05-二层技术-以太网交换命令参考
06-LLDP命令
本章节下载  (347.04 KB)
docurl=/cn/Service/Document_Software/Document_Center/Home/Security/00-Public/Command/Command_Manual/H3C_CR(V7)(R8504_R8130_R8127_R8522)-6W302/05/202012/1366966_30005_0.htm
06-LLDP命令
1 LLDP
1.1  LLDP配置命令
1.1.1  display lldp local-information
display lldp local-information命令用来显示LLDP本地信息。
context-admin
context-operator
global:显示全局LLDP本地信息。
interface interface-type interface-number:显示指定接口上的LLDP本地信息,interface-type interface-number表示接口类型和接口编号。
如果未指定任何参数,将显示所有LLDP本地信息,包括全局LLDP信息以及所有开启了LLDP功能且状态为up的接口上的LLDP信息。
# 显示所有LLDP本地信息。
<Sysname> display lldp local-information
 Chassis ID          : 00e0-fc00-5600
 System name         : Sysname
 System description  : H3C Comware Software. Software Version 7.1.064, Ess 8130P
                       09
                       H3C SecBlade III ADE Module
                       Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. Al
                       l rights reserved.
 System capabilities supported  : Bridge, Router, Customer Bridge, Service Bridge
 System capabilities enabled    : Bridge, Router, Service Bridge
 MED information:
 Device class               : Connectivity device
 MED inventory information of master board:
 HardwareRev                : REV.A
 FirmwareRev                : 109
 SoftwareRev                : 5.20 Alpha 2101
 SerialNum                  : 210235A1D5H142000032
 Manufacturer name          : H3C
 Model name                 : SecPath F5020
 Asset tracking identifier  : Unknown
LLDP local-information of port 2[GigabitEthernet1/0/1]:
 Port ID type       : Interface name
 Port ID            : GigabitEthernet1/0/1
 Port description   : GigabitEthernet1/0/1 Interface
 LLDP agent nearest-bridge management address:
 Management address type           : IPv4
 Management address                : 192.168.80.60
 Management address interface ID   : Unknown
 Management address OID            : 0
 LLDP agent nearest-nontpmr management address:
 Management address                : 192.168.80.61
 LLDP agent nearest-customer management address:
 Management address                : 192.168.80.62
 Link aggregation enabled   : Yes
 Aggregation port ID        : 52
 Auto-negotiation enabled   : Yes
 OperMau                    : Speed(1000)/Duplex(Full)
 Power port class           : PD
 PSE power supported        : NO
 PSE power enabled          : NO
 PSE pairs control ability  : NO
 Power pairs                : Signal
 Port power classification  : Class 0
 Maximum frame size         : 9216
 Transmit Tw                : 0 us
 Receive Tw                 : 0 us
 Fallback Tw                : 0 us
 Echo Transmit Tw           : 0 us
 Echo Receive Tw            : 0 us
 PoE PSE power source       : Unknown
 Port PSE priority          : Unknown
 Port available power value : 0.0 w
表1-1 display lldp local-information命令显示信息描述表
本设备的全局LLDP本地信息
Chassis ID
Chassis ID值,为本设备的桥MAC地址
System name
系统名称
System description
系统描述
系统所支持的功能:
·     Bridge:表示支持交换功能
·     Router:表示支持路由功能
·     Customer Bridge:表示支持客户桥功能
·     Service Bridge:表示支持服务桥功能
系统已开启的功能:
·     Bridge:表示交换功能已开启
·     Router:表示路由功能已开启
·     Customer Bridge:表示客户桥功能已开启
·     Service Bridge:表示服务桥功能已开启
MED information
MED设备相关信息
Device class
MED设备类型:
·     Connectivity device:表示网络设备
·     Class I:表示一般终端设备,即所有需要LLDP发现服务的终端设备
·     Class II:表示媒体终端设备,即具备媒体能力的终端设备,其能力包含了一般终端设备的能力。该类设备支持媒体流
·     Class III:表示通讯终端设备,即直接支持目标用户IP通讯系统的终端设备,其能力包含了一般终端设备和媒体终端设备的所有能力。该类设备直接被目标用户所使用
主控板MED资产信息
HardwareRev
产品的硬件版本
FirmwareRev
产品的固件版本
SoftwareRev
产品的软件版本
SerialNum
序列号
Manufacturer name
制造厂商
Model name
模块名称
资产跟踪ID
LLDP local-information of port 1
端口1上LLDP本地信息
Port ID type
端口ID类型:
·     MAC address:表示MAC地址
·     Interface name:表示接口名称
Port ID
端口ID值,根据本设备的Port ID type取相应类型的值
Port description
端口描述
LLDP最近桥代理的管理地址
LLDP最近客户桥代理的管理地址
LLDP最近非TPMR桥代理的管理地址
管理地址类型
Management address
管理地址
管理地址所在接口的编码方式
管理地址接口索引
管理地址对象标识符
端口是否支持链路聚合
端口是否已开启链路聚合
Aggregation port ID
聚合组中该成员端口的编号,未开启链路聚合功能时为0
端口是否支持自协商
端口是否已开启自协商
OperMau
端口自适应的速率和双工状态
Power port class
PoE类型:
·     PSE(Power Sourcing Equipment,供电设备)
