06-VPLS commands | 273.52 KB |
display bgp l2vpn auto-discovery
display l2vpn service-instance
tunnel-policy (auto-discovery VSI view)
VPLS commands
address-family l2vpn
Use address-family l2vpn to create the BGP L2VPN address family and enter its view, or enter the view of the existing BGP L2VPN address family.
Use undo address-family l2vpn to delete the BGP L2VPN address family and all settings from BGP L2VPN address family view.
No BGP L2VPN address family exists.
BGP instance view
To establish a BGP PW to a remote PE, you must execute the peer enable command in BGP L2VPN address family view to enable the remote PE.
# Create the BGP L2VPN address family and enter BGP L2VPN address family view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn
[Sysname-bgp-default-l2vpn]
[Sysname-bgp-abc] address-family l2vpn
[Sysname-bgp-abc-l2vpn]
peer enable (Layer 3—IP Routing Command Reference)
auto-discovery
Use auto-discovery to enable a VSI to automatically discover neighbors through BGP and enter auto-discovery VSI view.
Use undo auto-discovery to restore the default.
auto-discovery bgp
undo auto-discovery
A VSI does not use BGP to automatically discover neighbors.
VSI view
bgp: Enables the VSI to automatically discover neighbors through BGP.
After the remote PEs are discovered through BGP, you can use the signaling-protocol command to specify the signaling protocol (LDP or BGP) to establish PWs to the discovered remote PEs.
# Enable VSI aaa to automatically discover neighbors through BGP and enter auto-discovery VSI view.
[Sysname] vsi aaa
[Sysname-vsi-aaa] auto-discovery bgp
[Sysname-vsi-aaa-auto]
display l2vpn pw
display l2vpn vsi
default-pw-id
Use default-pw-id to set the default PW ID for a VSI.
Use undo default-pw-id to restore the default.
default-pw-id default-pw-id
undo default-pw-id
No default PW ID is set for a VSI.
VSI view
default-pw-id: Specifies the default PW ID for the VSI, in the range of 1 to 4294967295.
After you set the default PW ID for a VSI, you do not need to provide a PW ID in the backup-peer and peer commands.
# Set the default PW ID to 200 for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] default-pw-id 200
backup-peer
peer
description
Use description to configure a description for a VSI.
No description is configured for a VSI.
VSI view
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
# Configure a description of vsi for vpn1 for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
display l2vpn vsi
Use display bgp l2vpn auto-discovery to display VPLS PE information discovered by BGP.
display bgp [ instance instance-name ] l2vpn auto-discovery [ peer ip-address { advertised | received } [ statistics ] | route-distinguisher route-distinguisher [ pe-address ip-address [ advertise-info ] ] | statistics ]
instance instance-name: Displays VPLS PE information in a BGP instance. The instance-name argument specifies the BGP instance name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays VPLS PE information in the default BGP instance.
peer ip-address: Displays VPLS PE information advertised to or received from a BGP peer specified by its IP address.
advertised: Displays VPLS PE information advertised to the BGP peer.
received: Displays VPLS PE information received from the BGP peer.
statistics: Displays BGP VPLS PE statistics.
route-distinguisher route-distinguisher: Displays BGP VPLS PE information for the route distinguisher (RD), which is a string of 3 to 21 characters. You can specify an RD in one of the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 101:3.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number, where the AS number must be equal to or greater than 65536. For example, 65536:1.
pe-address ip-address: Displays BGP VPLS PE information for a PE. The ip-address argument specifies the PE address.
advertise-info: Displays BGP VPLS PE advertisement information.
If you do not specify any parameters, this command displays brief information about all VPLS PEs discovered by BGP.
# Display brief information about all VPLS PEs discovered by BGP in the default BGP instance.
<Sysname> display bgp l2vpn auto-discovery
BGP local router ID is 192.168.1.140
Total number of automatically discovered PEs: 3
Route distinguisher: 2:2
PE address Nexthop VPLS ID
* > 1.1.1.9 0.0.0.0 100:100
* >i 2.2.2.9 2.2.2.9 100:100
* >i 3.3.3.9 3.3.3.9 100:100
Status codes |
Status codes: · * – valid—Valid route. · > – best—Best route. · d – damped—Dampened route. · h – history—History route. · s – suppressed—Suppressed route. · S – Stale—Stale route. · i – internal—Internal route. · e – external—External route. |
Origin |
Origin of the label block: · i – IGP—Originated in the AS. · e – EGP—Learned through EGP. · ? – incomplete—Unknown origin. |
# Display detailed information about the VPLS PE that has RD 2:2 and IP address 2.2.2.9 in the default BGP instance.
<Sysname> display bgp l2vpn auto-discovery route-distinguisher 2:2 pe-address 2.2.2.9
BGP local router ID: 192.168.1.140
Local AS number: 100
Total number of automatically discovered PEs: 1
Paths: 1 available, 1 best
Original nexthop: 2.2.2.9
Ext-Community : <RT: 2:2>, <VPLS ID: 100:100>
AS-path : (null)
Origin : igp
Attribute value : localpref 100, pref-val 0
PE address : 2.2.2.9
State : valid, internal, best
Original nexthop |
Original next hop. If the VPLS PE information was obtained from a BGP update, this field displays the next hop address in the received update. |
Ext-Community |
Extended community attribute: · RT—Route Target. · VPLS ID—VPLS instance identifier. |
AS-path |
AS path attribute, which records all ASs that the VPLS PE information passed to prevent routing loops. |
Origin |
Origin of the label block: · igp—Originated in the AS. · egp—Learned through EGP. · incomplete—Unknown origin. |
Attribute value |
Attribute of the VPLS PE information: · MED—Multi-Exit Discriminator attribute. · localpref—Local preference value. · pref-val—Preferred value. · pre—Preference value. |
State |
State of the VPLS PE information: · valid. · internal. · external. · local. · best. |
# Display BGP advertisement information for the specified VPLS PE in the default BGP instance.
<Sysname> display bgp l2vpn auto-discovery route-distinguisher 2:2 pe-address 1.1.1.9 advertise-info
Paths: 1 best
VPLS ID : 100:100
PE address : 1.1.1.9
Advertised to peers (2 in total):
2.2.2.9
3.3.3.9
display bgp l2vpn signaling
Use display bgp l2vpn signaling to display VPLS label block information maintained by BGP.
display bgp [ instance instance-name ] l2vpn signaling [ peer ip-address { advertised | received } [ statistics ] | route-distinguisher route-distinguisher [ site-id site-id [ label-offset label-offset [ advertise-info ] ] ] | statistics ]
instance instance-name: Displays VPLS label block information in a BGP instance. The instance-name argument specifies the BGP instance name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays VPLS label block information in the default BGP instance.
peer ip-address: Displays VPLS label block information advertised to or received from a BGP peer. The ip-address argument specifies the peer address.
advertised: Displays VPLS label block information advertised to the BGP peer.
received: Displays VPLS label block information received from the BGP peer.
statistics: Displays VPLS label block statistics.
route-distinguisher route-distinguisher: Displays BGP VPLS label block information for the route distinguisher (RD), which is a string of 3 to 21 characters. You can specify an RD in one of the following formats:
site-id site-id: Displays BGP VPLS label block information for a site. The site-id argument specifies the site ID. The site ID range is 0 to 65535.
label-offset label-offset: Displays information about the BGP VPLS label block with an offset. The label-offset argument specifies the offset in the range of 0 to 65535.
advertise-info: Displays BGP VPLS label block advertisement information.
