Manage NAS groups
Create a NAS Group
  1. On the top navigation bar, click Storage, and then select File Storage > NAS from the navigation pane.
  1. On the NAS Groups tab, click Create.
  1. Set the parameters as described in "Parameters."
  1. Click OK.
Edit a NAS group
  1. Click Edit in the Actions column for a NAS group.
  1. Edit the parameters as described in "Parameters."
  1. Click OK.
Delete a NAS Group
Before deleting a NAS group, make sure no NAS servers exist in the group.
  1. Click Delete in the Actions column for a NAS group.
  1. In the dialog box that opens, click OK.
Add NAS servers to a NAS group
  1. Click the name of a NAS group.
  1. Click Create.
  1. Select one or multiple hosts, and then click OK.
Delete a NAS server from a NAS group
  1. Click Delete in the Actions column for a NAS server.