·     PD(Powered Device,受电设备)
PSE power supported
是否支持PSE供电
PSE power enabled
是否已开启PSE供电
供电方式是否可控
Power pairs
PoE端口的远程供电模式:
·     Signal:表示信号线供电模式
·     Spare:表示空闲线供电模式
PD的端口控制级别:
·     Class 0:表示级别0
·     Class 1:表示级别1
·     Class 2:表示级别2
·     Class 3:表示级别3
·     Class 4:表示级别4
Maximum frame size
端口支持的最大帧长度
PSE所采用的电源类型:
·     Unknown:表示采用的电源类型未知
·     Primary:表示采用主用电源作为电源
·     Backup:表示采用备用电源作为电源
Port PSE priority
PSE上端口的供电优先级:
·     Unknown:表示优先级未知
·     Critical:表示优先级为1级
·     High:表示优先级为2级
·     Low:表示优先级为3级
PSE上端口可提供的功率,或PD上端口所需的功率,单位为瓦特
Transmit Tw
本端发送的等待时间,单位为微秒
Receive Tw
本端向对端请求的等待时间,单位为微秒
Fallback Tw
本端向对端请求的候选等待时间,单位为微秒
Echo Transmit Tw
收到的对端发送的等待时间,单位为微秒
Echo Receive Tw
收到的对端请求的等待时间,单位为微秒
1.1.2  display lldp neighbor-information
display lldp neighbor-information命令用来显示由邻居设备发来的LLDP信息。
context-admin
context-operator
interface interface-type interface-number:显示指定接口收到的由邻居设备发来的LLDP信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有接口收到的由邻居设备发来的LLDP信息。
agent:显示指定类型LLDP代理收到的由邻居设备发来的LLDP信息。如果未指定该参数,将显示所有类型LLDP代理收到的由邻居设备发来的LLDP信息。
nearest-bridge:表示最近桥代理。
nearest-customer:表示最近客户桥代理。
nearest-nontpmr:表示最近非TPMR桥代理。
verbose:显示由邻居设备发来的LLDP详细信息。如果未指定该参数,将显示由邻居设备发来的LLDP概要信息。
list:按列表显示由邻居设备发来的LLDP信息。
system-name system-name:按列表显示由指定邻居设备发来的LLDP信息。system-name表示邻居设备的系统名称,为1~255个字符的字符串。如果未指定该参数,将按列表显示由所有邻居设备发来的LLDP信息。
# 显示所有接口最近桥代理收到的由邻居设备发来的LLDP详细信息。
<Sysname> display lldp neighbor-information agent nearest-bridge verbose
LLDP neighbor-information of port 1[GigabitEthernet1/0/1]:
LLDP agent nearest-bridge:
 LLDP Neighbor index : 1
 Update time         : 0 days, 0 hours, 1 minutes, 1 seconds
 Chassis type        : MAC address
 Chassis ID          : 000f-0055-0002
 Time to live        : 121
 System description  : H3C Comware Platform Software, Software Version 7.1.064,
                       Alpha 7164
                       H3C Simware32
                       l rights reserved.
 System capabilities enabled   : Bridge, Router, Customer Bridge
 Management address                : 192.168.1.55
 Port VLAN ID(PVID): 1
 Management VLAN ID  : 5
 PSE power supported        : Yes
 PSE power enabled          : Yes
 PSE pairs control ability  : Yes
 Maximum frame size         : 10000
 Transmit Tw                : 100 us
 Receive Tw                 : 90 us
 Fallback Tw                : 90 us
 PoE PSE power source       : Primary
 Port PSE priority          : Low
 Port available power value : 2.2 w
# 显示所有接口所有类型LLDP代理收到的由邻居设备发来的LLDP概要信息。
LLDP neighbor-information of port 52[GigabitEthernet1/0/3]:
 LLDP neighbor index : 3
 ChassisID/subtype   : 0011-2233-4400/MAC address
 PortID/subtype      : 000c-29f5-c71f/MAC address
 Capabilities        : Bridge, Router, Customer Bridge
 LLDP neighbor index : 6
 PortID/subtype      : 000c-29f5-c715/MAC address
 Capabilities        : None
LLDP agent nearest-nontpmr:
 Capabilities        : None
# 按列表显示类型LLDP代理所有邻居设备发来的LLDP信息。
Chassis ID : * -- --Nearest nontpmr bridge neighbor
             # -- --Nearest customer bridge neighbor
             Default -- -- Nearest bridge neighbor
System Name          Local Interface   Chassis ID       Port ID
System1              GE1/0/1           000f-e25d-ee91 GigabitEthernet1/0/1
表1-2 display lldp neighbor-information命令显示信息描述表
LLDP缺省代理,即最近桥代理
LLDP最近客户桥代理
LLDP最近非TPMR桥代理
端口1上收到的LLDP邻居信息
LLDP Neighbor index
邻居索引
Update time
邻居信息最新更新时间
Chassis type
Chassis ID类型:
·     Chassis component:表示底架组件
·     Interface alias:表示接口别名
·     Port component:表示端口组件
·     Network address(ipv4):表示网络地址(括号里表示地址类型)
·     Locally assigned:表示邻居自定义
Chassis ID
Chassis ID值,根据邻居设备的Chassis type取相应类型的值
Port ID type
端口ID类型:
·     Network Address(ipv4):表示网络地址(括号里表示地址类型)
·     Agent circuit ID:表示代理巡回标识
Port ID
端口ID值,根据邻居设备的Port ID type取相应类型的值
Time to live
邻居信息在本地的存活时间
Port description
端口描述
System name
系统名称
System description
系统描述
系统所支持的功能:
·     Repeater:表示支持信号中继功能
·     Bridge:表示支持交换功能
·     Router:表示支持路由功能
系统已开启的功能:
·     Bridge:表示交换功能已开启
·     Router:表示路由功能已开启
管理地址类型
Management address
管理地址
管理地址接口类型
管理地址接口索引
管理地址对象标识符
Port VLAN ID
端口VLAN ID
端口是否支持链路聚合
端口是否已开启链路聚合