If you do not specify any parameters, this command displays brief information about all BGP VPLS label blocks.
# Display brief information about all BGP VPLS label blocks in the default BGP instance.
<Sysname> display bgp l2vpn signaling
BGP local router ID is 192.168.1.135
Total number of label blocks: 2
Site ID LB offset LB range LB base Nexthop
* > 1 0 10 1034 192.1.1.1
* >i 2 0 10 1162 192.3.3.3
Status codes |
Origin |
LB offset |
Offset of the label block. |
LB range |
Size of the label block. |
LB base |
Initial value of the label block. |
# Display detailed information about the BGP VPLS label block that has RD 1:1, site ID 2, and offset 0 in the default BGP instance.
<Sysname> display bgp l2vpn signaling route-distinguisher 1:1 site-id 2 label-offset 0
Route distinguisher: 1:1
Total number of label blocks: 1
Ext-Community : <RT: 1:1>, <L2VPN info: MTU 1500, Encap type BGP VPLS>
AS-path : (null)
Origin : igp
Site ID : 2
LB offset : 0
LB base : 1418
LB range : 10
Original nexthop |
Original next hop. If the label block was obtained from a BGP route update, this field displays the next hop address in that BGP route update. |
Ext-Community |
Extended community attribute: · RT—Route target. · L2VPN info—L2VPN information, including the MTU and encapsulation type. |
AS-path |
AS path attribute, which records all ASs that the label block passed to prevent routing loops. |
Origin |
Attribute value |
Attribute of the label block: · MED—Multi-Exit Discriminator attribute. · localpref—Local preference value. · pref-val—Preferred value. · pre—Preference value. |
LB offset |
LB base |
LB range |
State |
State of the label block: · valid. · internal. · external. · local. · best. |
# Display BGP advertisement information for the specified VPLS label block in the default BGP instance.
<Sysname> display bgp l2vpn signaling route-distinguisher 1:1 site-id 1 label-offset 0 advertise-info
Paths: 1 best
Site ID : 1
LB offset : 0
LB base : 1418
LB range : 10
2.2.2.9
3.3.3.9
LB offset |
LB base |
LB range |
display l2vpn auto-discovery
Use display l2vpn auto-discovery to display information about automatically discovered VPLS PEs.
display l2vpn auto-discovery [ peer ip-address ] [ vsi vsi-name ]
peer ip-address: Displays information about the specified VPLS PE. If you do not specify a PE, this command displays information about all automatically discovered VPLS PEs.
vsi vsi-name: Displays automatically discovered VPLS PEs for a VSI. The vsi-name argument specifies the VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays automatically discovered VPLS PEs for all VSIs.
# Display information about all automatically discovered VPLS PEs.
<Sysname> display l2vpn auto-discovery
Total number of automatically discovered peers: 2
VSI Name: bbb
RD PE_address VPLS ID Nexthop
2:2 1.1.1.9 100:100 1.1.1.9
2:2 3.3.3.9 100:100 3.3.3.9
route-distinguisher
vpls-id
display l2vpn bgp
Use display l2vpn bgp to display VPLS label block information.
display l2vpn bgp [ local | peer ip-address ] [ vsi vsi-name ] [ verbose ]
local: Displays local VPLS label block information.
peer ip-address: Displays VPLS label block information received from a remote peer. The ip-address argument specifies the peer address.
vsi vsi-name: Displays VPLS label block information for a VSI. The vsi-name argument specifies the VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays VPLS label block information for all VSIs.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
If you specify a peer, this command displays both the label block received from the peer and the local label block that matches the received label block.
If you do not specify a peer or local, this command displays label blocks received from all peers and local label blocks that match the received ones.
A local label block matches a received label block if the following condition is met: local label block LO ≤ remote site ID ≤ local label block LO + local label block LR – 1.
# Display brief information about label blocks received from all peers.
<Sysname> display l2vpn bgp
Total number of BGP PWs: 2, 2 up, 0 down
VSI Name: aaa
Rmt Site Offset RD Nexthop In/Out Label State
1 0 1:1 1.1.1.9 1419/1420 Up
3 0 1:1 3.3.3.9 1421/1282 Up
Table 6 Command output
Rmt Site |
ID of the remote site. |
Offset |
# Display detailed information about label blocks received from all peers.
<Sysname> display l2vpn bgp verbose
VSI Name: aaa
Remote Site ID : 1
Offset : 0
RD : 1:1
PW State : Up
Encapsulation : BGP-VPLS
MTU : 1500
Nexthop : 1.1.1.9
Local VC Label : 1419
Remote VC Label : 1420
Link ID : 9
Local Label Block : 1418/10/0
Remote Label Block : 1418/10/0
Local Flow Label : -
Remote Flow Label : -
Export Route Target: 1:1
Table 7 Command output
Local VC Label |
Incoming label of the PW. |
Remote VC Label |
Outgoing label of the PW. |
Link ID |
Link ID of the PW. |
Local Label Block |
Local label block: label base/label range/label-block offset. |
Remote Label Block |
Remote label block: label base/label range/label-block offset. |
Local Flow Label |
This field is not supported in the current software version. Flow label capability of the local PE: · Both—Flow label sending and receiving capabilities. · Send—Flow label sending capability. · Recv—Flow label receiving capability. This field display a hyphen (-) if the flow label feature is disabled. |
Remote Flow Label |
This field is not supported in the current software version. Flow label capability of the remote PE: · Both—Flow label sending and receiving capabilities. · Send—Flow label sending capability. · Recv—Flow label receiving capability. This field display a hyphen (-) if the flow label feature is disabled. |
Export Route Target |
Route target of the remote label block. |
# Display brief information about all local label blocks.
<Sysname> display l2vpn bgp local
VSI Name: aaa
Site Offset Range Label Base RD
2 0 10 1418 1:1
Table 8 Command output
Offset |
Range |
Range of the label block. |
Label Base |
RD |
RD of the label block. If no RD is configured, this field displays a hyphen (-). |
# Display detailed information about all local label blocks.
<Sysname> display l2vpn bgp local verbose
VSI Name: aaa
Site ID : 2
Offset : 0
RD : 1:1
Range : 10
Label Base : 1418
Link ID : 8,9,10,11,12,13,14,15,16
Table 9 Command output
Offset |
RD |
Range |
Label Base |
Link ID |
Link IDs of the PWs established using the label block. |
display l2vpn pw
display l2vpn forwarding
Use display l2vpn forwarding to display L2VPN forwarding information.
display l2vpn forwarding { ac | pw } [ vsi vsi-name ] [ slot slot-number ] [ verbose ]
ac: Displays AC forwarding information.
pw: Displays PW forwarding information.
vsi vsi-name: Displays L2VPN forwarding information for a VSI. The vsi-name argument specifies the VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays L2VPN forwarding information for all VSIs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays L2VPN forwarding information for the master device.
