Change storage paths
Add data and log disks on a VM
  1. Attach iSCSI storage to the target host.
  1. On the top navigation bar, click Hosts.
  1. Select a host, and then select the Storage tab.
  1. Click Add.
  1. Add an iSCSI storage pool.
Figure-1 Selecting the iSCSI Network Storage type
Figure-2 Configuring storage pool settings
  1. Verify that the iSCSI storage pool is normal.
  1. Attach a disk to the target VM.
  1. On the top navigation bar, click Storage, and then select Storage Management > Block Device Management from the navigation pane.
  1. Add a 500 GB block device in a data pool used for cache acceleration.
Figure-3 Adding a 500 GB block device
  1. Add a 200 GB block device in an SSD data pool.
Figure-4 Adding a 200 GB block device
  1. Edit the VM to attach the 500 GB block device as a disk to the VM.
Figure-5 Attaching the 500 GB block device as a disk
  1. Attach the 200 GB block device as a log disk to the VM.
Figure-6 Attaching the 200 GB block device as a disk
Format disks
  1. Execute the lsblk command to verify that the data and log disks have been attached to the VM.
[root@localhost ~]# lsblk
NAME            MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
fd0               2:0    1    4K  0 disk
sr0              11:0    1 1024M  0 rom
vda             252:0    0  100G  0 disk
   vda1          252:1    0    1G  0 part /boot
   vda2          252:2    0   99G  0 part
      centos-root 253:0    0   50G  0 lvm  /
      centos-swap 253:1    0  7.9G  0 lvm  [SWAP]
      centos-home 253:2    0 41.1G  0 lvm  /home
vdb             252:16   0  500G  0 disk
vdc             252:32   0  200G  0 disk
  1. Add partitions on data disk vdb.
[root@localhost ~]# fdisk /dev/vdb
Welcome to fdisk (util-linux 2.23.2).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Device does not contain a recognized partition table
Building a new DOS disklabel with disk identifier 0x25e7e632.
Command (m for help): n
Partition type:
   p   primary (0 primary, 0 extended, 4 free)
   e   extended
Select (default p):
Using default response p
Partition number (1-4, default 1):
First sector (2048-1048575999, default 2048):
Using default value 2048
Last sector, +sectors or +size{K,M,G} (2048-1048575999, default 1048575999):
Using default value 1048575999
Partition 1 of type Linux and of size 500 GiB is set
Command (m for help): w
The partition table has been altered!
Calling ioctl() to re-read partition table.
Syncing disks.
[root@localhost ~]#
  1. Add partitions on log disk vdc.
 [root@localhost ~]# fdisk /dev/vdc
Building a new DOS disklabel with disk identifier 0x2d99bcb6.
Partition type:
   e   extended
Select (default p):
First sector (2048-419430399, default 2048):
Last sector, +sectors or +size{K,M,G} (2048-419430399, default 419430399):
Using default value 419430399
Partition 1 of type Linux and of size 200 GiB is set
Syncing disks.
[root@localhost ~]#
fd0               2:0    1    4K  0 disk
    vdb1          252:17   0  500G  0 part
    vdc1          252:33   0  200G  0 part
  1. Format the partitions by using Ext4.
 [root@localhost ~]# mkfs.ext4 /dev/vdb1
mke2fs 1.42.9 (28-Dec-2013)
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=0 blocks, Stripe width=0 blocks
32768000 inodes, 131071744 blocks
6553587 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=2279604224
4000 block groups
32768 blocks per group, 32768 fragments per group
8192 inodes per group
Superblock backups stored on blocks:
        32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
        4096000, 7962624, 11239424, 20480000, 23887872, 71663616, 78675968,
        102400000
Allocating group tables: ^[[Adone
Writing inode tables: done
Creating journal (32768 blocks): done
Writing superblocks and filesystem accounting information: done
[root@localhost ~]# mkfs.ext4 /dev/vdc1
Filesystem label=
OS type: Linux
13107200 inodes, 52428544 blocks
2621427 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=2199912448
1600 block groups
Allocating group tables: done
Change disk paths
  1. Stop the MySQL service.
[root@localhost ~]# systemctl stop mysqld.service
[root@localhost ~]#
  1. Add directories /home/mysql and /home/mysqllog.
[root@localhost ~]# cd /home/
[root@localhost home]# mkdir mysql
[root@localhost home]# mkdir mysqllog
  1. Mount /dev/vdb1 to /home/mysql and /dev/vdc1 to /home/mysqllog.
[root@localhost home]# echo '/dev/vdb1 /home/mysql ext4 defaults 0 0'>> /etc/fstab
[root@localhost home]# echo '/dev/vdc1 /home/mysqllog  ext4 defaults 0 0'>> /etc/fstab
[root@localhost home]# cat /etc/fstab
# /etc/fstab
# Created by anaconda on Thu Aug  2 20:47:44 2018
# Accessible filesystems, by reference, are maintained under '/dev/disk'
# See man pages fstab(5), findfs(8), mount(8) and/or blkid(8) for more info
/dev/mapper/centos-root /                       xfs     defaults        0 0
UUID=0dba471b-6422-45f7-b0be-fdd3fc9c4eb7 /boot                   xfs     defaults        0 0