Aggregation port ID
Management VLAN ID
管理VLAN ID
端口是否支持自协商
端口是否已开启自协商
OperMau
端口自适应的速率和双工状态
Power port class
PoE类型:
·     PSE:表示供电设备
·     PD:表示受电设备
PSE power supported
是否支持PSE供电
PSE power enabled
是否已开启PSE供电
供电方式是否可控
Power pairs
PoE端口的远程供电模式:
·     Signal:表示信号线供电模式
·     Spare:表示空闲线供电模式
PD的端口控制级别:
·     Class 0:表示级别0
·     Class 1:表示级别1
·     Class 2:表示级别2
·     Class 3:表示级别3
·     Class 4:表示级别4
Power type
供电类型:
·     Type 1 PD:表示类型1 PD
·     Type 2 PD:表示类型2 PD
·     Type 1 PSE:表示类型1 PSE
·     Type 2 PSE:表示类型2 PSE
Power source
功率来源(功率来源根据供电类型为PD类型或PSE类型,取值不同):
PSE
·     Reserved:保留
PD
·     PSE:表示采用PSE作为电源
·     Local:表示采用本地电源作为电源
·     PSE and local:表示采用PSE和本地电源作为电源
Power priority
功率优先级:
·     Unknown:表示优先级未知
·     Critical:表示优先级为1级
·     High:表示优先级为2级
·     Low:表示优先级为3级
PD requested power value
PD请求功率值,单位为瓦特
PSE allocated power value
PSE分配功率值,单位为瓦特
Maximum frame size
端口支持的最大帧长度
PSE所采用的电源类型:
PoE PD power source
PD所采用的电源类型:
·     PSE:表示采用PSE作为电源
PoE service type
PoE服务类型
Port PSE priority
PSE上端口的供电优先级:
·     Unknown:表示优先级未知
·     Critical:表示优先级为1级
·     High:表示优先级为2级
·     Low:表示优先级为3级
Port PD priority
PD上端口的受电优先级:
·     Unknown:表示优先级未知
·     Critical:表示优先级为1级
·     High:表示优先级为2级
·     Low:表示优先级为3级
HardwareRev
产品的硬件版本
FirmwareRev
产品的固件版本
SoftwareRev
产品的软件版本
SerialNum
序列号
Manufacturer name
制造厂商
Model name
模块名称
资产跟踪ID
Unknown basic TLV
未知的基本TLV
TLV type
未知的基本TLV类型
TLV information
未知的基本TLV的具体信息
Unknown organizationally-defined TLV
未知组织定义TLV
TLV OUI
未知组织定义TLV的对象唯一标识
TLV subtype
未知的组织定义TLV类型
Index
未知组织的索引
Chassis ID/subtype
Chassis ID值及Chassis ID类型
Port ID/subtype
Port ID值及PortID类型
Software version
邻居软件版本
Platform version
邻居平台版本
Duplex
双工状态
Capabilities
系统已开启的功能:
·     Bridge:表示开启交换功能
·     Router:表示开启路由功能
·     None:表示该邻居未发布该TLV
Local Interface
接收LLDP信息的本端端口
Chassis ID : * -- -- Nearest nontpmr bridge neighbor
                    #-- -- Nearest customer bridge neighbor
*符号:表示该邻居是最近非TPMR桥代理类型邻居
#符号:表示该邻居是最近客户桥代理类型邻居
Transmit Tw
本端发送的等待时间,单位为微秒
Receive Tw
本端向对端请求的等待时间,单位为微秒
Fallback Tw
Echo Transmit Tw
收到的对端发送的等待时间,单位为微秒
Echo Receive Tw
收到的对端请求的等待时间,单位为微秒
1.1.3  display lldp statistics
display lldp statistics命令用来显示LLDP的统计信息。
context-admin
context-operator
global:显示全局LLDP统计信息。
interface interface-type interface-number:显示指定接口上的LLDP统计信息,interface-type interface-number表示接口类型和接口编号。
agent:显示指定类型LLDP代理的统计信息。如果未指定该参数,将显示所有类型LLDP代理的统计信息。
如果未指定任何参数,将同时显示全局和接口上的LLDP统计信息。
# 显示全局和接口上的LLDP统计信息。
LLDP statistics global information:
LLDP neighbor information last change time:0 days, 0 hours, 4 minutes, 40 seconds
The number of LLDP neighbor information deleted  : 1
The number of LLDP neighbor information dropped  : 0
LLDP statistics information of port 1 [GigabitEthernet1/0/1]:
The number of LLDP frames transmitted            : 0
The number of LLDP frames received               : 0
The number of LLDP frames discarded              : 0
The number of LLDP error frames                  : 0
The number of LLDP TLVs discarded                : 0
The number of LLDP TLVs unrecognized             : 0
The number of CDP frames transmitted             : 0
The number of CDP frames received                : 0
The number of CDP frames discarded               : 0
The number of CDP error frames                   : 0
LLDP agent nearest-customer:
# 显示接口GigabitEthernet1/0/1的最近客户桥代理上的LLDP统计信息。
<Sysname> display lldp statistics interface gigabitethernet 1/0/1 agent nearest-customer
表1-3 display lldp statistics命令显示信息描述表
LLDP缺省代理,即最近桥代理
LLDP最近客户桥代理
LLDP最近非TPMR桥代理
全局LLDP统计信息
邻居信息的最后更新时间
邻居信息的增加次数
邻居信息的删除次数
由于空间不足而导致丢弃邻居信息的次数
邻居信息的老化数量
LLDP statistics Information of port 1
端口1上的LLDP统计信息
发送的LLDP帧总数
收到的LLDP帧总数
丢弃的LLDP帧总数
收到的错误LLDP帧总数
丢弃的LLDP TLV总数
不可识别的LLDP TLV总数
老化的LLDP邻居信息总数
(暂不支持)发送的CDP帧总数
(暂不支持)收到的CDP帧总数
(暂不支持)丢弃的CDP帧总数
(暂不支持)收到的错误CDP帧总数
1.1.4  display lldp status
display lldp status命令用来显示LLDP的状态信息。
context-admin
context-operator
interface interface-type interface-number:显示指定接口上的LLDP状态信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有开启了LLDP功能的接口上的LLDP状态信息。
agent:显示指定类型LLDP代理的状态信息。如果未指定该参数,将显示所有类型LLDP代理的状态信息。
