Manage a bucket policy
A bucket policy allows you to assign access permissions of resources such as objects and buckets to users.
  1. On the top navigation bar, click Storage, and then select Object Storage > Buckets from the navigation pane.
  1. Select a bucket, and then click Bucket Policy.
Bucket access permission
User access permission
Remarks
s3:GetObject
READ
Get object
s3:GetObjectTorrent
READ
Get Torrent files from bucket
s3:GetObjectVersion
READ
Get version control of bucket
s3:GetObjectVersionTorrent
READ
Get other versions of Torrent files
s3:GetObjectTagging
READ
Get the tag set of the object
s3:GetObjectVersionTagging
READ
Get other versions of tag sets
s3:ListAllMyBuckets
READ
Get a list of all buckets owned by the verified sender
s3:ListBucket
READ
Return some or all (up to 1000) objects in the bucket
s3:ListBucketMultipartUploads
READ
Get a list of ongoing multipart uploads
s3:ListBucketVersions
READ
Get metadata about all versions of objects in the bucket
s3:ListMultipartUploadParts
READ
Get parts uploaded for a specific multipart upload
s3:AbortMultipartUpload
WRITE
Abort multipart upload
s3:CreateBucket
WRITE
Create a new bucket
s3:DeleteBucket
WRITE
Delete bucket
s3:DeleteObject
WRITE
Delete the empty version of the object (if any), and insert a delete marker, which will become the most recent version of the object.
s3:DeleteObjectVersion
WRITE
Delete the object version in the bucket
s3:PutObject
WRITE
Add objects to the bucket
s3:PutObjectTagging
WRITE
Set the provided tag set to an object that already exists in the bucket
s3:PutObjectVersionTagging
WRITE
Set tag set for multi-version objects
s3:DeleteObjectTagging
WRITE
s3:DeleteObjectVersionTagging
WRITE
Delete the entire tag set from the specified object version
s3:RestoreObject
WRITE
Restore the archived copy of the object back to Amazon S3
s3:GetAccelerateConfiguration
READ_ACP
Use accelerate sub-resource to obtain the transmission acceleration status of the bucket, which is Enabled or Suspended
s3:GetBucketAcl
READ_ACP
Use acl sub-resource to obtain bucket access control list (acl)
s3:GetBucketCORS
READ_ACP
Get the cors configuration information set for the bucket
s3:GetBucketLocation
READ_ACP
Get the area where the bucket is located
s3:GetBucketLogging
READ_ACP
Get the bucket's logging status, and the user's permission to view and modify the status
s3:GetBucketNotification
READ_ACP
Get bucket notification configuration
s3:GetBucketPolicy
READ_ACP
Get the policy of the specified bucket
s3:GetBucketRequestPayment
READ_ACP
Get the request payment configuration of the bucket
s3:GetBucketTagging
READ_ACP
Get the tag set associated with the bucket
s3:GetBucketVersioning
READ_ACP
Get the version control status of the bucket
s3:GetBucketWebsite
READ_ACP
Get bucket website configuration
s3:GetLifecycleConfiguration
READ_ACP
Get the life cycle configuration information set on the bucket
s3:GetObjectAcl
READ_ACP
Get the access control list (ACL) of the object
s3:GetObjectVersionAcl
READ_ACP
Obtain the object's access control list (ACL) for multi-version objects
s3:GetReplicationConfiguration
READ_ACP
Get the replication configuration of the bucket
s3:DeleteBucketPolicy
WRITE_ACP
Implement the strategy of using the strategy sub-resource to delete the specified bucket
s3:DeleteBucketWebsite
WRITE_ACP
Delete the website configuration of the bucket
s3:DeleteReplicationConfiguration
WRITE_ACP
Delete the replication configuration from the bucket
s3:PutAccelerateConfiguration
WRITE_ACP
Set acceleration configuration of existing bucket (faster data transfer)
s3:PutBucketAcl
WRITE_ACP
Use Access Control List (ACL) to set permissions on existing buckets
s3:PutBucketCORS
WRITE_ACP
Set cors configuration for the bucket
s3:PutBucketLogging
WRITE_ACP
Set bucket log parameters, and specify permissions for users who can view and modify log parameters
s3:PutBucketNotification
WRITE_ACP
Enable notification of specified events for the bucket
s3:PutBucketPolicy
WRITE_ACP
Apply amazons3 bucket policy to amazons3 bucket
s3:PutBucketRequestPayment
WRITE_ACP
Set bucket request payment configuration
s3:PutBucketTagging
WRITE_ACP
Set the Tagging  of the bucket
s3:PutBucketVersioning
WRITE_ACP
Set the version control status of an existing bucket
s3:PutBucketWebsite
WRITE_ACP
WRITE_ACP sets the configuration of the website specified in the website subresource
s3:PutLifecycleConfiguration
WRITE_ACP
Create a new lifecycle configuration for the bucket or replace an existing lifecycle configuration
s3:PutObjectAcl
WRITE_ACP
Use acl sub-resources to set access control list (acl) permissions for objects that already exist in the bucket
s3:PutObjectVersionAcl
WRITE_ACP
Use acl subresources to set access control list (acl) permissions for multi-version objects that already exist in the bucket.
s3:PutReplicationConfiguration
WRITE_ACP
Create a duplicate configuration or replace an existing configuration
AWS condition keys
Condition operator
aws:CurrentTime
This can be used for conditions that check the date and time.
DateEquals: Matching a specific date
DateNotEquals: Negated matching
aws:EpochTime
This is the date in epoch or Unix time, for use with date/time conditions.
NumericEquals: Matching
NumericNotEquals: Negated matching
aws:PrincipalType
This value indicates whether the principal is an account, user, federated, or assumed rolesee the explanation that follows later.
StringEquals: Exact matching, case sensitive
StringNotEquals: Negated matching
aws:Referer
Use this key to compare who referred the request in the client browser with the referer that you specify in the policy. The aws:referer request context value is provided by the caller in an HTTP header. The Referer header is included in a web browser request when you select a link on a web page. The Referer header contains the URL of the web page where the link was selected.
aws:SecureTransport
This is a Boolean value that represents whether the request was sent using SSL.
Bool: Boolean matching
aws:SourceIp
This is the requester's IP address, for use with IP address conditions. Refer to IP address condition operators for information about when SourceIp is valid and when you should use a VPC-specific key instead.
IpAddress: The specified IP address or range
NoipAddres: All IP addresses except the specified IP address or range
aws:UserAgent
This value is a string that contains information about the requester's client application. This string is generated by the client and can be unreliable. You can only use this context key from the AWS CLI.
aws:username
This is a string containing the friendly name of the current usersee the chart that follows.
