A DNS IP address must belong to a network segment shared by all NAS servers of all NAS groups. Different DNS IP addresses must belong to different network segments.
As a best practice, make sure a DNS IP address belongs to the same network segment as a dynamic service IP address in a NAS group.
Different DNS IP addresses cannot belong to the same network.
The load balancer page displays a maximum of five DNS IP addresses. To display all DNS IP addresses, click More.
On the top navigation bar, click Storage, and then select File Storage > NAS from the navigation pane.
Click the Load Balancers tab.
Click Create.
Set the parameters as described in "Parameters."
Click OK.
Click Edit in the Actions column for a load balancer.
Edit the parameters as described in "Parameters."
Click OK.
Click Delete in the Actions column for a load balancer.
In the dialog box that opens, click OK.
Domain Name: Enter a domain name for the load balancer. The domain name cannot exceed 63 characters. Only letters, digits, and hyphens (-) are allowed. The first and last characters cannot be hyphens (-). The top-level domain name cannot contain only digits. Separate different subdomain names with dots (.).
DNS IP Type: Select DNS IP address types. You can select both IPv4 and IPv6.
IPv4 Mask: Enter the subnet mask of the IPv4 address.