# Display brief AC forwarding information for all VSIs.
<Sysname> display l2vpn forwarding ac
Total number of VSIs: 1
Total number of ACs: 3
AC VSI Name Link ID
XGE1/0/1 srv1 test 3
XGE1/0/1 srv2 test 4
Table 10 Command output
Total number of VSIs |
Total number of VSIs, including VSIs that are not bound to any ACs. |
AC |
AC type: Layer 2 interface and Ethernet service instance. |
Link ID |
Link ID of the AC in the VSI. |
# Display detailed AC forwarding information for all VSIs.
<Sysname> display l2vpn forwarding ac verbose
VSI Name: vpls2
Interface: XGE1/0/3 Service Instance: 4
Link ID : 1
Access Mode : VLAN
Encapsulation : s-vid 10
Bandwidth : Unlimited
Type : Manual
Table 11 Command output
Service Instance |
Ethernet service instance ID. |
Link ID |
Access Mode |
AC access mode, which is VLAN. |
Encapsulation |
Match criterion of the Ethernet service instance. This field is displayed only when the AC is an Ethernet service instance on a Layer 2 interface. |
Bandwidth |
Maximum bandwidth in kbps for traffic on the AC. If this field displays Unlimited, the traffic bandwidth of the AC is not limited. |
Type |
Ethernet service instance type. This field can only be Manual, which indicates that the Ethernet service instance is manually created. |
# Display brief PW forwarding information for all VSIs.
<Sysname> display l2vpn forwarding pw
Total number of PWs: 2, 2 up, 0 blocked, 0 down
VSI Name In/Out Label NID Link ID State
aaa 1272/1275 1034 8 Up
aaa 1271/1273 1035 9 Up
Table 12 Command output
Total number of VSIs, including VSIs that do not contain PWs. |
In/Out Label |
Incoming and outgoing labels of the PW. A hyphen (-) indicates that no label exists. |
NID |
NHLFE ID for the public tunnel that carries the PW. If equal-cost tunnels are available, this field displays multiple NIDs. If no tunnel is available, this field displays None. |
Link ID |
Link ID of the PW in the VSI. |
State |
PW state: Up, Down, or Blocked. Blocked indicates that the PW is blocked. |
# Display detailed PW forwarding information for all VSIs.
<Sysname> display l2vpn forwarding pw verbose
VSI Name: aaa
Link ID: 8
PW Type : VLAN PW State : Up
In Label : 1272 Out Label: 1275
MTU : 1500
PW Attributes : Main
VCCV CC : -
VCCV BFD : Fault Detection with BFD
Flow Label : -
Tunnel Group ID : 0x960000000
Tunnel NHLFE IDs: 1034
Table 13 Command output
Link ID |
PW Type |
Data encapsulation type of the PW. |
PW State |
In Label |
Incoming label of the PW. A hyphen (-) indicates that no label exists. |
Out Label |
Outgoing label of the PW. A hyphen (-) indicates that no label exists. |
PW Attributes |
PW attribute: · Main—The PW is the primary PW. · No-split-horizon—Split horizon forwarding is disabled. |
VCCV CC |
This field is not supported in the current software version. VCCV CC type: Router-Alert—MPLS Router Alert Label. This field displays a hyphen (-) if no VCCV CC type is specified. |
VCCV BFD |
This field is not supported in the current software version. VCCV BFD type: · Fault Detection with BFD—BFD packets use IP/UDP encapsulation (with IP/UDP headers). · Fault Detection with Raw-BFD—BFD packets use PW-ACH encapsulation (without IP/UDP headers). This field displays a hyphen (-) if BFD is not used to verify PW connectivity. |
Flow Label |
This field is not supported in the current software version. Flow label capability: · Both—Flow label sending and receiving capabilities. · Send—Flow label sending capability. · Recv—Flow label receiving capability. This field display a hyphen (-) if the flow label feature is disabled. |
Tunnel Group ID |
ID of the tunnel group for the PW. |
Tunnel NHLFE IDs |
NHLFE ID of the public tunnel that carries the PW. If equal-cost tunnels are available, this field displays multiple NIDs. If no tunnel is available, this field displays None. |
display l2vpn ldp
Use display l2vpn ldp to display LDP PW label information.
display l2vpn ldp [ peer ip-address [ pw-id pw-id | vpls-id vpls-id ] | vsi vsi-name ] [ verbose ]
peer ip-address: Displays information about PW labels advertised by a peer PE through LDP. The ip-address argument specifies the LSR ID of the peer PE. If you do not specify a peer PE, this command displays information about LDP PW labels advertised by all peer PEs.
pw-id pw-id: Displays FEC 128 LDP PW label information for a PW. The pw-id argument specifies the PW ID in the range of 1 to 4294967295. If you specify the peer ip-address option without the pw-id pw-id option, this command displays all LDP PW label information advertised by the specified peer PE.
vpls-id vpls-id: Displays FEC 129 LDP PW label information for a VPLS instance. The vpls-id argument specifies the VPLS instance ID, a string of 3 to 21 characters. You can specify a VPLS ID in one of the following formats:
vsi vsi-name: Displays LDP PW label information for a VSI. The vsi-name argument specifies the VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays LDP PW label information for all VSIs.
LDP advertises FEC-to-PW label bindings in the following ways:
· After you specify a remote PE with the peer command, LDP advertises an FEC 128-to-PW label binding to the remote PE.
· After BGP discovers a remote PE, LDP advertises an FEC 129-to-PW label binding to the remote PE.
This command can display PW labels as follows:
· If you specify the pw-id pw-id option, this command displays PW labels for FEC 128.
· If you specify the vpls-id vpls-id option, this command displays PW labels for FEC 129.
· If you do not specify pw-id pw-id or vpls-id vpls-id, this command displays PW labels for both FEC 128 and FEC 129.
