H3C Switches & Routers Licensing Guide-6W101
HomeSupportResource CenterTechnical DocumentsInstall & UpgradeLicensing GuidesH3C Switches & Routers Licensing Guide-6W101
Download Book
Table of Contents
Related Documents
Licensing Guide
Copyright © 2021-2022 New H3C Technologies Co., Ltd. All rights reserved.
Overview·· 1
Obtaining information about license-based features· 1
License types· 1
Preinstalled licenses· 1
Formal licenses· 1
Concepts· 2
Technical support 3
Licensing from the CLI 4
About licensing· 4
Restrictions and guidelines: Licensing management 4
Management operation restrictions and guidelines· 4
File operation restrictions· 5
Registering and installing a license· 6
License registration and installation flowchart 6
Licensing requirements· 6
Obtaining a license key· 8
Identifying the license storage on the device· 9
Compressing the license storage on the device· 9
Obtaining device information from the device· 10
Requesting an activation key or activation file on H3C License Management Platform·· 11
Installing an activation key or activation file on the device· 17
Viewing license information· 18
Transferring licenses· 19
About this task· 19
License transfer workflow· 19
Restrictions and guidelines· 19
Obtaining an Uninstall key or Uninstall file on the source device· 20
Compressing the license storage of the destination device· 21
Obtaining the device information of the destination device· 21
Requesting license transfer on H3C License Management Platform·· 21
Installing the new activation key or activation file on the destination device· 24
Uninstalling a license· 24
About this task· 24
License uninstallation workflow· 25
Restrictions and guidelines· 25
Obtaining an Uninstall key or Uninstall file for a license on the device· 25
Requesting license uninstallation on H3C License Management Platform·· 25
Licensing from the Web interface· 27
About licensing· 27
Restrictions and guidelines: Licensing configuration· 27
Management operation restrictions and guidelines· 27
File operation restrictions· 27
Registering and installing a license· 27
License registration and installation flowchart 27
Licensing requirements· 28
Obtaining license keys· 28
Compressing the license storage on the device· 28
Obtaining device information from the device· 29
Requesting an activation key or activation file on H3C License Management Platform·· 30
Installing an activation key or activation file on the device· 30
Viewing license information· 30
Appendix A  FAQ·· 32
License activation· 32
Q: What is a license key and what is an activation key or activation file?· 32
Q: Can I install the license for a feature only on one member device in an IRF fabric?· 32
Q: Can I modify the system time of the device after a license is installed?· 32
Q: Might the DID file for the device change? What impact does a DID file change have?· 32
Q: Will activated license activation files be lost after the device reboots or the device software upgrades?  33
License uninstallation· 33
Q: Can I uninstall an expired license?· 33
Q: How do I obtain the Uninstall key for a license?· 33
Q: Can I install an uninstalled activation file on the device again?· 33
Q: How do I delete expired and uninstalled licenses?· 34
Q: What should I do if I inadvertently delete the activation file for a license?· 34
License retrieval 34
Q: How do I retrieve a lost license key?· 34
Q: How do I retrieve an activation key or activation file?· 34
Q: How do I transfer licenses when a node fails or when license transfer is required?· 34
Overview
H3C offers licensing options for you to deploy features and expand resource capacity on an as needed basis. To use license-based features, you must purchase licenses from H3C and install the licenses.
To obtain information about license-based features, their licensing status, and license availability, execute the display license feature command on the device. Then, you can purchase and install licenses as needed.
Figure 1 displays a sample output from the display license feature command:
Figure 1 Sample output from the display license feature command
License types
H3C offers preinstalled and formal licenses. Support for preinstalled licenses varies by product. For more information about the license options available for a product, see the license matrixes document for that product.
Preinstalled licenses are built into a system and are available for use on initial startup of the system. Users do not need to activate them.
A preinstalled license is typically time limited and cannot be uninstalled or transferred.
When a preinstalled license expires, the license-based feature becomes unavailable. To continue to use the feature, you must purchase and install a formal license for it.
Formal licenses
To gain most from a license-based feature, purchase a formal license for it.
