H3C WA6628E-T and WA6628X APs 5 GHz Radio Virtualization Configuration Guide-6W100-book.pdf(49.55 KB)
- Released At: 14-04-2022
- Page Views:
- Downloads:
H3C WA6628E-T and WA6628X APs |
5 GHz Radio Virtualization Configuration Guide |
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved.
The contents in this document are general technical information, some of which might not support the products you have purchased.
Configuring 5 GHz radio virtualization
Configuring 5 GHz radio virtualization on the AC
Configuring 5 GHz radio virtualization on the cloud AP
5 GHz radio virtualization splits the 5 GHz radio on an AP that has a 2.4 GHz radio and a 5-GHz 8 × 8 mode radio into two 5-GHz 4 × 4 mode radios. With this feature enabled, a dual-radio AP can operate in triple-radio mode.
· SNMP and cloud-based management are not supported when this feature is enabled.
· With this feature enabled, you can bind a maximum of eight wireless service templates to each of the two 5 GHz radios.
· To check the LED status of radios on a WA6628E-T AP in triple-radio mode, use the following table.
Table 1 LED description
LED |
Color |
Status |
RADIO1 |
Green |
Flashing (once per second) |
Radio 1 has associated clients. |
Off |
Radio 1 is disabled or the LED has been turned off. |
RADIO2 |
Green |
Radio 2 has associated clients. |
Amber |
In triple radio mode, Radio 3 has associated clients. |
Alternating green and amber |
In triple radio mode, Radio 2 and Radio 3 have associated clients. |
Off |
Radio 2 is disabled or the LED has been turned off. |
Before you configure 5 GHz radio virtualization, perform the following tasks:
· Disable the auto AP feature.
· Delete the manual APs for which you want to enable this feature. If the manual APs belong to an AP group, also delete the manual APs from that AP group.
After you configure 5 GHz radio virtualization, reconfigure the target APs. The APs will reboot automatically during the association process to switch to triple-radio mode.
1. Enter system view.
2. Enable 5 GHz radio virtualization.
wlan virtual-5g-radio enable { all | ap-model ap-model }
By default, 5 GHz radio virtualization is disabled. A 5 GHz radio will not be virtualized into two 5 GHz radios.
After you enable 5 GHz radio virtualization or restore the default setting, reboot the cloud AP for the settings to take effect.
The cloud AP starts up with factory default configuration after it switches to triple-radio mode.
2. Enable virtual 5 GHz radio.
