You can add bare metal nodes one by one or import bare metal nodes in bulk.
On the top navigation bar, click Resources.
From the left navigation pane, select Bare Metal.
Click Import.
On the page that opens, click Download Template in the upper right corner of the page.
Open the downloaded template, and enter the information as described in Table-1.
Click Select File, and then select the saved configuration file, in the CSV format.
Review the information in the template, and then click Import.
Table-1 Filling information in the template
Item |
Flat network |
Multi-tenant network |
IPMI Address |
Required. Enter the IPMI IP address of the server. This address must be unique. |
IPMI User |
Required. Enter the IPMI username for logging in to the server. |
IPMI Password |
Required. Enter the IPMI password for logging in to the server. |
User |
Required. Enter the name of the user to which the bare metal instance belongs (user name specified on the System > Organization Management page). The user can see the instance being created on the Cloud Services > Compute > Bare Metal page. If you leave this field empty, the bare metal instance belongs to the current user. |
AZ |
Required. AZ to which the bare metal server belongs. |
Host Name |
Required. Enter the host name of the operating system. This name will also be used as the name of the bare metal instance. |
Administrator Name |
Required. Enter the name of the administrator. Enter root for a Linux operating system. |
Administrator Password |
Required. Password used for logging in to the operating system after the instance is created successfully. |
Image Name |
Required. Enter the name of the image created for creating the bare metal instance. |
Management Network |
Enter the management network you created. For a flat network, you can configure only one management network for each bare metal node. The network name must start with ironicMagNet, and must be a shared network. |
N/A |
Management Network IP |
Required. Specify a management network address. It must be an available IPv4 address in the management IP address pool. |
N/A |
Management Network VLAN ID |
Optional. Enter the VLAN ID (segment ID) of the management network. If you leave this field empty, no VLAN ID is deployed to the management network. |
N/A |
Service Network 1 |
The following restrictions and guidelines apply to all service networks 1, 2, and 3. If you do not configure a service network, leave all the four fields empty. If you configure a service network but do not require aggregation, specify a service network, a service network IP, and NICs. If you require aggregation, specify all the four fields. |
Optional.
Optional.
Service Network 1 IP |
Network 1 Bonding Mode |
Service Network 1 Bond NIC |
Service Network 2 |
Service Network 2 IP |
Service Network 2 Bonding Mode |
Service Network 2 Bond NIC |
Service Network 3 |
Service Network 3 IP |
Service Network 3 Bonding Mode |
Gateway |
Optional. Options are 0, 1, 2, and 3. 0 represents the management network's gateway. 1 represents service network 1's gateway. 2 represents service network 2's gateway. 3 represents service network 3's gateway. |
Remarks |
Optional. |
Optional. |
Tenancy |
Optional. Specify the tenancy of the bare metal node. You must select a tenancy from the tenancy list on the Tenancy Settings tab on the System > System Settings > Operations Settings > Tenancy Management page. |
Incorporated |
Optional. Configure whether to incorporate the bare metal node. If you leave this field empty, the bare metal node will not be incorporated. |
Boot Mode |
Optional. The default boot mode of a bare metal node is Legacy. UEFI is a new BIOS and Legacy is a legacy BIOS. If you install the system in UEFI mode, you can only access the system in UEFI mode. If you install the system in Legacy mode, you can only access the system in Legacy mode. |
VPC Name |
Required if you select the VPC network as the management network. The default management network is the legacy network. |
Architecture |
x86 and ARM are supported. An x86 server support both legacy and UEFI boot modes. An ARM server supports only the UEFI boot mode. |
Click Create.
In the dialog box that opens, configure bare metal node parameters as required.
Item |
IPMI Address |
IPMI User |
IPMI Password |
Server Model |
Select a server model. |
Managed |
Architecture |
Select an architecture. x86 and ARM are supported. An x86 server support both legacy and UEFI boot modes. An ARM server supports only the UEFI boot mode. |
Boot Mode |
Select a boot mode. Please make sure the boot mode you select is the same as that for the server you use. |
Click OK.