Formal licenses are available with different validity periods and their support for uninstallation and transfer of formal licenses depends on product model. For more information, see the license matrixes document for the product.
To install a formal license for a feature:
1.     Purchase a software license certificate through an official channel.
2.     Access H3C License Management Platform, and then enter the license key in the certificate and the required device information to obtain an activation key or activation file.
3.     Install the activation key or activation file in the target system.
Concepts
The following information describes the basic concepts that you might encounter when you register, install, and manage licenses.
H3C License Management Platform provides product licensing services for H3C customers. You can access this system to obtain license activation key or file, transfer licenses, or remove the device and license binding for an uninstalled license.
H3C License Management Platform is accessible at https://www.h3c.com/en/Support/Online_Help/License_Service/.
Software license certificate
A software license certificate allows users to use a license-based feature. It contains license key, license capacity, and other information.
License key
A license key uniquely identifies a license.
To obtain a formal license key, purchase a software license certificate. The authorization serial number in the software license certificate is the license key.
Device serial number
A device serial number (SN or S/N) is a barcode that uniquely identifies a device. It comes with the device and must be provided when you request a license in H3C License Management Platform.
Device ID (DID) and DID file
A DID is a string of characters that uniquely identifies a hardware device. A DID file stores the DID and other information. The product comes with a DID or DID file. You must provide the DID or DID file when you request a license for the device on H3C License Management Platform.
A DID file is also referred to as a device information file in this document.
Activation key and activation file
An activation key (AK) or activation file (AF) binds a license to a system.
To use a license-based feature on a system, you must perform the following tasks:
1.     Use the license key and the system’s SN and DID information to obtain an activation key or file from H3C License Management Platform.
2.     Install the activation key or file on the system.
Uninstall key and Uninstall file
When you uninstall an activation key or file, the system generates an Uninstall key (UK) or Uninstall file (UF), respectively. This information proves that the license and system binding has been removed. You must provide this information when you transfer an unexpired license from one system to another.
License storage
License storage is a persistent storage of fixed size for storing licensing information. This information includes the licensing state, licensing time, Uninstall key or file, and other related information.
Data in the license storage persists through reboot. This ensures licensing accuracy and continuity.
Stateful failover deployment
A failover deployment contains one master node and one backup node for node redundancy.
In a stateful failover deployment, the backup node instantly backs up data from the master node so the master can take over immediately after the master node fails.
Stateful failover is also called management high availability (HA) or hot backup. The master and backup nodes in a failover pair are also called primary and secondary nodes, respectively.
Technical support
To obtain assistance, contact H3C by email or phone or access documents at the H3C website.
·     Email:
¡     China: service@h3c.com
¡     Hongkong, China: service_hk@h3c.com
¡     Other countries or regions: h3cts@h3c.com
·     Technical support hotline:
To find contacts for your local area, access the H3C global contacts page at https://www.h3c.com/en/Support/Online_Help/Service_Hotlines/
·     Website: http://www.h3c.com
IMPORTANT
IMPORTANT:
The command output in this document is for illustration only. The actual command output varies by device model.
About licensing
Licensing requires license activation device by device. It is applicable to small-sized networks.
To install a license on a device:
1.     Obtain the license key and the SN and DID information of the device.
2.     Access H3C License Management Platform to request an activation key or activation file based on the license key and the device's SN and DID information.
3.     Install the activation key or activation file on the device to activate the license.
The activation key or file for a license is device locked. You cannot install the activation key or activation file for one device to activate the license on another device.
Figure 2 Licensing procedure
·     Purchase licenses from H3C authorized channels.
·     To identify the validity periods of the licenses that have been installed on the device, execute the display license command. If the license for a feature is time limited, install a new license for the feature before the old license expires.
Figure 3 Sample output from the display license command
·     Licenses are typically device locked. To ensure a successful licensing, use the following licensing guidelines:
a.     When you purchase a license certificate, verify the following items:
-     Make sure the license is compatible with the target device.