# 显示全局和所有接口上的LLDP状态信息。
<Sysname> display lldp status
Global status of LLDP: Enable
The current number of LLDP neighbors: 5
Transmit interval              : 30s
Fast transmit interval         : 1s
Transmit max credit            : 5
Hold multiplier                : 4
Reinit delay                   : 2s
Trap interval                  : 5s
Fast start times               : 3
LLDP status information of port 1 [GigabitEthernet1/0/1]:
Port status of LLDP            : Enable
Admin status                   : TX_RX
Trap flag                      : No
MED trap flag                  : No
Polling interval               : 0s
Number of LLDP neighbors       : 5
Number of MED neighbors        : 2
Number of CDP neighbors        : 0
Number of sent optional TLV    : 12
Trap flag                      : No
MED trap flag                  : No
Trap flag                      : No
MED trap flag                  : No
表1-4 display lldp status命令显示信息描述表
Bridge mode of LLDP
LLDP桥模式:
·     service-bridge:表示服务桥模式
·     customer-bridge:表示客户桥模式
LLDP缺省代理,即最近桥代理
LLDP最近客户桥代理
LLDP最近非TPMR桥代理
LLDP功能是否已全局开启
当前设备的LLDP邻居总数
(暂不支持)当前设备的CDP邻居总数
邻居信息的最后更新时间
Transmit interval
LLDP报文的发送间隔
Hold multiplier
TTL乘数
Reinit delay
端口初始化延迟时间
Transmit max credit
LLDP报文发包限速令牌桶的最大值
Trap interval
Trap信息的发送间隔
Fast start times
快速发送LLDP报文的个数
LLDP status infomation of port 1
端口1上的LLDP状态信息
Port status of LLDP
LLDP功能是否已在端口上开启
Admin status
端口LLDP工作模式:
·     TX_RX:表示既发送也接收LLDP报文
·     Rx_Only:表示只接收不发送LLDP报文
·     Tx_Only:表示只发送不接收LLDP报文
·     Disable:表示既不发送也不接收LLDP报文
Trap Flag
LLDP Trap功能是否已开启
MED trap flag
LLDP-MED Trap功能是否已开启
Polling interval
轮询间隔,0表示轮询功能处于关闭状态
Number of neighbors
端口LLDP邻居数量
端口MED邻居设备的数量
(暂不支持)端口CDP邻居设备的数量
端口在一个LLDP报文中发送的可选TLV总数
端口在所有LLDP报文中收到的不能识别的TLV总数
1.1.5  display lldp tlv-config
display lldp tlv-config命令用来显示接口上可发送的可选TLV信息。
context-admin
context-operator
interface interface-type interface-number:显示指定接口上可发送的可选TLV信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有接口上可发送的可选TLV信息。
agent:显示指定类型LLDP代理的可选TLV信息。如果未指定该参数,将显示所有类型LLDP代理的可选TLV信息。
# 显示接口GigabitEthernet1/0/1上可发送的可选TLV信息。
<Sysname> display lldp tlv-config interface gigabitethernet 1/0/1
LLDP tlv-config of port 1[GigabitEthernet1/0/1]:
NAME                              STATUS    DEFAULT
Basic optional TLV:
 Port Description TLV             YES       YES
 System Name TLV                  YES       YES
 System Description TLV           YES       YES
 System Capabilities TLV          YES       YES
 Management Address TLV           YES       YES
IEEE 802.1 extend TLV:
 Port VLAN ID TLV                 YES       YES
 Port And Protocol VLAN ID TLV    YES       YES
 VLAN Name TLV                    YES       YES
 DCBX TLV                         NO        NO
 EVB TLV                          NO        NO
 Link Aggregation TLV             YES       YES
 Management VID TLV               YES       YES
IEEE 802.3 extend TLV:
 MAC-Physic TLV                   YES       YES
 Power via MDI TLV                YES       YES
 Maximum Frame Size TLV           YES       YES
LLDP-MED extend TLV:
 Network Policy TLV               YES        YES
 Location Identification TLV      NO         NO
 Extended Power via MDI TLV       YES YES
 Inventory TLV                    YES YES
NAME                              STATUS    DEFAULT
Basic optional TLV:
 Port Description TLV             YES       NO
 System Name TLV                  YES       NO
 System Description TLV           YES       NO
 System Capabilities TLV          YES       NO
 Management Address TLV           YES       NO
 Port VLAN ID TLV                 YES       NO
 Port And Protocol VLAN ID TLV    YES       NO
 VLAN Name TLV                    YES       NO
 DCBX TLV                         NO        NO
 EVB TLV                          YES       YES
 Link Aggregation TLV             YES       NO
 Management VID TLV               NO        NO
 MAC-Physic TLV                   YES       NO
 Power via MDI TLV                YES       NO
 Maximum Frame Size TLV           YES       NO
 Network Policy TLV               YES        NO
