CLI方式:三层直路部署典型配置
使用版本
本举例是在F1090的R8660P33版本上进行配置和验证的。
组网需求
如下图所示,Host A、Host B和Server通过Switch、Device与Internet通信,应用需求如下:
图-1 Device三层直路部署组网图
配置步骤
配置Device
  1. 配置接口IP
# 配置接口GigabitEthernet1/0/1和GigabitEthernet1/0/2的IP地址。
[Device-GigabitEthernet1/0/1] ip address 20.1.1.1 24
[Device-GigabitEthernet1/0/2] ip address 10.1.1.1 24
  1. 配置静态路由
# 配置默认路由指导上行流量转发(此处下一跳以20.1.1.3为例,请以实际情况为准)。
[Device] ip route-static 0.0.0.0 0 20.1.1.3
  1. 配置接口加入安全域
# 将GigabitEthernet1/0/1和GigabitEthernet1/0/2分别加入安全域Untrust和Trust中。
[Device] security-zone name untrust
[Device-security-zone-Untrust] import interface gigabitethernet 1/0/1
[Device-security-zone-Untrust] quit
[Device] security-zone name trust
[Device-security-zone-Trust] import interface gigabitethernet 1/0/2
  1. 配置DHCP服务
# 配置DHCP地址池1,用来为10.1.1.0/24网段内的客户端分配IP地址和网络配置参数。
[Device] dhcp server ip-pool 1
[Device-dhcp-pool-1] network 10.1.1.0 24
[Device-dhcp-pool-1] gateway-list 10.1.1.1
[Device-dhcp-pool-1] dns-list 20.1.1.15
[Device-dhcp-pool-1] forbidden-ip 10.1.1.2
[Device-dhcp-pool-1] quit
# 开启DHCP服务。
[Device] dhcp enable
  1. 配置NAT服务
# 配置地址组0,包含外网地址20.1.1.2。
[Device] nat address-group 0
[Device-address-group-0] address 20.1.1.2 20.1.1.2
[Device-address-group-0] quit
# 配置全局NAT规则1,允许使用地址组0中的地址对匹配的报文进行源地址转换。
[Device] nat global-policy
[Device-nat-global-policy] rule name 1
[Device-nat-global-policy-rule-1] source-zone trust
[Device-nat-global-policy-rule-1] destination-zone untrust
[Device-nat-global-policy-rule-1] source-ip subnet 10.1.1.0 24
[Device-nat-global-policy-rule-1] action snat address-group 0
[Device-nat-global-policy-rule-1] quit
# 配置全局NAT规则2,允许外网主机访问20.1.1.2的21端口时进行目的地址转换,并转换为内网FTP服务器的21端口。
[Device-nat-global-policy] rule name 2
[Device-nat-global-policy-rule-2] source-zone untrust
[Device-nat-global-policy-rule-2] destination-ip host 20.1.1.2
[Device-nat-global-policy-rule-2] service ftp
[Device-nat-global-policy-rule-2] action dnat ip-address 10.1.1.2 local-port 21
[Device-nat-global-policy-rule-2] quit
[Device-nat-global-policy] quit
  1. 配置安全策略
# 配置安全策略dhcpin允许用户发送的DHCP协议报文通过。
[Device] security-policy ip
[Device-security-policy-ip] rule name dhcpin
[Device-security-policy-ip-0-dhcpin] action pass
[Device-security-policy-ip-0-dhcpin] source-zone trust
[Device-security-policy-ip-0-dhcpin] destination-zone local
[Device-security-policy-ip-0-dhcpin] service dhcp-server
[Device-security-policy-ip-0-dhcpin] quit
# 配置安全策略dhcpout允许设备回复用户的DHCP协议报文通过。
[Device-security-policy-ip] rule name dhcpout
[Device-security-policy-ip-1-dhcpout] action pass
[Device-security-policy-ip-1-dhcpout] source-zone local
[Device-security-policy-ip-1-dhcpout] destination-zone trust
[Device-security-policy-ip-0-dhcpin] service dhcp-client
[Device-security-policy-ip-1-dhcpout] quit
# 配置安全策略trust-untrust允许trust安全域源地址范围为10.1.1.0/24的用户访问untrust安全域网络。
[Device-security-policy-ip] rule name trust-untrust
[Device-security-policy-ip-2-trust-untrust] action pass
[Device-security-policy-ip-2-trust-untrust] source-zone trust
[Device-security-policy-ip-2-trust-untrust] destination-zone untrust
[Device-security-policy-ip-2-trust-untrust] source-ip-subnet 10.1.1.0 24
[Device-security-policy-ip-2-trust-untrust] quit
# 配置安全策略untrust-trust允许untrust安全域网络访问trust安全域目的地址为10.1.1.2的FTP服务器。
[Device-security-policy-ip] rule name untrust-trust
[Device-security-policy-ip-3-untrust-trust] action pass
[Device-security-policy-ip-3-untrust-trust] source-zone untrust
[Device-security-policy-ip-3-untrust-trust] destination-zone trust
[Device-security-policy-ip-3-untrust-trust] destination-ip-host 10.1.1.2
[Device-security-policy-ip-3-untrust-trust] quit
[Device-security-policy-ip] quit
验证配置
# Host A、Host B上ping测试Internet的连通性,可以ping通Internet地址20.1.1.3。
C:\>ping 20.1.1.3
Pinging 20.1.1.3 with 32 bytes of data:
Reply from 20.1.1.3: bytes=32 time=3ms TTL=254
Reply from 20.1.1.3: bytes=32 time=2ms TTL=254
Reply from 20.1.1.3: bytes=32 time=1ms TTL=254
Ping statistics for 20.1.1.3:
    Minimum = 1ms, Maximum = 3ms, Average = 2ms
# 在Device上检查会话表,存在Host与20.1.1.3的会话表。
[Device] display session table ipv4
Slot 1:
Initiator:
  Source      IP/port: 10.1.1.6/229
  Destination IP/port: 20.1.1.3/2048
  DS-Lite tunnel peer: -
  Protocol: ICMP(1)
  Inbound interface: GigabitEthernet1/0/2
  Source security zone: Trust
Initiator:
  Source      IP/port: 10.1.1.7/229
  Protocol: ICMP(1)
Total sessions found: 2
# 在Device上检查NAT会话的简要信息。
[Device]display nat session brief
Slot 1:
Protocol   Source IP/port         Destination IP/port    Global IP/port
ICMP       10.1.1.6/229           20.1.1.3/2048          20.1.1.2/0
ICMP       10.1.1.7/229           20.1.1.3/2048          20.1.1.2/0
# 外网设备可以通过FTP目的地址20.1.1.2来访问内网地址为10.1.1.2的FTP服务器。
配置文件
Device
nat address-group 0
 dhcp enable
 network 10.1.1.0 mask 255.255.255.0
 dns-list 20.1.1.15
 ip address 20.1.1.1 255.255.255.0
security-zone name Trust
 import interface GigabitEthernet1/0/2
security-zone name Untrust
 import interface GigabitEthernet1/0/1
nat global-policy
 rule name 2
  service ftp
  source-zone untrust
 rule name 1
  source-zone trust
security-policy ip
 rule 0 name dhcpin
  action pass
  source-zone trust
 rule 1 name dhcpout
  action pass
  source-zone local
 rule 2 name trust-untrust
  action pass
  source-zone trust
  source-ip-subnet 10.1.1.0 255.255.255.0
 rule 3 name untrust-trust
  action pass
  source-zone untrust