-     Make sure its licensed functionality and capacity meet your requirements.
b.     When you obtain an activation key or file, make sure the provided license key and hardware information are correct.
c.     Install the activation key or file on the correct target device.
·     Make sure no one else is performing license management tasks while you are managing licenses on the device.
·     Unless otherwise stated, all character strings entered on H3C License Management Platform are case sensitive. As a best practice to ensure a successful licensing, copy and paste license keys, Uninstall keys, device SNs, and values for other critical fields as long as possible.
·     You can manage licenses only on the default MDC. Any license operation performed on the default MDC takes effect on all MDCs.
When you operate DID files, activation files, or Uninstall files, follow these restrictions and guidelines:
·     To avoid licensing error, do not modify the file name or edit the file content.
·     Before you install an activation file, download the activation file to the storage media of the device such as flash memory or CF card. When installing an activation file, the device automatically copies the activation file to the license folder in the root directory of the storage media. The license folder stores important files for licensing. For licensed features to function correctly, do not delete or modify the license folder or the files in this folder.
Figure 4 shows the procedure for registering and installing a formal license.
Figure 4 Licensing procedure
Single-node deployment
Licenses for fixed-port devices are device locked (also called chassis locked). You purchase, register, and install licenses on a per-device basis.
Licenses for modular devices are device locked or MPU locked, depending on the device series. To identify the license locking type, execute the display license feature command.
·     If the command output does not contain slot fields, the license is device locked. Use the following guidelines:
¡     You purchase licenses and install their activation files on a per-device basis.
¡     When you install an activation file, the system automatically copies the activation file to all MPUs of the device.
-     The licensed feature can operate correctly after you remove one of the MPUs.
-     If you replace one of the MPUs, the system automatically copies all activation files to the new MPU to make sure the licensed features can operate correctly after an active/standby switchover.
-     If you are replacing both MPUs at the same time, back up the activation files. After the replacement, you must copy the activation files back to the new active MPU for the licensed features to continue to take effect. The system will automatically copy the activation files to the standby MPU.
Figure 5 Command output without the slot field
·     If the command output contains slot fields, in Slot xx or Chassis xx Slot xx format, the licenses are MPU locked. Use the following guidelines:
¡     You purchase, register, and activate licenses of the same specifications for each MPU in the device. This ensures that the license-based features can continue to take effect after an active/standby switchover.
¡     If you move the MPUs to another device, the license-based features can continue to take effect on the destination device as long as they are still valid. To have the license-based features continue to take effect on the source device, you must purchase, register, and activate new licenses for the new MPUs.
Figure 6 Command output with slot fields
IRF or 1+N node redundancy deployment
In an IRF or 1+N node redundancy deployment, only the licenses installed on the current master node are used. For a license-based feature to take effect after a master/standby switchover, you must purchase, apply for, and install a license of the same specification on each of the member node or IRF member device. The license installation requirements and license installation procedures are the same across the member devices.
1+N node redundancy deployment contains one master device and N backup devices, for example, a stateful failover deployment. The master device processes services. When the master device fails, a backup device immediately takes over to ensure service continuity.
Command syntaxes
IMPORTANT
IMPORTANT:
The command syntaxes in this document are for illustration only. The complete command syntaxes vary by device model.
Table 1 shows the command syntaxes for the command used to install licenses on fixed-port devices and modular devices.
Table 1 Syntaxes for the command used to install licenses
Device type
Command syntax
Fixed-port devices that do not support IRF
license activation-file install activation-file
Fixed-port devices that support IRF
license activation-file install activation-file slot slot-number
Modular devices where licenses are device locked
In standalone mode:
In IRF mode:
license activation-file install activation-file chassis chassis-number
Modular devices where licenses are MPU locked
In standalone mode:
In IRF mode:
license activation-file install activation-file chassis chassis-number slot slot-number
After you obtain a license key, back up it and keep the backup license key in a safe place for future use.
To obtain a license key:
1.     Log in to the CLI of the device and execute the display license feature command in any view to identify features that require licensing.
