What should I do to handle the insufficient disk error received when I perform a CB backup, even though the backup disk has sufficient space?
To remove this issue, make sure the temporary directory for CB backup is set to the base FTP directory for FTP sharing. If you select a subdirectory under the base directory, this issue occurs.
For example, an FTP site uses base directory E:\ftp1 for file sharing. This base directory contains a subdirectory named Localuser.
When you use this FTP site for CB backup, you must set the temporary directory to E:\ftp1. If you set the temporary directory to E:\ftp1\LocalUser, you would receive an insufficient disk space error message.