# Display brief information about all PW labels advertised by LDP.
<Sysname> display l2vpn ldp
Total number of LDP PWs: 2, 2 up, 0 down
Peer PW ID/VPLS ID In/Out Label State Owner
192.3.3.3 1001 775125/775126 Up vpls1
192.3.3.3 1003 775117/775122 Up vpls3
Table 14 Command output
PW ID/VPLS ID |
PW ID for FEC 128, or VPLS ID of the PE for FEC 129. |
State |
PW state: Up or Down. |
Owner |
Name of the VSI to which the PW belongs. |
# Display detailed information about all PW labels advertised by LDP.
<Sysname> display l2vpn ldp verbose
Peer: 2.2.2.9 PW ID: 500
VSI Name: ccc
PW State: Up
PW Status Communication: Notification method
PW Preferential Forwarding Status Bit: Process
PW ID FEC (Local/Remote):
PW Type : VLAN/VLAN
Group ID : 0/0
Label : 1552/1552
Control Word: Disabled/Disabled
VCCV CV Type: -/-
VCCV CC Type: -/-
Flow Label : -/-
MTU : 1500/1500
PW Status : PW forwarding/PW forwarding
Peer: 2.2.2.9 VPLS ID: 100:100
VSI Name: bbb
PW State: Up
PW Preferential Forwarding Status Bit: Ignore
Local AII : (1.1.1.9, 2.2.2.9)
Remote AII : (2.2.2.9, 1.1.1.9)
PW Type : VLAN/VLAN
Group ID : 0/0
Label : 1553/1553
VCCV CV Type: -/-
VCCV CC Type: -/-
Flow Label : -/-
MTU : 1500/1500
Table 15 Command output
PW Status Communication |
PW status communication method: · Notification method—Notifies the PW status through Notification messages. · Label withdraw method—Assigns a PW label to the PW when the AC associated with PW comes up, and withdraws the PW label when the AC goes down. |
PW Preferential Forwarding Status Bit |
PW state processing mode: · Process—Process the received PW states. · Ignore—Ignore the received PW states. |
PW ID FEC (Local/Remote) |
PW ID FEC information advertised from the local PE to the peer PE/PW ID FEC information advertised from the peer PE to the local PE. |
Control Word |
This field is not supported in the current software version. Whether the control word feature is enabled. |
VCCV CV Type |
This field is not supported in the current software version. VCCV CV type: · LSP Ping—Uses MPLS LSP ping to verify PW connectivity. · BFD—Uses BFD to verify PW connectivity. BFD packets use IP/UDP encapsulation (with IP/UDP headers). · Raw-BFD—Uses BFD to verify PW connectivity. BFD packets use PW-ACH encapsulation (without IP/UDP headers). This field displays a hyphen (-) if VCCV is not performed on the PW. |
VCCV CC Type |
This field is not supported in the current software version. VCCV CC type: Router-Alert—MPLS Router Alert Label. This field displays a hyphen (-) if no VCCV CC type is specified. VCCV is an MPLS OAM technology. For more information about VCCV, see MPLS Configuration Guide. |
Flow Label |
MTU |
Maximum transmission unit of the VSI. |
PW Status |
PW status: · PW forwarding—PW is ready for packet forwarding. · PW not forwarding—PW is not ready for packet forwarding. · AC receive fault—AC cannot receive packets. · AC transmit fault—AC cannot send packets. · PW receive fault—PW cannot receive packets. · PW transmit fault—PW cannot send packets. · PW standby—The PW is in standby state. · Unknown—Unknown protocol. |
VPLS ID |
ID of the VPLS instance. |
Local AII |
Source Attachment Individual Identifier (SAII) and Target Attachment Individual Identifier (TAII) advertised to the remote PE. |
Remote AII |
SAII and TAII received from the remote PE. |
display l2vpn mac-address
Use display l2vpn mac-address to display MAC address table information for VSIs.
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count | verbose ]
vsi vsi-name: Displays MAC address table information for a VSI. The vsi-name argument specifies the VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC address table information for all VSIs.
dynamic: Displays dynamically generated MAC address entries. If you do not specify this keyword, the command displays all types of MAC address entries. The device supports only dynamic MAC address entries in the current software version.
count: Displays the number of MAC address entries. If you do not specify this keyword, the command displays information about MAC address entries.
verbose: Displays detailed information about MAC address entries. If you do not specify this keyword, the command displays brief information about MAC address entries.
# Display MAC address table information for all VSIs.
<Sysname> display l2vpn mac-address
MAC Address : 0001-0001-0001
VSI Name : aaa
State : Dynamic
Link ID/Name Aging
XGE1/0/1 NotAging
MAC Address : 0001-0001-0002
VSI Name : aaa
State : Dynamic
Link ID/Name Aging
XGE1/0/2 NotAging
--- 2 mac address(es) found ---
# Display the total number of MAC address entries of all VSIs.
<Sysname> display l2vpn mac-address count
Table 16 Command output
State |
MAC address type. The MAC address type can only be Dynamic in the current software version, which indicates that the MAC address is dynamically learned. |
For a local site's MAC address, this field displays the name of the interface on which the Ethernet service instance is created. For a remote site's MAC address, this field displays the link ID of the PW from which the MAC address is learned. |
Aging |
Whether the MAC address entry will be aged. |
XX mac address(es) found |
Total number of MAC address entries of the VSI. |
# Display detailed information about MAC address entries of all VSIs.
<Sysname> display l2vpn mac-address verbose
MAC Address : 0000-0000-000b
VSI Name : vpn1
VXLAN ID : -
Interface : XGE1/0/1
Link ID : 1
State : Dynamic
Aging : Aging
Table 17 Command output
VSI Name |
Name of the VSI to which the MAC address belongs. |
VXLAN ID |
VPLS does not support this field. |
For a local site's MAC address, this field displays the name of the interface on which the Ethernet service instance is created. For a remote site's MAC address, this field displays a hyphen (-). |
Link ID |
Link ID of the AC or PW in the VSI. |
State |
Aging |
reset l2vpn mac-address
display l2vpn pw
Use display l2vpn pw to display L2VPN PW information.
display l2vpn pw [ vsi vsi-name ] [ protocol { bgp | evpn | ldp | static } ] [ verbose ]
vsi vsi-name: Displays L2VPN PW information for a VSI. The vsi-name argument specifies the VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays L2VPN PW information for all VSIs.
protocol: Displays PWs created by a signaling protocol. If you do not specify a protocol, this command displays PWs created by all protocols.
bgp: Displays BGP PW information.
evpn: Displays EVPN PW information.
ldp: Displays LDP PW information, including PWs for FEC 128 (LDP PWs) and FEC 129 (BGP auto-discovery LDP PWs).
static: Displays static PW information.
# Display brief information about all PWs.
<Sysname> display l2vpn pw
N - no split horizon, A - administration, ABY - ac-bypass
PBY - pw-bypass
Total number of PWs: 5
5 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
VSI Name: aaa
Peer PWID/RmtSite/SrvID In/Out Label Proto Flag Link ID State
2.2.2.9 2 1420/1419 BGP M 9 Up
3.3.3.9 3 1421/1281 BGP M 10 Up
VSI Name: bbb
2.2.2.9 - 1553/1553 LDP M 8 Up
3.3.3.9 - 1554/1416 LDP M 9 Up
VSI Name: ccc
2.2.2.9 500 1552/1552 LDP M 8 Up
Table 18 Command output
PWID/RmtSite/SrvID |
This field displays the following: · PW ID for an LDP PW (FEC 128) or a static PW. · A hyphen (-) for a BGP auto-discovery LDP PW (FEC 129). · Remote site ID for a BGP PW. · Remote service ID for an EVPN PW.This value is not supported in the current software version. · A hyphen (-) for an EVPN VPLS PW.This value is not supported in the current software version. |
Proto |
Protocol used to establish the PW: LDP, Static, or BGP. |
Flag |
PW attribute flag: · M—Primary PW. · B—Backup PW. · E—ECMP PW. (This value does not apply to VPLS.) · BY—Bypass PW. (This value does not apply to VPLS.) · N—Split horizon forwarding is disabled. · A—The PW is an administration PW. · ABY—The PW is a bypass PW for AC bypass. (This value does not apply to VPLS.) · PBY—The PW is a bypass PW for PW bypass. (This value does not apply to VPLS.) |
Link ID |
State |
PW state: · Up—The PW is available. · Down—The PW is not available. · Blocked—The PW is a backup PW. · Idle—The incoming label of the PW is not available. · Dup—The incoming label of the static PW is occupied by a static LSP or a static CRLSP. |
