07-WLAN IP snooping commands | 50.26 KB |
client ip-snooping http-learning enable
client ipv4-snooping arp-learning enable
client ipv4-snooping dhcp-learning enable
client ipv6-snooping dhcpv6-learning enable
client ipv6-snooping nd-learning enable
client ipv6-snooping snmp-nd-report enable
wlan client ip-conflict-detection enable
Use client ip-snooping http-learning enable to enable snooping HTTP and HTTPS requests redirected to the portal server.
Use undo client ip-snooping http-learning enable to disable snooping HTTP and HTTPS requests redirected to the portal server.
Snooping HTTP and HTTPS requests is disabled.
Service template view
An AC can use this method to learn IP addresses of clients performing portal authentication. For more information about portal authentication, see User Access and Authentication Configuration Guide.
The priorities for learning IP addresses through snooping DHCP packets, ARP or ND packets, and HTTP/HTTPS requests are in descending order.
Make sure the service template is disabled when you execute this command.
# Enable snooping HTTP and HTTPS requests.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] client ip-snooping http-learning enable
Use client ipv4-snooping arp-learning enable to enable snooping ARP packets.
Use undo client ipv4-snooping arp-learning enable to disable snooping ARP packets.
Snooping ARP packets is enabled.
# Disable snooping ARP packets.
[Sysname-wlan-st-service1] undo client ipv4-snooping arp-learning enable
Use client ipv4-snooping dhcp-learning enable to enable snooping DHCPv4 packets.
Use undo client ipv4-snooping dhcp-learning enable to disable snooping DHCPv4 packets.
Snooping DHCPv4 packets is enabled.
# Disable snooping DHCPv4 packets.
[Sysname-wlan-st-service1] undo client ipv4-snooping dhcp-learning enable
Use client ipv6-snooping dhcpv6-learning enable to enable snooping DHCPv6 packets.
Use undo client ipv6-snooping dhcpv6-learning enable to disable snooping DHCPv6 packets.
Snooping DHCPv6 packets is disabled.
# Disable snooping DHCPv6 packets.
[Sysname-wlan-st-service1] client ipv6-snooping dhcpv6-learning enable
Use client ipv6-snooping nd-learning enable to enable snooping ND packets.
Use undo client ipv6-snooping nd-learning enable to disable snooping ND packets.
Snooping ND packets is disabled.
# Disable snooping ND packets.
[Sysname-wlan-st-service1] undo client ipv6-snooping nd-learning enable
Use client ipv6-snooping snmp-nd-report enable to enable SNMP to obtain client IPv6 addresses learned from ND packets.
Use undo client ipv6-snooping snmp-nd-report enable to disable SNMP from obtaining client IPv6 addresses learned from ND packets.
SNMP obtains client IPv6 addresses learned from both DHCPv6 and ND packets.
# Disable SNMP from obtaining client IPv6 addresses learned from ND packets.
[Sysname-wlan-st-service1] undo client ipv6-snooping snmp-nd-report enable
Use wlan client ip-conflict-detection enable to enable IP address conflict detection.
Use undo wlan client ip-conflict-detection enable to disable IP address conflict detection.
IP address conflict detection is enabled.
This feature enables the system to detect IP address conflicts between a client attempting to come online and online clients. The system logs off the online clients that use the same IP address as the new client and creates IP address conflict entries for the clients. The system deletes the IP address conflict entry for a client when the client cache expires or the client's IP address changes.
In an AC hierarchy network, you can disable IP address conflict detection on the central AC if portal authentication has been disabled or accounting has been disabled for 802.1X or MAC authentication clients. This allows clients from different local ACs to come online with the same IP address, simplifying DHCP configuration.
# Disable IP address conflict detection.
<Sysname> system
[Sysname] undo wlan client ip-conflict enable
client cache aging-time