 Extended Power via MDI TLV       YES NO
 Inventory TLV                    YES NO
NAME                              STATUS    DEFAULT
Basic optional TLV:
 DCBX TLV                         NO        NO
 EVB TLV                          NO        NO
表1-5 display lldp tlv-config命令显示信息描述表
LLDP 缺省代理,即最近桥代理
LLDP最近客户桥代理
LLDP最近非TPMR桥代理
端口1上可发送的可选TLV类型
NAME
TLV类型
STATUS
端口是否配置发布指定类型TLV
DEFAULT
端口发布指定类型TLV的缺省情况
Basic optional TLV
端口可以发送的基本TLV类型
端口描述TLV
System Name TLV
系统名称TLV
系统描述TLV
系统能力集TLV
管理地址TLV
IEEE 802.1 extended TLV
端口可发送的IEEE 802.1组织定义的TLV类型
Port VLAN ID TLV
端口VLAN ID TLV
协议VLAN ID TLV
VLAN Name TLV
VLAN名称TLV
DCBX TLV
(暂不支持)DCBX(Data Center Bridging Exchange Protocol,数据中心桥能力交换协议) TLV
EVB TLV
(暂不支持)EVB(Edge Virtual Bridging,边缘虚拟桥接)模块TLV
Management VID TLV
管理VLAN TLV
IEEE 802.3 extended TLV
端口可发送的IEEE 802.3组织定义的TLV类型
MAC-Physic TLV
端口物理属性TLV
Power via MDI TLV
供电能力TLV
链路聚合TLV
最大帧长度TLV
LLDP-MED extend TLV
LLDP-MED TLV
Capabilities TLV
MED能力集TLV
Network Policy TLV
网络策略TLV
位置标识TLV
扩展供电能力TLV
Inventory TLV
资产信息TLV,包括以下几种:
·     Hardware Revision TLV:终端设备硬件版本
·     Firmware Revision TLV:终端设备固件版本
·     Software Revision TLV:终端设备软件版本
·     Serial Number TLV:终端设备序列号
·     Manufacturer Name TLV:终端设备的制造厂商名称
·     Model name TLV:终端设备的模块名称
·     Asset ID TLV:终端设备的资产标识符,以便目录管理和资产跟踪
1.1.6  lldp admin-status
lldp admin-status命令用来配置LLDP的工作模式。
undo lldp admin-status命令用来恢复缺省情况。
在二层以太网接口视图/三层以太网接口视图下:
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] admin-status
在二层聚合接口视图/三层聚合接口视图下:
undo lldp agent { nearest-customer | nearest-nontpmr } admin-status
LLDP最近桥代理的工作模式为TxRx,既发送也接收LLDP报文。其他类型的LLDP代理的工作模式为Disable,即不发送也不接收LLDP报文。
二层以太网接口视图
三层以太网接口视图
二层聚合接口视图
三层聚合接口视图
context-admin
agent:配置指定类型LLDP代理的工作模式。在以太网接口视图下,未指定时表示配置最近桥代理的工作模式。
disable:表示工作模式为Disable,既不发送也不接收LLDP报文。
rx:表示工作模式为Rx,只接收不发送LLDP报文。
tx:表示工作模式为Tx,只发送不接收LLDP报文。
txrx:表示工作模式为TxRx,既发送也接收LLDP报文。
# 配置接口GigabitEthernet1/0/1上最近客户桥代理LLDP的工作模式为Rx。
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer admin-status rx
1.1.7  lldp check-change-interval
lldp check-change-interval命令用来开启轮询功能并配置轮询间隔。
undo lldp check-change-interval命令用来关闭轮询功能。
在二层以太网接口视图/三层以太网接口视图:
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] check-change-interval
undo lldp agent { nearest-customer | nearest-nontpmr } check-change-interval
轮询功能处于关闭状态。
二层以太网接口视图
三层以太网接口视图
二层聚合接口视图
三层聚合接口视图
context-admin
agent:配置指定类型LLDP代理的轮询功能。在以太网接口视图下,未指定时表示配置最近桥代理的轮询功能。
interval:表示轮询间隔,取值范围为1~30,单位为秒。
# 在接口GigabitEthernet1/0/1的最近客户桥代理上开启轮询功能,并配置轮询间隔为30秒。
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer check-change-interval 30
1.1.8  lldp enable
lldp enable命令用来在接口上开启LLDP功能。
undo lldp enable命令用来在接口上关闭LLDP功能。
lldp enable
undo lldp enable
接口上的LLDP功能处于开启状态。
二层以太网接口视图
三层以太网接口视图
二层聚合接口视图
三层聚合接口视图
context-admin
只有当全局和接口上都开启了LLDP功能后,该功能才会生效。
# 在接口GigabitEthernet1/0/1上关闭LLDP功能。
[Sysname-GigabitEthernet1/0/1] undo lldp enable
·     lldp global enable
1.1.9  lldp encapsulation snap
lldp encapsulation snap命令用来配置LLDP报文的封装格式为SNAP格式。
undo lldp encapsulation命令用来恢复缺省情况。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] encapsulation
undo lldp agent { nearest-customer | nearest-nontpmr } encapsulation
LLDP报文的封装格式为Ethernet II格式。
二层以太网接口视图
三层以太网接口视图
二层聚合接口视图
三层聚合接口视图
context-admin
agent:配置指定类型LLDP代理的封装格式。在以太网接口视图下,未指定时表示配置最近桥代理的封装格式。
# 配置接口GigabitEthernet1/0/1上发送的LLDP报文的封装格式为SNAP格式。
[Sysname-GigabitEthernet1/0/1] lldp encapsulation snap
1.1.10  lldp fast-count
lldp fast-count命令用来配置快速发送LLDP报文的个数。
undo lldp fast-count命令用来恢复缺省情况。
lldp fast-count count
快速发送LLDP报文的个数为4个。
context-admin
count:表示快速发送LLDP报文的个数,取值范围为1~8。
# 配置快速发送LLDP报文的个数为5个。
[Sysname] lldp fast-count 5
1.1.11  lldp global enable
lldp global enable命令用来全局开启LLDP功能。
undo lldp global enable命令用来全局关闭LLDP功能。
lldp global enable
设备未全局开启LLDP功能。
context-admin
# 全局关闭LLDP功能。
[Sysname] undo lldp global enable
·     lldp enable
1.1.12  lldp hold-multiplier
lldp hold-multiplier命令用来配置TTL乘数。
undo lldp hold-multiplier命令用来恢复缺省情况。
lldp hold-multiplier value
TTL乘数为4。
context-admin
value:表示TTL乘数,取值范围为2~10。