# Display detailed information about all L2VPN PWs.
<Sysname> display l2vpn pw verbose
VSI Name: aaa
Peer: 2.2.2.9 Remote Site: 2
Signaling Protocol : BGP
Link ID : 9 PW State : Up
In Label : 1420 Out Label: 1419
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x800000960000000
Tunnel NHLFE IDs : 1038
Admin PW : -
VSI Name: bbb
Signaling Protocol : LDP
Link ID : 8 PW State : Up
In Label : 1553 Out Label: 1553
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Admin PW : -
VSI Name: ccc
In Label : 1552 Out Label: 1552
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Admin PW : -
Table 19 Command output
Peer |
IP address of the peer PE to which the PW is destined. |
Signaling Protocol |
Protocol used to establish the PW: LDP, Static, EVPN, or BGP. |
Link ID |
PW State |
PW state: · Up—The PW is available. · Down—The PW is not available. · Blocked—The PW is a backup PW. · Idle—The incoming label of the PW is not available. · Duplicate—The incoming label of the static PW is occupied by a static LSP or a static CRLSP. |
Wait to Restore Time |
Wait time to switch traffic from the backup PW to the primary PW when the primary PW recovers, in seconds. If the switchover is disabled, this field displays Infinite. This field is available when both primary and backup PW exist, and is displayed only for the primary PW. |
Remaining Time |
Remaining wait time for traffic switchover, in seconds. This field is displayed after the switchover wait timer is started. |
MTU |
Negotiated MTU of the PW. |
PW Attributes |
VCCV CC |
VCCV BFD |
Flow Label |
Tunnel Group ID |
Tunnel NHLFE IDs |
VPLS ID |
Remote Site |
Use display l2vpn service-instance to display Ethernet service instance information.
interface interface-type interface-number: Displays Ethernet service instance information for the specified Layer 2 Ethernet interface or Layer 2 aggregate interface. If you do not specify an interface, this command displays Ethernet service instance information for all Layer 2 Ethernet interfaces and Layer 2 aggregate interfaces.
service-instance instance-id: Displays information about the Ethernet service instance specified by its ID. The instance ID is in the range of 1 to 4096. If you specify interface interface-type interface-number without this option, the command displays information about all Ethernet service instances on the specified Layer 2 Ethernet interface or Layer 2 aggregate interface.
# Display brief information about all Ethernet service instances.
<Sysname> display l2vpn service-instance
Total number of service-instances: 2, 2 up, 0 down
Total number of ACs: 2, 2 up, 0 down
Interface ID Owner LinkID State Type
XGE1/0/3 1 vpls1 1 Up VSI
XGE1/0/3 2 vpls2 1 Up VSI
Table 20 Command output
Layer 2 Ethernet interface or Layer 2 aggregate interface. |
ID |
Owner |
Name of the VSI bound to the Ethernet service instance. This field is empty if no VSI is bound. |
LinkID |
State |
Ethernet service instance state. |
Type |
L2VPN type of the Ethernet service instance: VSI or VPWS. |
# Display detailed information about all Ethernet service instances on Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/3.
<Sysname> display l2vpn service-instance interface ten-gigabitethernet 1/0/3 verbose
Interface: XGE1/0/3
Service Instance: 1
Type : Manual
Encapsulation : s-vid 16
Bandwidth : -
VSI Name : vpls1
Link ID : 1
State : Up
Statistics : Disabled
Table 21 Command output
Service Instance |
Type |
Encapsulation |
Match criteria of the Ethernet service instance. If no match criteria are configured, the field is not displayed. |
Bandwidth |
Maximum bandwidth in kbps for traffic of the AC. If this field displays a hyphen (-), the traffic bandwidth of the AC is not limited. |
VSI Name |
Name of the VSI bound to the Ethernet service instance. |
Link ID |
State |
Ethernet service instance state: Up and Down. |
Statistics |
This field is not supported in the current software version. Packet statistics state: · Enabled—Packet statistics is enabled for the Ethernet service instance. · Disabled—Packet statistics is disabled for the Ethernet service instance. |
service-instance
display l2vpn vsi
Use display l2vpn vsi to display VSI information.
display l2vpn vsi [ name vsi-name ] [ verbose ]
name vsi-name: Displays information about a VSI. The vsi-name argument specifies the VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays information about all VSIs.
# Display brief information about all VSIs.
<Sysname> display l2vpn vsi
Total number of VSIs: 2, 1 up, 1 down, 0 admin down
VSI Name VSI Index MTU State
vpls1 0 1500 Up
vpls2 1 1500 Down
Table 22 Command output
State |
VSI state: · Up. · Down. · Admin down—The VSI is manually brought down by using the shutdown command. |
# Display detailed information about all VSIs.
<Sysname> display l2vpn vsi verbose
VSI Name: vpls1
VSI Index : 0
VSI Description : vsi for vpls1
VSI State : Up
MTU : 1500
Bandwidth : -
Broadcast Restrain : -
Multicast Restrain : -
Unknown Unicast Restrain: -
MAC Learning : Enabled
MAC Table Limit : -
MAC Learning rate : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : -
LDP PWs:
Peer PW ID Link ID State
192.3.3.3 1 8 Up
192.3.3.3 1001 8 Blocked
BGP PWs:
Peer Remote Site Link ID State
192.4.4.4 1 9 Up
ACs:
AC Link ID State Type
XGE1/0/3 srv1 1 Up Manual
Table 23 Command output
VSI Description |
If no description is configured for the VSI, this field is not displayed. |
VSI State |
Bandwidth |
This field is not supported in the current software version. Maximum bandwidth for traffic in the VSI, in kbps. This field displays Unlimited if no limit is set on the traffic in the VSI. This field displays a hyphen (-) if the VSI does not support setting the maximum bandwidth for traffic. |
Broadcast Restrain |
This field is not supported in the current software version. Broadcast suppression bandwidth for the VSI, in kbps. This field displays Unlimited if no limit is set on the broadcast traffic in the VSI. This field displays a hyphen (-) if the VSI does not support setting the maximum bandwidth for broadcast traffic. |
Multicast Restrain |
This field is not supported in the current software version. Multicast suppression bandwidth for the VSI, in kbps. This field displays Unlimited if no limit is set on the multicast traffic in the VSI. This field displays a hyphen (-) if the VSI does not support setting the maximum bandwidth for mulicast traffic. |
Unknown Unicast Restrain |
This field is not supported in the current software version. Unknown unicast suppression bandwidth for the VSI, in kbps. This field displays Unlimited if no limit is set on the unknown unicast traffic in the VSI. This field displays a hyphen (-) if the VSI does not support setting the maximum bandwidth for unknown unicast traffic. |
MAC Table Limit |
This field is not supported in the current software version. Maximum number of MAC addresses that the VSI can learn. This field displays Unlimited if no limit is set on the number of MAC addresses that the VSI can learn. |
MAC Learning Rate |
This field is not supported in the current software version. MAC address learning interval of the VSI. |
Drop Unknown |
This field is not supported in the current software version. Whether the VSI drops packets with unknown source MAC addresses after it has leaned the maximum number of MAC addresses: · Enabled—Drops packets with unknown source MAC addresses. · Disabled—Forwards packets with unknown source MAC addresses. |
Flooding |
Statistics |
This field is not supported in the current software version. VSI statistics state, Enabled or Disabled. |
VXLAN ID |
State |
PW state: Up, Down, Blocked, or BFD Defect. |
AC |
Type |
vsi
encapsulation
Use encapsulation to configure a packet match criterion for an Ethernet service instance.