/dev/mapper/centos-home /home                   xfs     defaults        0 0
/dev/mapper/centos-swap swap                    swap    defaults        0 0
[root@localhost home]# mount -a
[root@localhost home]# df -h
Filesystem               Size  Used Avail Use% Mounted on
/dev/mapper/centos-root   50G  7.9G   43G  16% /
devtmpfs                  16G     0   16G   0% /dev
tmpfs                     16G     0   16G   0% /dev/shm
tmpfs                     16G  9.7M   16G   1% /run
tmpfs                     16G     0   16G   0% /sys/fs/cgroup
/dev/vda1               1014M  171M  844M  17% /boot
/dev/mapper/centos-home   42G   37M   42G   1% /home
tmpfs                    3.2G  8.0K  3.2G   1% /run/user/42
tmpfs                    3.2G     0  3.2G   0% /run/user/0
/dev/vdb1                493G   73M  467G   1% /home/mysql
/dev/vdc1                197G   61M  187G   1% /home/mysqllog
  1. Modify the user and user group ownership of the mysql and mysqllog directories.
[root@localhost home]# chown -R mysql:mysql mysql
[root@localhost home]# chown -R mysql:mysql mysqllog/
[root@localhost home]# ll
total 12
drwx------. 16 cloud cloud 4096 Aug  2  2018 cloud
drwxr-xr-x.  3 mysql mysql 4096 Jul  9 02:21 mysql
drwxr-xr-x.  3 mysql mysql 4096 Jul  9 02:21 mysqllog
[root@localhost home]# chmod 777 mysql
total 12
drwxrwxrwx.  3 mysql mysql 4096 Jul  9 02:21 mysql
  1. Modify the my.cnf file.
 [root@localhost home]# vi /etc/my.cnf
# For advice on how to change settings please see
# http://dev.mysql.com/doc/refman/5.7/en/server-configuration-defaults.html
[mysqld]
# Remove leading # and set to the amount of RAM for the most important data
# cache in MySQL. Start at 70% of total RAM for dedicated server, else 10%.
# innodb_buffer_pool_size = 128M
# Remove leading # to turn on a very important data integrity option: logging
# changes to the binary log between backups.
# log_bin
# Remove leading # to set options mainly useful for reporting servers.
# The server defaults are faster for transactions and fast SELECTs.
# Adjust sizes as needed, experiment to find the optimal values.
# join_buffer_size = 128M
# sort_buffer_size = 2M
# read_rnd_buffer_size = 2M
#datadir=/var/lib/mysql
#socket=/var/lib/mysql/mysql.sock
datadir=/home/mysql
socket=/home/mysql/mysql.sock
# Disabling symbolic-links is recommended to prevent assorted security risks
symbolic-links=0
log-error=/home/mysqllog/mysqld.log
innodb_log_group_home_dir=/home/mysqllog
pid-file=/var/run/mysqld/mysqld.pid
skip-grant-tables
[client]
default-character-set=utf8
socket =/home/mysql/mysql.sock
 [mysql]
"/etc/my.cnf" 44L, 1177C written
  1. Move the files in /var/lib/mysql/ to /home/mysql/.
[root@localhost home]# mv /var/lib/mysql/*  /home/mysql
[root@localhost home]# cd mysql
[root@localhost mysql]# ll
total 110668
-rw-r-----. 1 mysql mysql       56 Jul  6 04:52 auto.cnf
-rw-------. 1 mysql mysql     1679 Jul  6 04:52 ca-key.pem
-rw-r--r--. 1 mysql mysql     1107 Jul  6 04:52 ca.pem
-rw-r--r--. 1 mysql mysql     1107 Jul  6 04:52 client-cert.pem
-rw-------. 1 mysql mysql     1679 Jul  6 04:52 client-key.pem
-rw-r-----. 1 mysql mysql      299 Jul  9 02:24 ib_buffer_pool
-rw-r-----. 1 mysql mysql 12582912 Jul  9 02:24 ibdata1
-rw-r-----. 1 mysql mysql 50331648 Jul  9 02:24 ib_logfile0
-rw-r-----. 1 mysql mysql 50331648 Jul  6 04:51 ib_logfile1
drwx------. 2 mysql mysql    16384 Jul  9 02:21 lost+found
drwxr-x---. 2 mysql mysql     4096 Jul  6 04:52 mysql
drwxr-x---. 2 mysql mysql     4096 Jul  6 04:52 performance_schema
-rw-------. 1 mysql mysql     1679 Jul  6 04:52 private_key.pem
-rw-r--r--. 1 mysql mysql      451 Jul  6 04:52 public_key.pem
-rw-r--r--. 1 mysql mysql     1107 Jul  6 04:52 server-cert.pem
-rw-------. 1 mysql mysql     1675 Jul  6 04:52 server-key.pem
drwxr-x---. 2 mysql mysql    12288 Jul  6 04:52 sys
  1. Set the state of SELinux to disabled and reboot.
[root@localhost mysql]# vi /etc/selinux/config
# This file controls the state of SELinux on the system.
# SELINUX= can take one of these three values:
#     enforcing - SELinux security policy is enforced.
#     permissive - SELinux prints warnings instead of enforcing.
#     disabled - No SELinux policy is loaded.
SELINUX=disabled
# SELINUXTYPE= can take one of three two values:
#     targeted - Targeted processes are protected,
#     minimum - Modification of targeted policy. Only selected processes are protected.
#     mls - Multi Level Security protection.
SELINUXTYPE=targeted
"/etc/selinux/config" 14L, 546C written
[root@localhost mysql]# reboot
