09-Radio Resources Management
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5426P02)-6W10409-Radio Resources Management
00-Preface
00-Preface 100.44 KB
Preface
This command reference describes the configuration commands for the following features:
·     WLAN RRM.
·     WLAN load balancing.
·     WLAN radio load balancing.
·     Band navigation.
·     Spectrum management.
·     Radio management.
·     WLAN radio resource measurement.
·     Channel scanning.
·     Audience.
·     Conventions.
·     Documentation feedback.
Audience
·     Network planners.
·     Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
  • Become a Partner
  • Partner Resources