Use undo encapsulation to restore the default.
encapsulation s-vid vlan-id
encapsulation untagged
undo encapsulation
No packet match criterion is configured for an Ethernet service instance.
Ethernet service instance view
s-vid: Matches packets with the specified outer VLAN IDs.
vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
untagged: Matches any packets that do not have a VLAN tag.
The match criteria of different Ethernet service instances cannot overlap on an interface.
You cannot repeat the encapsulation command to modify the match criterion of an Ethernet service instance. To change the match criterion, first execute the undo encapsulation command to remove the original match criterion.
After you remove the packet match criterion of an Ethernet service instance, the mapping between the Ethernet service instance and the VSI is removed automatically.
# Configure Ethernet service instance 1 on Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/1 to match packets that have an outer VLAN ID of 111.
[Sysname-Ten-GigabitEthernet1/0/1] service-instance 1
[Sysname-Ten-GigabitEthernet1/0/1-srv1] encapsulation s-vid 111
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
You must enable L2VPN before configuring other L2VPN settings.
# Enable L2VPN.
[Sysname] l2vpn enable
mac-learning enable
Use mac-learning enable to enable MAC address learning for a VSI.
Use undo mac-learning enable to disable MAC address learning for a VSI.
mac-learning enable
MAC address learning is enabled for a VSI.
VSI view
If MAC address learning is disabled for a VSI, the VSI does not learn the source MAC addresses of received packets.
# Disable MAC address learning for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] undo mac-learning enable
display l2vpn vsi
mtu
Use mtu to set an MTU for a VSI.
mtu size
undo mtu
A VSI has an MTU of 1500 bytes.
VSI view
size: Specifies an MTU value. The value range is 300 to 65535.
The VSI MTU specifies the maximum length of a packet transmitted on a PW, including the PW label, and network layer packet.
When LDP is used to create PWs, all PEs in a VPLS instance must have the same MTU configured for the VSI.
# Set the MTU to 1400 bytes for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] mtu 1400
display l2vpn vsi
peer
Use peer in VSI LDP signaling view to configure a VSI LDP PW and enter its view, or enter the view of an existing VSI LDP PW.
Use peer in VSI static configuration view to configure a VSI static PW and enter its view, or enter the view of an existing VSI static PW.
Use undo peer to delete a VPLS PW.
VSI LDP signaling view:
peer ip-address [ pw-id pw-id ] [ ignore-standby-state | no-split-horizon | tunnel-policy tunnel-policy-name ] *
undo peer ip-address pw-id pw-id
VSI static configuration view:
peer ip-address [ pw-id pw-id ] [ in-label label-value out-label label-value [ no-split-horizon | tunnel-policy tunnel-policy-name ] * ]
No PWs exist for VPLS.
ip-address: Specifies the LSR ID of the peer PE.
pw-id pw-id: Specifies a PW ID for the PW, in the range of 1 to 4294967295.
in-label label-value: Specifies the incoming label of the PW. The value range is 16 to 1023.
out-label label-value: Specifies the outgoing label of the PW. The value range is 16 to 1048575.
ignore-standby-state: Ignores the PW active/standby status bit received from the remote PE. This keyword is applicable only to LDP PWs.
no-split-horizon: Disables split horizon forwarding for the PW. By default, a PW must use the split horizon forwarding scheme to forward packets.
tunnel-policy tunnel-policy-name: Specifies a tunnel policy by its name, a case-insensitive string of 1 to 19 characters. If you do not specify a tunnel policy, the PW uses the default tunnel policy.
A PE uses the PW Preferential Forwarding Status bit in LDP messages to advertise the local PWs' active/standby states. When the bit is set, it indicates that the local PW is in standby state. When the bit is cleared, it indicates that the local PW is in active state.
In master/slave mode of PW redundancy, the slave PE selects the forwarding PW among the set of redundant PWs based on the status bit received from the master PE. If you specify the ignore-standby-state keyword, the PE ignores the status bit received from the master PE and uses the primary PW to forward packets as long as the primary PW is up.
To create a static PW, you must specify the incoming and outgoing labels. To enter VSI static PW view of an existing static PW, you do not need to specify the incoming and outgoing labels.
The PW ID for a PW must be the same on the PEs at the ends of the PW.
On a PE, the LSR ID of the peer PE and the PW ID uniquely identify a PW. The peer LSR ID and PW ID combination of a PW must be unique among all VPLS PWs and cross-connect PWs.
If both the default PW ID in the default-pw-id command and a PW ID in the peer command are configured, the PW ID in the peer command is used. If only the default PW ID is configured, the default PW ID is used. If no default PW ID is configured, you must provide a PW ID in the peer command.
When you add a static PW, you must make sure that static PW uses a different incoming label than an existing static LSP or static CRLSP. If the incoming label is duplicated, you cannot make the static PW take effect by changing the incoming label of the static LSP or CRLSP. Instead, you must delete the static PW and then reconfigure the static PW with an unused incoming label.
# Configure an LDP PW for VSI vpn1 and enter VSI LDP PW view: specify the peer PE address as 4.4.4.4, set the PW ID to 200, and disable split horizon forwarding for the PW.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] pwsignaling ldp
[Sysname-vsi-vpn1-ldp] peer 4.4.4.4 pw-id 200 no-split-horizon
[Sysname-vsi-vpn1-ldp-4.4.4.4-200]
# Configure a static PW for VSI vpn1 and enter VSI static PW view: specify the peer PE address as 5.5.5.5, set the PW ID to 200, incoming label to 100, and outgoing label to 200, and disable split horizon forwarding for the PW.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] pwsignaling static
[Sysname-vsi-vpn1-static] peer 5.5.5.5 pw-id 200 in-label 100 out-label 200 no-split-horizon
[Sysname-vsi-vpn1-static-5.5.5.5-200]
default-pw-id
display l2vpn ldp
display l2vpn pw
tunnel-policy
peer auto-discovery
Use peer auto-discovery to enable BGP to exchange VPLS PE information with the specified peers.
Use undo peer auto-discovery to disable BGP from exchanging VPLS PE information with the specified peers.
peer { group-name | ip-address [ mask-length ] } auto-discovery [ non-standard ]
undo peer { group-name | ip-address [ mask-length ] } auto-discovery
BGP can exchange VPLS PE information with a BGP L2VPN peer or peer group through RFC 6074 MP_REACH_NLRI.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The specified peer group must have been created.
ip-address: Specifies a peer by its IP address. The specified peer must have been created.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP to exchange VPLS PE information with all dynamic peers in the subnet.
non-standard: Uses non-standard MP_REACH_NLRI to exchange VPLS PE information. If you do not specify this keyword, RFC 6074 MP_REACH_NLRI is used to exchange VPLS PE information.
L2VPN can use MP-BGP to exchange VPLS PE information and find remote PEs in the same VPLS instance.
To enable BGP to exchange VPLS PE information with the specified peers through RFC 6074 MP_REACH_NLRI, you can also use the peer enable command in BGP L2VPN address family view. To disable the capability, use the undo peer auto-discovery command.