LLDP报文所携Time To Live TLV中TTL的值用来设置邻居信息在本地设备上的老化时间,由于TTL=Min(65535,(TTL乘数×LLDP报文的发送间隔+1)),即取65535与(TTL乘数×LLDP报文的发送间隔+1)中的最小值,因此通过调整TTL乘数可以控制本设备信息在邻居设备上的老化时间。
# 配置TTL乘数为6。
·     lldp timer tx-interval
1.1.13  lldp ignore-pvid-inconsistency
lldp ignore-pvid-inconsistency命令用来关闭LLDP的PVID不一致检查功能。
undo lldp ignore-pvid-inconsistency命令用来开启LLDP的PVID不一致检查功能。
LLDP的PVID不一致检查功能处于开启状态。
context-admin
缺省情况下,LLDP会对接口接收报文中的PVID TLV进行检查,如果发现报文中PVID与本端不一致,LLDP会打印日志信息,提示用户。但在一些特殊情况下,可以允许链路两端的PVID配置不一致,此时可以关闭LLDP的PVID不一致性检查功能。
# 关闭LLDP的PVID不一致检查功能。
[Sysname] lldp ignore-pvid-inconsistency
1.1.14  lldp management-address
lldp management-address命令用来配置接口收到携带Management Address TLV的LLDP报文后生成ARP表项或ND表项。
undo lldp management-address命令用来恢复缺省情况。
lldp management-address { arp-learning | nd-learning } [ vlan vlan-id ]
undo lldp management-address { arp-learning | nd-learning }
接口收到携带Management Address TLV的LLDP报文后不生成ARP表项和ND表项。
三层以太网接口视图
context-admin
arp-learning:表示接口收到携带IPv4格式Management Address TLV的LLDP报文后,会生成该报文携带的管理地址与报文源MAC地址组成的ARP表项。
nd-learning:表示接口收到携带IPv6格式Management Address TLV的LLDP报文后,会生成该报文携带的管理地址与报文源MAC地址组成的ND表项。
vlan vlan-id:指定的VLAN ID为三层以太网子接口编号,取值范围为1~4094。指定该参数后,生成的ARP表项或ND表项中的接口为到该VLAN ID对应的三层以太网子接口;如果该VLAN ID对应的三层以太网子接口不存在,则生成的表项中的接口为主接口。不指定该参数时表示生成的表项中的接口为主接口。
ARP表项和ND表项的生成互不影响,可同时配置。
# 配置接口GigabitEthernet1/0/1收到携带IPv4格式Management Address TLV的LLDP报文后,生成ARP表项。
[Sysname-GigabitEthernet1/0/1] lldp management-address arp-learning
·     lldp source-mac vlan
1.1.15  lldp management-address-format string
lldp management-address-format string命令用来配置管理地址在TLV中的封装格式为字符串格式。
undo lldp management-address-format命令用来恢复缺省情况。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] management-address-format
undo lldp agent { nearest-customer | nearest-nontpmr } management-address-format
管理地址在TLV中的封装格式为数字格式。
二层以太网接口视图
三层以太网接口视图
二层聚合接口视图
三层聚合接口视图
context-admin
agent:配置指定LLDP代理类型管理地址在TLV中的封装格式。在以太网接口视图下,未指定时表示配置最近桥代理的管理地址在TLV中的封装格式。
如果邻居将管理地址以字符串格式封装在TLV中,用户可在本地设备上也将封装格式改为字符串,以保证与邻居设备的正常通信。
# 在接口GigabitEthernet1/0/1的最近客户桥代理上配置管理地址在TLV中的封装格式为字符串格式。
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer management-address-format string
1.1.16  lldp max-credit
lldp max-credit命令用来配置限制发送报文速率的令牌桶大小。
undo lldp max-credit命令用来恢复缺省情况。
lldp max-credit credit-value
限制发送报文速率的令牌桶大小为5。
context-admin
credit-value:表示LLDP发包限速的令牌桶大小,取值范围1~100。
# 配置LLDP发包限速的令牌桶大小为10。
[Sysname] lldp max-credit 10
1.1.17  lldp mode
lldp mode命令用来配置LLDP桥模式。
undo lldp mode命令用来恢复缺省情况。
lldp mode service-bridge
undo lldp mode
LLDP桥模式为客户桥模式。
context-admin
service-bridge:表示服务桥模式。
LLDP桥模式命令用于控制设备支持不同的LLDP代理。
·     工作于服务桥模式时,设备可支持最近桥代理和最近非TPMR桥代理,即对上述类型的代理MAC的LLDP报文进行处理,其他目的MAC的LLDP报文进行VLAN内透传。
·     工作于客户桥模式时,设备可支持最近桥代理、最近非TPMR桥代理及最近客户桥代理,即对上述类型的代理MAC的LLDP报文进行处理,其他目的MAC的LLDP报文进行VLAN内透传。
桥模式配置只在LLDP全局开启后才能生效,LLDP全局关闭时,只能作为客户桥对三种类型代理MAC的LLDP报文进行拦截。
# 配置LLDP桥模式为服务桥模式。
[Sysname] lldp mode service-bridge
1.1.18  lldp notification med-topology-change enable
lldp notification med-topology-change enable命令用来开启LLDP-MED Trap功能。
undo lldp notification med-topology-change enable命令用来关闭LLDP-MED Trap功能。
LLDP-MED Trap功能处于关闭状态。
二层以太网接口视图
三层以太网接口视图
context-admin
# 在接口GigabitEthernet1/0/1上开启LLDP-MED Trap功能。
[Sysname-GigabitEthernet1/0/1] lldp notification med-topology-change enable
1.1.19  lldp notification remote-change enable
lldp notification remote-change enable命令用来开启LLDP Trap功能。
undo lldp notification remote-change enable命令用来关闭LLDP Trap功能。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] notification remote-change enable
undo lldp agent { nearest-customer | nearest-nontpmr } notification remote-change enable
LLDP Trap功能处于关闭状态。
二层以太网接口视图
三层以太网接口视图
二层聚合接口视图
三层聚合接口视图
context-admin
agent:开启指定类型LLDP代理的LLDP Trap功能。在以太网接口视图下,未指定时表示开启最近桥代理类型LLDP代理的LLDP Trap功能。
# 在接口GigabitEthernet1/0/1最近客户桥代理上开启LLDP Trap功能。
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer notification remote-change enable
1.1.20  lldp source-mac vlan
lldp source-mac vlan命令用来配置LLDP报文源MAC地址为指定三层以太网子接口的MAC地址。
undo lldp source-mac vlan命令用来恢复缺省情况。
lldp source-mac vlan vlan-id
LLDP报文源MAC地址为主接口的MAC地址。
三层以太网接口视图
context-admin
