Recommended disk configuration
Caches
Allocate a minimum of 50 GB of cache to each disk.
  • Cache settings cannot be modified after UIS setup finishes. If HDD expansion is required, reserve SSD space in storage planning.
  • Make sure the size of each cache partition multiplied by the number of data disks on a storage node is smaller than the total size of SSDs deployed as caches. For example, a storage node has two 600-GB SSDs and eight HDDs, and the SSDs provide 100 GB of cache for each HDD. The total cache size is 800 GB, which is smaller than the total size of the cache disks. Typically, the actual size of a disk is smaller than the claimed size. Please use the actual size to plan storage. For illustration purposes, this document uses the claimed size.
  • Use RAID 0 on each SSD.
  • Do not use read-intensive SSDs as cache disks, Intel S3500 series SSDs for example.
Recommended SSD to HDD ratios are as follows:
NVMe SSDs of different models differ greatly in performance. As a best practice, use NVMe SSDs that support an IOPS of 200000 or higher.
To ensure performance, do not enable disk caching when SSDs are not enough.
Metadata disks
Metadata is used to manage the user data stored on a storage system. For high performance, save metadata on dedicated SSDs.
Storage data disks
ONEStor ensures data availability through replicas. If N replicas are used, the available capacity is the raw capacity divided by N.