Figure 7  Sample output from the display license feature command
2.     To use a license-based feature, purchase a software license certificate for it. The authorization serial number in the software license certificate is the license key.
To identify the free space of the license storage, execute the display license feature command in any view.
From the command output, view the Total and Usage fields to examine whether the remaining license storage is sufficient for installing new licenses. If the remaining license storage is not sufficient, compress the license storage.
Figure 8 Identifying the license storage
The license storage stores licensing information and has a fixed size.
Before requesting an activation key or activation file, you compress the license storage to delete expired and uninstalled license information to ensure sufficient storage space for installing new licenses.
If no licenses have been installed on the device, you do not need to compress the license storage.
Back up the Uninstall keys or Uninstall files for the uninstalled licenses for subsequent license transfer or license uninstallation on H3C License Management Platform.
If uninstalled licenses or expired licenses exist on the device, the compression operation will make the DID change. You will be unable to install the activation key or activation file obtained by using the old DID on the device. As a best practice, install all activation keys or activation files registered with the old DID before performing a compression.
If you have not installed an activation key or activation file registered with the old DID, take the following actions:
·     If the license storage is sufficient, install the activation key or activation file on the device. For more information, see "Installing an activation key or activation file on the device."
·     If the license storage is insufficient and the activation key or activation file cannot be installed after the compression, contact H3C Support.
1.     Execute the system-view command to enter system view.
2.     Execute the license compress command to compress the license storage.
Device information is required for license registration on H3C License Management Platform.
To obtain required information for license registration from CLI, log in to the CLI of a device and obtain the following parameters:
·     H3C device SNYou can execute the display license device-id command in any view to obtain the value of the SN field.
·     DID or DID fileYou can execute the display license device-id command in any view to obtain the value of the Device ID field.
¡     If the field value is a string of characters, the device supports the DID. You can copy the DID for future use.
Figure 9 Obtaining the DID
¡     If the field value is a file name, the device supports the DID file. Use FTP or TFTP to upload the DID file to the PC. If FTP is used to transfer the DID file, use the Binary mode.
Figure 10 Obtaining the DID file
On H3C License Management Platform, you can use one of the following methods to request an activation key or activation file:
·     Bind one license key to one device in one request.
·     Bind multiple license keys to one device or multiple devices in one request.
Adding license keys
1.     Open a Web browser and access H3C License Management Platform at https://www.h3c.com/en/Support/Online_Help/License_Service/.
IMPORTANT
IMPORTANT:
As a best practice, use Chrome 62 or above, IE 10 or above, or Firefox 60 or above.
2.     Access the License Activation Requests page as shown in Figure 11.
Figure 11 License Activation Requests page
3.     Use one of the following methods to add license keys:
¡     To add license keys one by one:
# Enter or copy and paste a complete license key in the empty License Key box as shown in Figure 11, and then click Search & Add. The platform will automatically obtain the information associated with the license key.
# Repeat this step to add multiple license keys.
¡     To add license keys by uploading the QR code images for the license keys:
# Click the  icon next to the License Key box as shown in Figure 11, and then upload the QR code image for a license key as shown in Figure 12.
# Click Search & Add in Figure 11. The platform will automatically obtain the information associated with the QR code image.
IMPORTANT
IMPORTANT:
Make sure the uploaded image is complete and clear for the platform to correctly recognize it.
Figure 12 Uploading the QR code image for a license key
¡     To add license keys in bulk.
# As shown in Figure 11, click Import & Add.
# In the dialog box that opens, you can use one of the following methods to import license keys in bulk to H3C License Management Platform:
-     Click the Download Excel License Key Import Template link to download the Excel license key import template, as shown in Figure 13. The contents in the template are as shown in Figure 14. Enter license keys in the template, save the template, and then upload it to the platform. The license keys in the template are all imported to the platform.
-     Click Select as shown in Figure 13 to upload a license key list file to the platform if an electronic license key list file is available. The license keys in the file are all imported to the platform.
