Access a Windows cloud host
Access through the console
  1. On the top navigation bar, click Cloud Services, and then select Cloud Hosts from the Compute menu.
  1. If a system-generated password is used for cloud host access, click the name of the target cloud host, and then click the  icon in the Basic Info are to obtain the password.
Figure-1 Viewing the system-generated password
  1. Return to the cloud host list, and click Console for the target cloud host.
  1. Enter the password to access the operating system of the cloud host.
Access through MSTSC
To use this method, make sure the local PC can reach the cloud host network.
At the first login through MSTSC, you must first enable remote connection for the cloud host. This section takes the first login as an example. At subsequent logins, you can start from step 4.
To access a cloud host through MSTSC:
  1. Access the console of the cloud host. For more information, see "Access through the console."
  1. Open the Start menu, click Control Panel. Then, click System and click Remote Settings.
  1. Click the Remote tab, select Allow Remote Assistance connections to this computer, and then click OK.
  1. Open the Start menu of the local PC, enter mstsc in the search box, and then press Enter. Then, access the cloud host as instructed.
