Configure Intel AEP settings
You can view and initialize Intel AEP memory after you install the memory on a host. After the initialization, the system can configure the Intel AEP memory as a block device and mount the block device to the host as a local file directory (high speed) storage pool. For more information, see "Manage storage pools."
  1. On the top navigation bar, click Hosts. If the system has multiple clusters, select a cluster from the left navigation pane.
  1. Select a host, and then click the Advanced tab.
  1. Click the Intel AEP Settings tab.
  1. Select one or multiple sockets, and then click Initialize.
  1. In the dialog box that opens, click OK.