# Enable BGP to exchange VPLS PE information with the peer 3.3.3.9 through RFC 6074 MP_REACH_NLRI.
[Sysname] bgp 100
[Sysname-bgp-default-l2vpn] peer 3.3.3.9 auto-discovery
peer signaling
Use peer signaling to enable BGP to exchange label block information with the specified peers.
Use undo peer signaling to disable BGP to exchange label block information with the specified peers.
peer { group-name | ip-address [ mask-length ] } signaling
undo peer { group-name | ip-address [ mask-length ] } signaling
BGP can exchange label block information with a BGP L2VPN peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP to exchange label block information with all dynamic peers in the subnet.
L2VPN uses MP-BGP to exchange label blocks when creating a BGP PW.
To enable BGP to exchange label block information with the specified peers, you can also use the peer enable command in BGP L2VPN address family view. To disable the capability, use the undo peer signaling command.
# Enable BGP to exchange label block information with peer 3.3.3.9.
[Sysname] bgp 100
[Sysname-bgp-default-l2vpn] peer 3.3.3.9 signaling
policy vpn-target
Use policy vpn-target to enable route target-based filtering of incoming BGP L2VPN information.
Use undo policy vpn-target to disable route target-based filtering of incoming BGP L2VPN information.
policy vpn-target
Route target-based filtering of incoming BGP L2VPN information is enabled.
If route target-based filtering is enabled, L2VPN accepts only the incoming BGP L2VPN information whose export route target attribute matches the local import route target attribute. If route target-based filtering is disabled, L2VPN accepts all incoming BGP L2VPN information.
To establish a BGP PW between two MP-IBGP peers that use a route reflector, you must disable route target-based filtering of incoming BGP L2VPN information on the route reflector.
# Disable route target-based filtering of incoming BGP L2VPN information.
[Sysname] bgp 100
[Sysname-bgp-default-l2vpn] undo policy vpn-target
pwsignaling
Use pwsignaling to specify a PW signaling protocol for a VSI, and enter the VSI signaling protocol view.
Use undo pwsignaling to remove the specified PW signaling protocol for a VSI.
pwsignaling { ldp | static }
undo pwsignaling { ldp | static }
No PW signaling protocol is specified for a VSI.
VSI view
ldp: Establishes PWs through LDP (FEC 128) and enters VSI LDP signaling view.
static: Establishes PWs statically and enters VSI static configuration view.
# Configure VSI vpn1 to use LDP to establish LDP PWs, and enter VSI LDP signaling view.
[Sysname] vsi vpn1
display l2vpn pw
Use reset l2vpn mac-address to clear MAC address entries for VSIs.
reset l2vpn mac-address [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears MAC address entries for all VSIs.
When a VSI learns wrong MAC addresses or has learned the maximum number of MAC addresses, use this command to clear MAC addresses for the VSI. Then, the VSI can learn MAC addresses again.
# Clear MAC address entries for VSI vpn1.
<Sysname> reset l2vpn mac-address vsi vpn1
display l2vpn mac-address vsi
route-distinguisher
Use route-distinguisher to configure a route distinguisher (RD) for an auto-discovery VSI.
Use undo route-distinguisher to restore the default.
No RD is configured for an auto-discovery VSI.
Auto-discovery VSI view
route-distinguisher: Specifies an RD, a string of 3 to 21 characters. An RD can be in one of the following formats:
VPLS uses RDs to differentiate the sites with the same site ID but in different VPNs.
BGP adds the configured RD before the site ID. The RD and the site ID uniquely identify a VPN site.
The configured RD applies to both BGP neighbor auto-discovery and VPLS label block advertisement.
You cannot configure the same RD for different BGP VSIs.
To modify an RD, execute the undo route-distinguisher command to remove the RD and then execute the route-distinguisher command.
# Configure RD 22:1 for BGP VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa-auto] route-distinguisher 22:1
rr-filter
Use rr-filter to create a route reflector (RR) reflection policy.
Use undo rr-filter to restore the default.
undo rr-filter
An RR does not filter reflected L2VPN information.
ext-comm-list-number: Specifies an extended community list number in the range of 1 to 65535.
After this command is executed, only the L2VPN information that is permitted by the specified extended community list is reflected.
By configuring different RR reflection policies on RRs in a cluster, you can implement load balancing among the RRs.
For more information about extended community lists, see Layer 3—IP Routing Configuration Guide.
# Configure the RR to reflect only the BGP L2VPN information that is permitted by extended community list 10.
[Sysname] bgp 100
[Sysname-bgp-default-l2vpn] rr-filter 10
ip extcommunity-list (Layer 3—IP Routing Command Reference)
service-instance
Use service-instance to create an Ethernet service instance on an interface and enter its view, or enter the view of an existing Ethernet service instance.
Use undo service-instance to delete an Ethernet service instance on an interface.
undo service-instance instance-id
No Ethernet service instances exist.
instance-id: Specifies an ID for the Ethernet service instance, in the range of 1 to 4096.
# Create Ethernet service instance 1 on Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/1, and enter Ethernet service instance 1 view.
shutdown
Use shutdown to disable a VSI.
Use undo shutdown to enable a VSI.
shutdown
A VSI is enabled.
VSI view
After you disable a VSI, the VSI cannot provide VPLS services.
Use the shutdown command when you want to temporarily disable VPLS. When a VSI is disabled, you can still configure the VSI. After the configuration, use the undo shutdown command to enable the VSI. The VSI will provide VPLS services using the new settings.
# Disable VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
display l2vpn vsi
signaling-protocol
Use signaling-protocol to specify a signaling protocol and enter the specified signaling view. The specified signaling protocol is used to establish PWs to the automatically discovered remote PEs.
Use undo signaling-protocol to restore the default.
signaling-protocol { bgp | ldp }
No signaling protocol is specified.
bgp: Specifies the signaling protocol as BGP and enters auto-discovery VSI BGP signaling view.
ldp: Specifies the signaling protocol as LDP and enters auto-discovery VSI LDP signaling view.
You can specify only one signaling protocol in the same auto-discovery VSI view. To modify the signaling protocol, execute the undo signaling-protocol command to remove the signaling protocol and then execute the signaling-protocol command.
# Use LDP (FEC 129) to establish a PW to a remote PE discovered by BGP and enter auto-discovery VSI LDP signaling view.
[Sysname] vsi aaa
[Sysname-vsi-aaa-auto] signaling-protocol ldp
[Sysname-vsi-aaa-auto-ldp]
display l2vpn pw
display l2vpn vsi
site
Use site to create a local site.
Use undo site to delete a local site.
site site-id [ range range-value ] [ default-offset default-offset ]
undo site site-id
No sites exist.
Auto-discovery VSI BGP signaling view
site-id: Specifies a local site ID. The value range for this argument is 0 to 512.
range range-value: Specifies the maximum number of sites in a VPLS instance, in the range of 2 to 1 + the maximum number of site-id. The default value is 10.
default-offset default-offset: Specifies the start site ID, 0 or 1. The default value is 0.
You can create multiple local sites for a VSI.