Figure 13 Uploading a file
Figure 14 Contents in the Excel license key import template
4.     Select license keys to be activated, and then click Next, as shown in Figure 15.
Figure 15 Finishing adding license keys
Binding license keys to devices
1.     Verify that the license keys to be activated are all added.
¡     To add a license key on the page as shown in Figure 16:
-     Click Add.
-     Enter or copy and paste a complete license key in the License Key column, or click the  icon in the column to upload the QR code image for a license key.
-     Click the plus icon (+) to add the license key.
¡     To remove a license key, select that license key, and then click Remove.
Figure 16 Adding or removing license keys
2.     Enter device information as instructed by H3C License Management Platform:
To obtain device information, use the method as described in "Obtaining device information from the device."
Use one of the following methods to bind license keys to devices:
¡     To bind one license key to one device:
# Click the  icon next to the Custom device ID box in the license key entry, as shown in Figure 16.
# In the dialog box that opens, set the device ID and upload the device information file of the device as instructed, and then click Yes.
Figure 17 Entering device information
# Repeat the steps to bind multiple license keys to different devices.
¡     To bind multiple license keys to the same device:
# Select the license keys on the page as shown in Figure 16, and then click Bulk Bind.
# In the dialog box that opens, set the device ID, upload the device information file of the device, and then click Yes.
¡     To add license key and device bindings in bulk:
-     Select the target license keys as shown in Figure 16, and then click Export to export the selected license keys to an excel file.
-     Open the excel file, and then enter device information for each license key.
-     Click Import to import the Excel file.
IMPORTANT
IMPORTANT:
·     The custom device ID field is optional. The value for this field is user defined, and it is used to identify a device. As a best practice to facilitate device management and location, use the combination of the device model, IP address, physical position, and other information as the custom device ID. This custom device ID takes effect only on the current license activation request. It cannot take effect after you leave the license activation request page and re-open the page. If you do not define a custom device ID, the device automatically defines it.
·     When you add license key and device bindings in bulk, some devices do not support importing or exporting device information because they require device information files for license key binding. The exported Excel file contains information to help you identify such devices.
3.     Review the bindings carefully.
Each license key will be locked to the device to which each of them is bound.
4.     Make sure you understand the impact of the binding operation. Select the option that explicitly states so, and then click Next, as shown in Figure 18.
Figure 18 Finishing binding license keys to devices
Specifying user information
As shown in Figure 19, enter user information, and then click Next. Table 2 describes the parameters.
Figure 19 Entering user information
Table 2 User information configuration parameters
Parameter
End Customer Company/Organization
(Required.) Company or organization that uses the licenses.
Your Company/Organization
(Required.) Company or organization with which the license applicant works.
Contact Person
(Required.) Name of the contact person.
Phone Number
(Required.) Contact phone number.
Email Address
(Required.) Contact email address.
IMPORTANT IMPORTANT:
H3C License Management Platform will send the generated activation keys or activation files to this email address. Make sure the email address is correct and available.
Zip/Postal Code
(Optional.) Zip code or postal code for the contact address.
Address
(Optional.) Contact address.
Project Name
(Optional.) Project name.
Verification Code
(Required.) The verification code is case insensitive.
Reviewing information and activating the licenses
1.     Review the license key and device information, select I accept all terms and conditions of H3C License Service Portal Legal Statement, and then click Confirm & Activate, as shown in Figure 20.
Figure 20 Reviewing information and activating the licenses
2.     Double-check the license key and device information, and then click OK in the dialog box as shown in Figure 21.
Figure 21 Confirmation dialog box
The platform automatically generates an activation key or activation file for each binding and sends them to the specified email address.
3.     Perform one of the following tasks to obtain activation keys or activation files:
¡     If one license key is bound to one device, the platform generates an activation file for the device. To download the activation file, click Get Activation Info in the Get Activation Info column for the license key, as shown in Figure 24.
¡     If multiple license keys are bound to one device, the platform generates a compressed activation file package for the device. To download the compressed activation file package, click Get Activation Info in the Get Activation Info column shared by the license keys, as shown in Figure 24.
