钩子脚本是SVN库中hooks/目录下的文件,通过配置钩子脚本可以实现SVN库中代码变更自动触发流水线任务。在使用SVN代码库前需执行本操作。
下载钩子脚本文件:
单击左侧导航树中的[项目]菜单项,单击对应的项目链接或新建项目进入项目管理页面。
单击<交付>按钮,进入项目交付页面。
单击<新建流水线>按钮,选择场景模板。
在初始配置页面的选择“监听设置”为自动触发,“代码库”选择对应的SVN代码库。
单击<下载钩子脚本并根据说明完成SVN服务配置>按钮下载钩子脚本文件post-commit。
单击<查看脚本命令>按钮查看本流水线对应的curl脚本命令,并复制此curl脚本命令。
在SVN仓库所在的服务器上为post-commit文件授权,执行“chmod 700 post-commit”命令。
可选如下两种方式之一编辑钩子脚本:
以文本方式打开或通过notepad++工具打开post-commit文件,将复制的curl脚本命令复制在“##流水线接口连接”之后,保存后将编辑好的post-commit文件传输到对应的SVN仓库下面的hooks/目录。
将post-commit文件传输到对应的SVN仓库下面的hooks/目录,然后通过“vi post-commit”命令在SVN仓库所在的服务器上编辑post-commit文件,将复制的curl脚本命令复制在“##流水线接口连接”之后。
目前只支持Linux系统的SVN服务器。
SVN仓库所在服务器必须支持curl命令。
一个SVN仓库下只能有一个post-commit文件,如果想对接不同的流水线,请负载流水线对应的curl脚本命令到指定位置。
用户可直接复制curl脚本命令,无需再进行编辑。流水线对应的curl脚本命令的格式为:curl -i -X POST -H "content-type: application/json" -H "user_id:f1f7562f-ce80-44e6-bcea-b3c315b27c75" -H "x-auth-token:43b64e61-347c-4123-abb2-34de4acdfff0" http://10.51.93.1:34568/api/v1.0/fluxes?Action=AddExecution -d '{"pipelineId":"1538740266939187200","parameters":{},"note":""}'
#!/bin/sh
# POST-COMMIT HOOK
# The post-commit hook is invoked after a commit. Subversion runs
# this hook by invoking a program (script, executable, binary, etc.)
# named 'post-commit' (for which this file is a template) with the
# following ordered arguments:
# [1] REPOS-PATH (the path to this repository)
# [2] REV (the number of the revision just committed)
# [3] TXN-NAME (the name of the transaction that has become REV)
# Because the commit has already completed and cannot be undone,
# the exit code of the hook program is ignored. The hook program
# can use the 'svnlook' utility to help it examine the
# newly-committed tree.
# The default working directory for the invocation is undefined, so
# the program should set one explicitly if it cares.
# On a Unix system, the normal procedure is to have 'post-commit'
# invoke other programs to do the real work, though it may do the
# work itself too.
# Note that 'post-commit' must be executable by the user(s) who will
# invoke it (typically the user httpd runs as), and that user must
# have filesystem-level permission to access the repository.
# On a Windows system, you should name the hook program
# 'post-commit.bat' or 'post-commit.exe',
# but the basic idea is the same.
# The hook program runs in an empty environment, unless the server is
# explicitly configured otherwise. For example, a common problem is for
# the PATH environment variable to not be set to its usual value, so
# that subprograms fail to launch unless invoked via absolute path.
# If you're having unexpected problems with a hook program, the
# culprit may be unusual (or missing) environment variables.
# CAUTION:
# For security reasons, you MUST always properly quote arguments when
# you use them, as those arguments could contain whitespace or other
# problematic characters. Additionally, you should delimit the list
# of options with "--" before passing the arguments, so malicious
# clients cannot bootleg unexpected options to the commands your
# script aims to execute.
# For similar reasons, you should also add a trailing @ to URLs which
# are passed to SVN commands accepting URLs with peg revisions.
# Here is an example hook script, for a Unix /bin/sh interpreter.
# For more examples and pre-written hooks, see those in
# the Subversion repository at
# http://svn.apache.org/repos/asf/subversion/trunk/tools/hook-scripts/ and
# http://svn.apache.org/repos/asf/subversion/trunk/contrib/hook-scripts/
# POST-COMMIT HOOK
#svn 钩子脚本配置:
#1.点击“下载钩子脚本” 下载文件(post-commit)
#2.点击“查看脚本命令”:curl命令
# 注意:
# 1.下载钩子脚本(post-commit)名称和后缀不能修改,没有后缀
# 2.原来仓库下面/hooks/目录下面的其他文件不需要动,比如:post-commit.tmpl等不要动
# 3.服务器必须支持curl命令的运行
# 4.授权:chmod 700 post-commit
#3.将下载的post-commit文件放入仓库下面(仓库下面/hooks/目录下)
# 注意:
# 1.如果仓库下面/hooks/目录下已经有post-commit文件(不是post-commit.tmpl文件),不需要替换(已有数据),vi post-commit(文件看下内容:是否是下载的基础脚本和查看脚本命令curl)
# 2.如果仓库下面/hooks/目录下没有post-commit文件,将下载的post-commit文件仓库下面/hooks/目录下
#4.编写脚本(post-commit)
# vi post-commit将第2步的curl命令复制到##流水线接口连接下面。保存退出。
# 注意:1.可以配置多个流水线,就可以编辑多个curl命令行
# 2.SVN存在多仓库,多项目,多流水线问题,所以这里需要自动触发的流水线,需要添加进来。
# 常见问题:
# 1.SVN提交代码时候报错:Error: post-commit hook failed (exit code 255) with no output.
# 解决方式:进入服务器授权:chmod 700 post-commit
REPOS="$1"
REV="$2"
TXN_NAME="$3"
$(> ${REPOS}/temp)
for a in `svnlook dirs-changed ${REPOS} -r ${REV}`
do
echo -n ${a}, >> ${REPOS}/temp
done
dirsfiles=$(cat ${REPOS}/temp)
dirsfiles=${dirsfiles%*,}
##流水线接口连接
