Manage disks for cloud hosts
You can perform this task to attach cloud disks to cloud hosts or detach cloud disks from cloud hosts. Cloud disks provide block storage, which can be formatted or used to create file systems like physical disks. For more information, see see cloud disks in the cloud services guide.
Attach cloud disks to a cloud host
  1. On the top navigation bar, click Cloud Services, and then select Cloud Hosts from the Compute menu.
  1. Click More for the target cloud host and then select Attach Disk. If you have enabled Configure a device name in mounting a cloud disk to a cloud host in cloud host settings, you can customize the device name in the Device Name column.
  1. Click Attach for the target cloud disks.
Detach cloud disks from a cloud host
This task will interrupt services provided by the cloud host. Before performing this task, make sure the cloud host services are allowed to be interrupted.
  1. Click More for the target cloud host and then select Detach Disk.
  1. Click Detach for the target cloud disks.