¡     To obtain all activation files generated for this request, click Bulk Get Activation Info as shown in Figure 24. The activation files are as shown in Figure 22 and the activation information sheet is as shown in Figure 23.
IMPORTANT
IMPORTANT:
As a best practice, click Bulk Get Activation Info to obtain all activation files generated for this request. The activation information sheet provided by this method facilitates you to record and manage activation files.
Figure 22 License file information
Figure 23 Activation information sheet
¡     Access the email box at the specified address to obtain the activation keys or activation files.
Figure 24 Downloading activation files
IMPORTANT
IMPORTANT:
·     It takes some time for H3C License Management Platform to generate multiple activation files. In this scenario, you cannot download the activation files from the webpage. To obtain the activation files, you must access the email box at the specified address.
·     If you do not receive an activation key or activation file for a license key from the platform and cannot use the license key to re-apply for license activation, contact H3C Support.
CAUTION
CAUTION:
Back up an activation key or activation file before you install it. If the activation key or activation file is inadvertently deleted or becomes unavailable for some other reason, you can use the backup activation key or activation file to restore the license.
To use a license-based feature, install an activation file for the feature on the device.
Use FTP or TFTP to upload the activation file to be installed to the device. If FTP is used to transfer the activation file, set it in binary mode.
2.     Execute the license activation-file install command to install the activation file.
Use one of the following commands in any view to display license information:
·     Use the display license feature command to display brief license information for features.
Figure 25 Sample output from the display license feature command
·     Use the display license command to display detailed information about licenses, including:
¡     Information about the licensed features, the validity periods of the installed licenses, and the date and time when the licenses were installed.
¡     Information about the features whose licenses were uninstalled, date and time when the licenses were installed, date and time when the licenses were uninstalled, and the Uninstall keys.
Figure 26 Sample output from the display license command
Perform this task to transfer a license that has not expired from one device to another in the same product series.
For the support of the product for license transfer, see its license matrixes document.
To transfer licenses from one device to another, use the workflow in Figure 27.
Figure 27 License transfer workflow
You can transfer only formal licenses that have not expired.
1.     Log in to the CLI of the source device.
2.     Execute the display license command to identify the activation key or activation file that will be uninstalled.
Figure 28 Sample output from the display license command
3.     Execute the system-view command to enter system view, and perform one of the following tasks to uninstall the license:
¡     If an activation key is installed for the license, execute the license activation-key uninstall command to uninstall the activation key.
¡     If an activation file is installed for the license, execute the license activation-file uninstall command to uninstall the activation file.
4.     Execute the display license command to obtain the Uninstall key. Copy the Uninstall key, and then use the Uninstall key on H3C License Management Platform to request a license transfer or uninstallation.
Figure 29 Sample output from the display license command
To ensure a successful license transfer, verify that the destination device has sufficient license storage space. If the license storage space on the destination device is insufficient, compress the license storage. For more information, see "Identifying the license storage on the device" and "Compressing the license storage on the device."
Log in to the destination device, and obtain information as described in "Obtaining device information from the device."
Entering Uninstall information
IMPORTANT
IMPORTANT:
2.     Click the Device License Transfer Requests tab to open the Device License Transfer Requests page, as shown in Figure 30.
Figure 30 Device License Transfer Requests page
3.     As shown in Figure 31, select Uninstall File, click Click to Upload to upload the Uninstall files, and then click Search & Add.
For information about obtaining Uninstall files, see "Obtaining an Uninstall key or Uninstall file on the source device."
Figure 31 Uploading the Uninstall files
4.     Select entries to uninstall, and then click Next.
Figure 32 Finishing adding Uninstall files
Binding license keys to the destination device
1.     Review the Uninstall files on the Bind to hardware device page.
To remove an Uninstall file, select that Uninstall file and click Remove.
Figure 33 Bind to hardware device page
2.     Bind the uninstallation information of the source device to the destination device. Make sure you understand the impact of the binding operation, and then select the option that explicitly states so.
3.     Click Next. For more information, see "Binding license keys to devices."
Figure 34 Finishing binding license keys to devices
Enter user information, and then click Next. For more information, see "Specifying user information."