You can use the site command to increase the range value for an existing site. You cannot decrease the range value for an existing site with the site command. To decrease the range value, execute the undo site command to delete the site and then execute the site command.
You cannot modify the default-offset for a site with the site command. To modify it, execute the undo site command to delete the site and then execute the site command.
# Create site 1, configure the VPLS instance to contain a maximum of 30 sites, and set the start site ID to 0 for VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa-auto] signaling-protocol bgp
[Sysname-vsi-aaa-auto-bgp] site 1 range 30 default-offset 0
display l2vpn pw
display l2vpn vsi
snmp-agent trap enable l2vpn
Use snmp-agent trap enable l2vpn to enable SNMP notifications for L2VPN PW.
Use undo snmp-agent trap enable l2vpn to disable SNMP notifications for L2VPN PW.
snmp-agent trap enable l2vpn [ pw-delete | pw-switch | pw-up-down ] *
undo snmp-agent trap enable l2vpn [ pw-delete | pw-switch | pw-up-down ] *
SNMP notifications for L2VPN PW are disabled.
pw-delete: Enables PW deletion notifications.
pw-switch: Enables PW primary/backup switchover notifications.
pw-up-down: Enables PW up-down notifications.
This feature enables L2VPN to generate SNMP notifications when PW deletions, PW status changes, or PW switchovers occur. For L2VPN event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
If you do not specify a notification type, this command enables all types of notifications for L2VPN PW.
# Enable PW up-down SNMP notifications.
[Sysname] snmp-agent trap enable l2vpn pw-up-down
display snmp-agent trap-list (Network Management and Monitoring Command Reference)
Use tunnel-policy to specify a tunnel policy for an auto-discovery VSI.
Use undo tunnel-policy to restore the default.
undo tunnel-policy
No tunnel policy is specified.
tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 19 characters.
The PWs on the auto-discovery VSI use the specified tunnel policy to select public tunnels.
If you do not specify a tunnel policy or specify a nonexistent tunnel policy, the default tunnel policy applies. The default tunnel policy selects only one public tunnel for a PW in this order: LSP tunnel, CRLSP tunnel.
# Specify tunnel policy policy1 for auto-discovery VSI aaa.
[Sysname] tunnel-policy policy1
[Sysname-tunnel-policy-policy1] quit
[Sysname] vsi aaa
[Sysname-vsi-aaa-auto] tunnel-policy policy1
tunnel-policy (system view)
vpls-id
Use vpls-id to set the VPLS ID for a VSI.
Use undo vpls-id to restore the default.
vpls-id vpls-id
undo vpls-id
No VPLS ID is specified for a VSI.
Auto-discovery VSI LDP signaling view
vpls-id: Specifies a VPLS ID, a string of 3 to 21 characters. You can specify a VPLS ID in one of the following formats:
A VPLS ID uniquely identifies a VPLS instance. Two PEs must have the same VPLS ID to establish a PW.
VPLS IDs are used in the scenarios where BGP is used to find remote PEs and where FEC 129 LDP is used to establish PWs to the remote PEs.
The local PE advertises a BGP update that includes the configured VPLS ID as an extended community attribute to the remote PE. The remote PE compares the received VPLS ID with its own VPLS ID. If the two VPLS IDs are identical, the two PEs use FEC 129 LDP to establish a PW. If not, the PEs do not establish a PW.
To change a VPLS ID, execute the undo vpls-id command to remove the VPLS ID and then execute the vpls-id command.
# Configure the VPLS ID 100:1 for VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa-auto-ldp] vpls-id 100:1
display l2vpn pw
display l2vpn vsi
vpn-target
Use vpn-target to configure route targets for an auto-discovery VSI.
Use undo vpn-target to remove route targets for an auto-discovery VSI.
undo vpn-target { vpn-target&<1-8> | all } [ both | export-extcommunity | import-extcommunity ]
No route targets are configured for an auto-discovery VSI.
vpn-target&<1-8>: Specifies a space-separated list of a maximum of eight route targets.
A route target is a string of 3 to 21 characters in one of the following formats:
both: Uses the specified route targets as both import targets and export targets. The both keyword is used when you do not specify any of both, export-extcommunity, and import-extcommunity.
export-extcommunity: Uses the specified route targets as export targets.
import-extcommunity: Uses the specified route targets as import targets.
all: Removes all route targets.
A local PE sets the route targets as export targets in BGP update messages when it advertises L2VPN information through the update messages to a remote peer. The peer uses its import targets to match the received export targets. If a match is found, the peer accepts the L2VPN information.
If you repeat this command, all the configured route targets take effect.
# Configure import route targets as 10:1 100:1 1000:1 and export route targets as 20:1 200:1 2000:1 for auto-discovery VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa] auto-discovery bgp
[Sysname-vsi-aaa-auto] vpn-target 10:1 100:1 1000:1 import-extcommunity
[Sysname-vsi-aaa-auto] vpn-target 20:1 200:1 2000:1 export-extcommunity
vsi
Use vsi to create a VSI and enter its view, or enter the view of an existing VSI.
Use undo vsi to delete a VSI.
vsi vsi-name
undo vsi vsi-name
No VSIs exist.
vsi-name: Specifies a name for the VSI, a case-sensitive string of 1 to 31 characters.
You can create multiple PWs for a VSI manually, or by using LDP or BGP.
# Create a VSI named vpls1 and enter VSI view.
[Sysname] vsi vpls1
[Sysname-vsi-vpls1]
display l2vpn vsi
xconnect vsi
Use xconnect vsi to bind an Ethernet service instance to a VSI.
Use undo xconnect vsi to restore the default.
xconnect vsi vsi-name [ access-mode vlan ] [ track track-entry-number&<1-3> ]
undo xconnect vsi
An Ethernet service instance is not bound to any VSI.
vsi-name: Specifies the name of a VSI, a case-sensitive string of 1 to 31 characters.
access-mode vlan: Specifies the AC access mode as VLAN. The access mode is VLAN regardless of whether you specify this option or not.
track track-entry-number&<1-3>: Specifies a space-separated list of up to three track entry numbers in the range of 1 to 1024. The AC is up only if a minimum of one associated track entry is in positive state.
After you bind an Ethernet service instance to a VSI, packets matching the service instance are forwarded according to the MAC address table of the VSI.
The Ethernet service instance specified in this command must have a packet match criterion configured by the encapsulation command.
The AC access mode determines how the PE considers the VLAN tag in Ethernet frames received from the AC and how the PE forwards Ethernet frames to the AC. In VLAN access mode, Ethernet frames received from the AC must carry a VLAN tag in the Ethernet header. The PE considers the VLAN tag as a P-tag assigned by the service provider. Ethernet frames sent to the AC must also carry the P-tag.
# Configure Ethernet service instance 200 on Ten-GigabitEthernet 1/0/1 to match packets with outer VLAN tag 200, and bind the Ethernet service instance to VSI vpn1. Associate the Ethernet service instance with track entries 1, 2, and 3.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] quit
[Sysname-Ten-GigabitEthernet1/0/1] service-instance 200
[Sysname-Ten-GigabitEthernet1/0/1-srv200] encapsulation s-vid 200
[Sysname-Ten-GigabitEthernet1/0/1-srv200] xconnect vsi vpn1 track 1 2 3
encapsulation
vsi