vlan-id:指定的VLAN ID为三层以太网子接口编号,取值范围为1~4094。指定该参数后,LLDP报文源MAC地址为该VLAN ID对应的三层以太网子接口的MAC地址;如果该VLAN ID对应的三层以太网子接口不存在,则LLDP报文源MAC地址为主接口的MAC地址。
# 配置LLDP报文源MAC地址为指定三层以太网子接口的MAC地址。
[Sysname-GigabitEthernet1/0/1] lldp source-mac vlan 4094
·     lldp management-address arp-learning
1.1.21  lldp timer fast-interval
lldp timer fast-interval命令用来配置LLDP快速发送报文的时间间隔。
undo lldp timer fast-interval命令用来恢复缺省情况。
LLDP快速发送报文的时间间隔为1秒。
context-admin
interval:表示LLDP快速发送报文的时间间隔,取值范围为1~3600,单位为秒。
# 配置LLDP快速发送报文的时间间隔为2秒。
[Sysname] lldp timer fast-interval 2
1.1.22  lldp timer notification-interval
lldp timer notification-interval命令用来配置LLDP Trap和LLDP-MED Trap信息的发送间隔。
undo lldp timer notification-interval命令用来恢复缺省情况。
LLDP Trap和LLDP-MED Trap信息的发送间隔均为30秒。
context-admin
interval:表示LLDP Trap和LLDP-MED Trap信息的发送间隔,取值范围为5~3600,单位为秒。
# 配置LLDP Trap和LLDP-MED Trap信息的发送间隔为8秒。
1.1.23  lldp timer reinit-delay
lldp timer reinit-delay命令用来配置接口初始化的延迟时间。
undo lldp timer reinit-delay命令用来恢复缺省情况。
lldp timer reinit-delay delay
接口初始化的延迟时间为2秒。
context-admin
delay:接口初始化的延迟时间,取值范围为1~10,单位为秒。
# 配置接口初始化的延迟时间为4秒。
1.1.24  lldp timer tx-interval
lldp timer tx-interval命令用来配置LLDP报文的发送间隔。
undo lldp timer tx-interval命令用来恢复缺省情况。
LLDP报文的发送间隔为30秒。
context-admin
interval:表示LLDP报文的发送间隔,取值范围为5~32768,单位为秒。
# 配置LLDP报文的发送间隔为20秒。
1.1.25  lldp tlv-enable
lldp tlv-enable命令用来配置接口上允许发布的TLV类型。
undo lldp tlv-enable命令用来配置接口上禁止发布的TLV类型。
在二层以太网接口视图下:
·     配置最近桥代理LLDP接口上允许发布的TLV类型
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation | protocol-vlan-id [ vlan-id ] | vlan-name [ vlan-id ] | management-vid [ mvlan-id ] } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | network-policy [ vlan-id ] | power-over-ethernet | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } } }
undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation | protocol-vlan-id | vlan-name | management-vid } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | network-policy [ vlan-id ] | power-over-ethernet | location-id } }
·     配置最近非TPMR代理LLDP接口上允许发布的TLV类型
lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation } }
undo lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation } }
undo lldp tlv-enable dot1-tlv { protocol-vlan-id | vlan-name | management-vid }
·     配置最近客户桥代理LLDP接口上允许发布的TLV类型
lldp agent nearest-customer tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation } }
undo lldp agent nearest-customer tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation } }
在三层以太网接口视图:
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address | interface loopback interface-number ] } | dot1-tlv { all | link-aggregation } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | power-over-ethernet | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } } }
lldp agent { nearest-nontpmr | nearest-customer } tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | link-aggregation } }
undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address | interface loopback interface-number ] } | dot1-tlv { all | link-aggregation } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | power-over-ethernet | location-id } }
undo lldp agent { nearest-nontpmr | nearest-customer } tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | link-aggregation } }
在二层聚合接口视图下:
lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | management-address-tlv [ ipv6 ] [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
undo lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | management-address-tlv [ ipv6 ] [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
undo lldp agent nearest-customer tlv-enable { basic-tlv { all | management-address-tlv [ ipv6 ] [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
在三层聚合接口视图下:
lldp agent { nearest-customer | nearest-nontpmr } tlv-enable basic-tlv { all | management-address-tlv [ ipv6 ] [ ip-address ] | port-description | system-capability | system-description | system-name }
undo lldp agent { nearest-customer | nearest-nontpmr } tlv-enable basic-tlv { all | management-address-tlv [ ipv6 ] [ ip-address ] | port-description | system-capability | system-description | system-name }
二层以太网接口上:
·     最近桥代理允许发布除Location-id TLV、Port And Protocol VLAN ID TLV、VLAN Name TLV和Management VLAN ID TLV之外所有类型的TLV;
·     最近客户桥代理允许发布基本TLV和IEEE 802.1组织定义TLV。
三层以太网接口上:
·     最近桥代理允许发布除Network Policy TLV之外所有类型的TLV,其中IEEE 802.1组织定义的TLV只支持Link Aggregation TLV;
·     最近非TPMR桥代理不发布任何TLV;
·     最近客户桥代理允许发布基本TLV和IEEE 802.1组织定义TLV,其中IEEE 802.1组织定义的TLV只支持Link Aggregation TLV。
二层聚合接口上:
·     最近客户桥代理允许发布基本TLV和IEEE 802.1组织定义TLV,其中IEEE 802.1组织定义的TLV只支持Port And Protocol VLAN ID TLV、VLAN Name TLV及Management VLAN ID TLV。
三层聚合接口上:
·     最近客户桥代理只允许发布基本TLV。
二层以太网接口视图
三层以太网接口视图
二层聚合接口视图
三层聚合接口视图
context-admin
agent:配置指定类型LLDP代理允许发布的TLV类型。在以太网接口视图下,未指定时表示配置最近桥代理允许发布的TLV类型。
all:发布指定类型的所有可选TLV:
¡     如果为basic-tlv参数指定all,则允许发布所有基本TLV。
¡     如果为dot1-tlv参数指定all,则允许发布所有802.1组织定义TLV。
¡     如果为dot3-tlv参数指定all,则允许发布所有802.3组织定义TLV。
¡     如果为med-tlv参数指定all,则允许发布除location-id以外所有的可选LLDP-MED TLV。
basic-tlv:表示基本类型TLV。
management-address-tlv [ ipv6 ] [ ip-address | interface loopback interface-number ]:表示Management Address TLV。其中,ipv6表示LLDP报文中所要发布的管理地址为IPv6格式的地址。ip-address表示在LLDP报文中发布的管理地址为指定的IP地址,interface loopback interface-number表示在LLDP报文中发布的管理地址为指定的LoopBack接口的IP地址。其缺省值如下:
·     执行lldp tlv-enable命令时:
¡     在二层以太网接口视图/二层聚合接口视图下,如果ip-address参数未指定,则发布的管理地址为当前接口允许通过的、对应VLAN接口上配置有IPv4/IPv6地址且处于up状态的最小VLAN的IPv4/IPv6地址。
如果指定了ipv6参数,则发布的管理地址为IPv6地址。如果未指定ipv6参数,则发布的管理地址为对应VLAN接口的IP地址。
如果当前接口允许通过的所有VLAN所对应的VLAN接口上都未配置IPv4/IPv6地址或均处于down状态,则发布当前接口的MAC地址。
¡     在三层以太网接口视图下,如果ip-address参数未指定,或指定的LoopBack接口不存在或LoopBack接口没有配置IPv4/IPv6地址,发布的管理地址为当前发送LLDP报文接口的IPv4/IPv6地址。
如果指定了ipv6参数,则发布的管理地址为IPv6地址。如果未指定ipv6参数,则发布的管理地址为对应接口的IP地址。
如果当前接口未配置IPv4/IPv6地址,则发布当前接口的MAC地址。
¡     在三层聚合接口视图下,如果ip-address参数未指定,发布的管理地址为当前发送LLDP报文接口的IPv4/IPv6地址。
·     执行undo lldp tlv-enable命令时:
¡     在二层以太网接口视图/二层聚合接口视图/三层以太网接口视图/三层聚合接口视图下:
如果不带ipv6ip-addressinterface loopback interface-number参数表示不发布该TLV;
如果带ipv6ip-addressinterface loopback interface-number参数表示按缺省值发布该TLV。
port-description:表示Port Description TLV。
system-capability:表示System Capabilities TLV。
system-description:表示System Description TLV。
system-name:表示System Name TLV。
dot1-tlv:表示IEEE 802.1组织定义的TLV。
port-vlan-id:表示Port VLAN ID TLV。
protocol-vlan-id [ vlan-id ]:表示Port And Protocol VLAN ID TLV,vlan-id为所要发布VLAN的VLAN ID,取值范围为1~4094,缺省值为该端口所属VLAN中最小的VLAN ID。
vlan-name [ vlan-id ]:表示VLAN Name TLV,vlan-id为所要发布VLAN的VLAN ID,取值范围为1~4094,缺省值为该端口所属VLAN中最小的VLAN ID。如果未指定vlan-id,且端口未加入任何VLAN,所要发布的VLAN为该端口PVID。
management-vid [ mvlan-id ]:表示Management VLAN ID TLV。mvlan-id指定要发布管理VLAN的VLAN ID,取值范围为1~4094。如果未指定该参数,则表示发布0,表示当前LLDP agent未配置管理VLAN。
link-aggregation:表示Link Aggregation TLV。
dot3-tlv:表示IEEE 802.3组织定义的TLV。
mac-physic:表示MAC/PHY Configuration/Status TLV。
max-frame-size:表示Maximum Frame Size TLV。
power:表示Power Via MDI TLV和Power Stateful Control TLV。
med-tlv:表示LLDP-MED TLV。
capability:表示LLDP-MED Capabilities TLV。
inventory:表示Hardware Revision TLV、Firmware Revision TLV、Software Revision TLV、Serial Number TLV、Manufacturer Name TLV、Model Name TLV和Asset ID TLV。
location-id:表示Location Identification TLV。
civic-address:表示Location Identification TLV封装网络设备的普通地址信息。
device-type:表示设备类型,取值范围为0~2。0表示设备类型为DHCP server,1表示设备类型为Network device,2表示设备类型为LLDP-MED Endpoint。
country-code:表示国家编码,取值范围请参考ISO 3166。
{ ca-type ca-value }&<1-10>:地址信息。ca-type表示地址信息类型,取值范围为0~255;ca-value表示地址信息,为1~250个字符的字符串。&<1-10>表示前面的参数最多可以输入10次。
elin-address:Location Identification TLV封装紧急电话号码。
tel-number:表示紧急电话号码,为10~25个字符的字符串,只能包含数字。
network-policy [ vlan-id ]:表示Network Policy TLV,vlan-id为要发布的Voice VLAN ID,取值范围为1~4094。
power-over-ethernet:表示Extended Power-via-MDI TLV。
聚合接口不支持最近桥代理。
在使用本命令时若不指定all参数,每次只能配置某类型下的一种可选TLV,此时可通过多次使用该命令来配置各类型下的多种可选TLV。
如果禁止发布802.3的组织定义的MAC/PHY Configuration/Status TLV,则LLDP-MED TLV将不会被发布,不论其是否被允许发布;如果禁止发布LLDP-MED Capabilities TLV,则其它LLDP-MED TLV将不会被发布,不论其是否被允许发布。
IEEE 802.1组织定义的TLV的Port And Protocol VLAN ID TLV、VLAN Name TLV及Management VLAN ID TLV只能基于最近桥代理配置,但是其配置会被最近非TPMR桥代理和最近客户桥代理继承。
# 配置接口GigabitEthernet1/0/1上最近客户桥代理允许发布IEEE 802.1组织定义的Link Aggregation可选TLV。
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer tlv-enable dot1-tlv link-aggregation