Review and activate the license to obtain a new activation key or activation file. For more information, see "Reviewing information and activating the licenses."
Figure 35 Succeeding in requesting license transfer
CAUTION
CAUTION:
Before you install an activation key or activation file, back up and keep your activation key or activation file safe. If the activation key or activation file is deleted or the license is unavailable because of device failure, you can use the backup activation key or activation file to restore the license.
Log in to the destination device and install the new activation key or activation file on the destination device. For more information, see "Installing an activation key or activation file on the device."
A license key is bound to a device once you activate the license key on H3C License Management Platform. You cannot bind this license key to another device. To unbind a license key for a license that has not expired from a device, obtain the Uninstall key or Uninstall file for the license on the device. Then, request for license uninstallation on H3C License Management Platform.
After license uninstallation is requested successfully, you can use this license key to request a new activation key or activation file on H3C License Management Platform.
The new activation key or activation file can be installed on another device for license transfer or on the local device for license restoration.
For support of license uninstallation, see the license matrixes for the product.
Figure 36 Uninstallation workflow
You can uninstall only formal licenses that have not expired.
Log in to the device to obtain an Uninstall key or Uninstall file for a license. For more information, see "Obtaining an Uninstall key or Uninstall file on the source device."
CAUTION
CAUTION:
If you cannot obtain an Uninstall key or Uninstall file because of device failure, contact H3C Support to unbind the device from the license.
To request license uninstallation on H3C License Management Platform:
1.     Log in to H3C License Management Platform at https://www.h3c.com/en/Support/Online_Help/License_Service/. Click the Device License Uninstall Requests tab.
2.     Use one of the following methods to enter uninstallation information:
¡     Manually enter Uninstall keys one by one and click Search & Add to obtain uninstallation information.
¡     Import Uninstall keys in bulk. First, click Import & Add and download the Excel Uninstall key import template. Then, enter Uninstall keys in the template and upload the Excel file back to H3C License Management Platform to obtain uninstallation information.
For information about obtaining Uninstall keys, see "Obtaining an Uninstall key or Uninstall file on the source device."
3.     Select the uninstallation information that will be uninstalled.
4.     Click Next.
5.     Enter user information, and then click Next. For more information, see "Specifying user information."
6.     Review the uninstallation information, and then select the option that explicitly states your acceptance of all terms in the legal statement.
7.     Click Confirm & Uninstall.
8.     Review license and device information, and then click OK. The binding between the device and license key will be removed.
IMPORTANT
IMPORTANT:
The webpage output in this document is for illustration only. The actual webpage output varies by device model.
About licensing
For more information, see "About licensing" in licensing from the CLI.
For more information, see "File operation restrictions" in licensing from the CLI.
For information about the procedure for registering and installing a license, see "License registration and installation flowchart" in licensing from the CLI.
For information about licensing requirements, see "Licensing requirements" in licensing from the CLI.
CAUTION
CAUTION:
Back up your license keys, and keep the backup license keys in a safe place for future use.
1.     Log in to the Web interface of the device.
2.     From the navigation pane, select System Tool > License Management.
3.     Click the Licenses and features tab. On the page that opens, identify the features that require licenses.
Figure 37 Identifying the features that require licenses
4.     Purchase software license certificates from H3C authorized channels. The software license certificates contain license keys.
You compress the license storage to delete expired and uninstalled license information to ensure sufficient storage space for installing new licenses.
To identify whether a compression operation is required:
3.     Click the Compress tab.
4.     Calculate the remaining number of allowed license files (activation files). Remaining number of allowed license files = Total number of allowed license files – Number of installed license files.
¡     If the remaining number of allowed license files is smaller than the number of license files to be installed, you must compress the license storage.
¡     If the remaining number of allowed license files is not smaller than the number of license files to be installed, you do not need to compress the license storage.
Figure 38 Compress page
For more information, see the restrictions and guidelines in "Compressing the license storage on the device."
