TopoNthp: 0
RefCnt: 11 FlushRefCnt: 5
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 127.0.0.1
RelyDepth: 0 RealNexthop: 127.0.0.1
Interface: InLoop0 LocalAddr: 127.0.0.1
Weight: 0
NibID: 0x15000003 Sequence: 3
Type: 0x43 Flushed: Yes
UserKey0: 0x100010000 VrfNthp: 0
UserKey1: 0x0 Nexthop: 22.22.22.22
TopoNthp: 0
RefCnt: 9 FlushRefCnt: 3
Policy: tnl-policy1
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 22.22.22.22
RelyDepth: 1 RealNexthop: 13.1.1.2
Interface: Vlan11 LocalAddr: 13.1.1.1
TunnelCnt: 1 Vrf: default-vrf
TunnelID: 1025 Topology: base
Weight: 0
x nexthop (s) |
Number of next hops. |
PrefixIndex |
Prefix index of the next hop for an ECMP route. |
Vrf |
This field is not supported in the current software version. VPN instance name. For the public network, this field displays default-vrf. |
OrigNexthop |
Original next hop. |
RealNexthop |
Real next hop. |
Output interface. |
LocalAddr |
RelyDepth |
Recursion depth. |
TunnelCnt |
Number of tunnels after route recursion. |
TunnelID |
This field is not supported in the current software version. ID of the tunnel after route recursion. |
Topology |
This field is not supported in the current software version. Topology name. The topology name for the IPv4 public network is base. This field is blank for IPv6, because IPv6 does not support non-base topologies. |
Weight |
ECMP route weight. This field displays 0 for non-ECMP routes. |
RefCnt |
Reference count of the next hop. |
FlushRefCnt |
Reference count of the next hop that is flushed to the FIB. |
Flag |
Flag of the next hop. |
Version |
Version of the next hop. |
display route-direct nib
Use display route-direct nib to display next hop information for direct routes.
verbose: Displays detailed next hop information for direct routes. If you do not specify this keyword, the command displays brief next hop information for direct routes.
# Display brief next hop information for direct routes.
<Sysname> display route-direct nib
Total number of nexthop(s): 116
TopoNthp: 0
TopoNthp: 0
NibID |
ID of the NIB. |
Sequence |
Sequence number of the NIB. |
Type |
Type of the NIB. |
Flushed |
Indicates whether the route with the NIB has been flushed to the FIB. |
UserKey0 |
Reserved data 1. |
UserKey1 |
Reserved data 2. |
VrfNthp |
Nexthop |
Next hop address. |
IFIndex |
Interface index. |
LocalAddr |
Local interface IP address. |
TopoNthp |
# Display detailed next hop information for direct routes.
<Sysname> display route-direct nib verbose
TopoNthp: 0
RefCnt: 2 FlushRefCnt: 0
1 nexthop(s):
Weight: 0
TopoNthp: 0
RefCnt: 5 FlushRefCnt: 0
1 nexthop(s):
Weight: 0
x nexthop(s) |
PrefixIndex |
Vrf |
OrigNexthop |
RealNexthop |
Real next hop. |
Output interface. |
localAddr |
RelyDepth |
Recursion depth. |
TunnelCnt |
This field is not supported in the current software version. Number of tunnels after route recursion. |
TunnelID |
Topology |
Weight |
RefCnt |
FlushRefCnt |
Flag |
Version |
fib lifetime
Use fib lifetime to set the maximum lifetime for IPv4 or IPv6 routes in the FIB.
Use undo fib lifetime to restore the default.
fib lifetime seconds
undo fib lifetime
The maximum lifetime for IPv4 or IPv6 routes in the FIB is 600 seconds.
RIB IPv4 address family view
RIB IPv6 address family view
seconds: Specifies the maximum lifetime for routes in the FIB, in the range of 0 to 6000 seconds. When this argument is set to 0, FIB entries immediately age out after a protocol or RIB process switchover.
When a protocol or RIB process switchover occurs, FIB entries age out after the time specified in this command.
# Set the maximum lifetime for IPv4 routes in the FIB to 60 seconds.
[Sysname] rib
[Sysname-rib-ipv4] fib lifetime 60
protocol lifetime
Use protocol lifetime to set the maximum lifetime for IPv4 or IPv6 routes and labels in the RIB.
Use undo protocol lifetime to restore the default.
protocol protocol lifetime seconds
undo protocol protocol lifetime
The maximum lifetime for IPv4 or IPv6 routes and labels in the RIB is 480 seconds.
seconds: Specifies the maximum lifetime for routes and labels in the RIB, in the range of 1 to 6000 seconds.
When GR is enabled, make sure the protocol can complete GR and install all route entries to the RIB within the lifetime configured in this command.
# Set the maximum lifetime for RIP routes and labels in the RIB to 60 seconds.
[Sysname] rib
[Sysname-rib-ipv4] protocol rip lifetime 60
Use reset ip routing-table statistics protocol to clear IPv4 route statistics.
reset ip routing-table statistics protocol { protocol | all }
protocol: Clears route statistics for a routing protocol.
all: Clears route statistics for all IPv4 routing protocols.
This command clears only statistics of added and deleted routes for the specified routing protocols.
# Clear all IPv4 route statistics for the public network.
<Sysname> reset ip routing-table statistics protocol all
Use reset ipv6 routing-table statistics protocol to clear IPv6 route statistics.
reset ipv6 routing-table statistics protocol { protocol | all }
protocol: Clears route statistics for an IPv6 routing protocol.
all: Clears route statistics for all IPv6 routing protocols.
# Clear all IPv6 route statistics for the public network.
<Sysname> reset ipv6 routing-table statistics protocol all
rib
Use rib to enter RIB view.
Use undo rib to remove all configurations in RIB view.
rib
undo rib
# Enter RIB view.
[Sysname] rib
[Sysname-rib]