4.     On the page that opens, click Compress.
5.     Click Apply.
3.     Click the Obtain DID tab.
4.     Obtain the device SN and DID and copy them for future use.
Figure 39 Obtaining the device SN and DID
For more information, see "Requesting an activation key or activation file on H3C License Management Platform" in licensing from the CLI.
CAUTION
CAUTION:
If an activation file is used, download the activation file to the PC that acts as the configuration terminal.
3.     Click the License configuration tab.
4.     Click Add.
5.     On the page that opens, select a license file (activation file) and click Apply.
To view information about licenses, access the Web interface of the device and perform the following tasks:
1.     From the navigation pane, select System Tool > License Management.
2.     Click the Licenses and features tab.
3.     View the license-based features and the license status.
Figure 40 Viewing the license-based features and the license status
Appendix A  FAQ
License activation
A: A license key uniquely identifies a license. An activation key or activation file uniquely binds a license key to a device. To use a license-based feature on a device, you must install the activation key or activation file for that license on the device.
·     To obtain a license key, purchase a software license certificate from an H3C approved sales channel.
·     To obtain an activation key or activation file, access H3C License Management Platform at https://www.h3c.com/en/Support/Online_Help/License_Service/. Then, request an activation key or activation file based on the license key and hardware information of the target device.
A: No. Licenses are device locked. To make sure a license-based feature can take effect after a master/standby switchover, install a license of the same specification on each of the member devices for that feature.
A: It depends on the license validity period.
·     For a permanent license or a days-restricted license, modifying the system time does not affect the license validity period.
·     For a date-restricted license, system time modification might shorten the license validity period. As a best practice, do not modify the system time after the activation file is installed.
A: The DID file would change if you compress the license storage area by using the license compress command.
The DID file change does not affect the activated licenses on the device. However, you will be unable to install the activation keys or activation files obtained by using the old DID on the device. To resolve the issue, contact H3C Support.
To obtain a new activation file, you must export the new DID file from the device.
A: No, they will not.
A: No, you cannot. To delete expired licenses, execute the license compress command.
A: Execute the display license command, identify the activation key for the feature license, and examine the Uninstall Key field for its Uninstall key. The value for this field depends on the device model.
Figure 41 Sample output from the display license command
A: No. An activation file will become invalid after you uninstall it. To restore the license, use one of the following methods:
·     License transferOn H3C License Management Platform, use the Uninstall key or Uninstall file to transfer the license to the device again and obtain a new activation file. Then, install the new activation file on the device.
·     License uninstallation and reactivationPerform the following operations:
a.     On H3C License Management Platform, use the Uninstall key or Uninstall file to request license uninstallation, which unbinds the device and the license key.
b.     Use the license key and device information to request a new activation file.
c.     Install the new activation file on the device.
Support for license transfer and uninstallation depends on the device model. For more information, see the license matrixes document for that product..
A: Execute the license compress command. This operation will change the DID or DID file.
As a best practice, perform the following tasks before you compress the license storage:
·     Back up the Uninstall keys or Uninstall files of uninstalled licenses for subsequent license transfer or license uninstallation.
·     Install all idle activation keys or activation files registered with the old DID.
A: After you delete the activation file for a license, you will be unable to use the licensed feature or uninstall its license for file transfer.
To resolve the issue:
1.     Execute the copy command to copy the backup activation file to the license folder in the root directory of the storage medium on the device, for example, flash:/license.
2.     Reboot the device. Then, the licensed-feature continues to take effect and you can uninstall the license if needed.
License retrieval
A: If you lose the license key before obtaining an activation key or activation file, contact H3C Support to retrieve the license key based on the license purchase contract.
If you lose the license key after obtaining an activation key or activation file, contact H3C Support and provide the activation key or file or the device information.
A: You will be unable to use a licensed feature if its activation key or activation file is lost or inadvertently deleted. To retrieve an activation key or activation file, use one of the following methods:
·     Use the backup activation key or activation file.
·     Find the activation key or activation file from the email box of the applicant.
·     Contact H3C Support and provide the license key or device information to retrieve the activation key or activation file.
A: Contact H3C Support for help.
