11-命令总索引
整本手册(chm)
本章节下载  (7.09 MB)
整本手册(chm)
Index
A B C D E F G H I J K L M N O P Q R S T U V W X Y
A
aaa nas-id profile
aaa session-limit
access-limit
accounting
accounting command
accounting default
accounting lan-access
accounting login
accounting portal
accounting-on enable
acl
acl copy
acl logging interval
acl name
action cli
action reboot
action switchover
action syslog
activation-key
active region-configuration
address range
address range
address-family ipv4
address-family ipv6
advantage-factor
ah authentication-algorithm
append
apply next-hop
apply next-hop
archive configuration
archive configuration interval
archive configuration location
archive configuration max
arp active-ack enable
arp authorized enable
arp check enable
arp check log enable
arp detection enable
arp detection rule
arp detection trust
arp detection validate
arp filter binding
arp filter source
arp fixup
arp ip-conflict log prompt
arp max-learning-num
arp max-learning-number
arp multiport
arp rate-limit
arp rate-limit log enable
arp rate-limit log interval
arp resolving-route enable
arp resolving-route probe-count
arp resolving-route probe-interval
arp scan
arp send-gratuitous-arp
arp snooping enable
arp source-mac
arp source-mac aging-time
arp source-mac exclude-mac
arp source-mac threshold
arp source-suppression enable
arp source-suppression limit
arp static
arp timer aging
arp valid-check enable
ascii
attack-defense tcp fragment enable
attribute
attribute 15 check-mode
authentication default
authentication lan-access
authentication login
authentication portal
authentication super
authentication-method
authentication-mode
authentication-server
authorization command
authorization default
authorization lan-access
authorization login
authorization portal
authorization-attribute(ISP domain view)
authorization-attribute(Local user view/user group view)
auto-execute command
B
backup startup-configuration
bandwidth
bandwidth
bandwidth
bandwidth
bfd authentication-mode
bfd demand enable
bfd detect-multiplier
bfd echo enable
bfd echo-source-ip
bfd echo-source-ipv6
bfd min-echo-receive-interval
bfd min-receive-interval
bfd min-transmit-interval
bfd multi-hop authentication-mode
bfd multi-hop destination-port
bfd multi-hop detect-multiplier
bfd multi-hop min-receive-interval
bfd multi-hop min-transmit-interval
bfd session init-mode
bfd template
bims-server
binary
bind-attribute
bootfile-name
boot-loader file
boot-loader update
bootrom update
bpdu-drop any
broadcast-suppression
buffer apply
buffer queue guaranteed
buffer total-shared
burst-mode enable
bye
bye
C
ca identifier
car
car name
cd
cd
cd
cdp voice-vlan
cdup
cdup
certificate domain
certificate request entity
certificate request from
certificate request mode
certificate request polling
certificate request url
cfd ais enable
cfd ais level
cfd ais period
cfd ais-track link-status global
cfd ais-track link-status level
cfd ais-track link-status period
cfd ais-track link-status vlan
cfd cc enable
cfd cc interval
cfd dm one-way
cfd dm two-way
cfd enable
cfd linktrace
cfd linktrace auto-detection
cfd loopback
cfd md
cfd mep
cfd meplist
cfd mip-rule
cfd service-instance
cfd slm
cfd tst
check region-configuration
ciphersuite
class
classifier behavior
client-verify enable
clock datetime
clock protocol
clock summer-time
clock timezone
close
codec-type
combo enable(仅S5130-28F-SI支持)
command
command accounting
command authorization
command-alias enable
command-alias mapping
commit
common-name
configuration encrypt
configuration replace file
control-plane
control-vlan
copy
copy
copyright-info enable
country
crl check
crl url
cwmp
cwmp acs default password
cwmp acs default url
cwmp acs default username
cwmp acs password
cwmp acs url
cwmp acs username
cwmp cpe connect interface
cwmp cpe connect retry
cwmp cpe inform interval
cwmp cpe inform interval enable
cwmp cpe inform time
cwmp cpe password
cwmp cpe provision-code
cwmp cpe stun enable
cwmp cpe username
cwmp cpe wait timeout
cwmp enable
D
databits
data-fill
data-flow-format (HWTACACS scheme view)
data-flow-format (RADIUS scheme view)
data-size
debug
debugging
default
default
default
default
delete
delete
delete
delete
delete ipv6 static-routes all
delete static-routes all
description
description
description
description
description
description
description
description (any NQA test type view)
destination ip
destination ipv6
destination port
dh
dhcp class
dhcp client dad enable
dhcp client dscp
dhcp client identifier
dhcp dscp
dhcp enable
dhcp relay check mac-address
dhcp relay check mac-address aging-time
dhcp relay client-information record
dhcp relay client-information refresh
dhcp relay client-information refresh enable
dhcp relay information circuit-id
dhcp relay information enable
dhcp relay information remote-id
dhcp relay information strategy
dhcp relay release ip
dhcp relay server-address
dhcp select
dhcp server always-broadcast
dhcp server apply ip-pool
dhcp server bootp ignore
dhcp server bootp reply-rfc-1048
dhcp server forbidden-ip
dhcp server ip-pool
dhcp server ping packets
dhcp server ping timeout
dhcp server relay information enable
dhcp snooping binding database filename
dhcp snooping binding database update interval
dhcp snooping binding database update now
dhcp snooping binding record
dhcp snooping check mac-address
dhcp snooping check request-message
dhcp snooping deny
dhcp snooping enable
dhcp snooping information circuit-id
dhcp snooping information enable
dhcp snooping information remote-id
dhcp snooping information strategy
dhcp snooping max-learning-num
dhcp snooping rate-limit
dhcp snooping trust
diagnostic-logfile save
dir
dir
dir
dir
disconnect
dispaly fips status
display | { begin | exclude | include }
display | by-linenum
display >
display >>
display acl
display archive configuration
display arp
display arp detection
display arp detection statistics
display arp ip-address
display arp snooping
display arp source-mac
display arp source-suppression
display arp timer aging
display bfd session
display boot-loader
display bootp client
display buffer
display cfd ais
display cfd ais-track link-status
display cfd dm one-way history
display cfd linktrace-reply
display cfd linktrace-reply auto-detection
display cfd md
display cfd mep
display cfd meplist
display cfd mp
display cfd remote-mep
display cfd service-instance
display cfd status
display cfd tst
display clock
display command-alias
display copyright
display copyright
display counters
display counters rate
display cpu-usage
display cpu-usage configuration
display cpu-usage history
display crypto-engine
display crypto-engine statistics
display current-configuration
display current-configuration diff
display cwmp configuration
display cwmp status
display debugging
display default-configuration
display device
display device manuinfo
display device manuinfo power(仅S5130-28F-SI支持)
display dhcp client
display dhcp relay check mac-address
display dhcp relay client-information
display dhcp relay information
display dhcp relay server-address
display dhcp relay statistics
display dhcp server conflict
display dhcp server expired
display dhcp server free-ip
display dhcp server ip-in-use
display dhcp server pool
display dhcp server statistics
display dhcp snooping binding
display dhcp snooping binding database
display dhcp snooping information
display dhcp snooping packet statistics
display dhcp snooping trust
display diagnostic-information
display diagnostic-logfile summary
display diff
display dldp
display dldp statistics
display dns domain
display dns host
display dns server
display domain
display dot1x
display dot1x connection
display environment
display ethernet statistics
display exception context
display exception filepath
display fan
display fib
display ftp client source
display ftp-server
display ftp-user
display history-command
display history-command all
display hotkey
display hwtacacs scheme
display icmp statistics
display igmp-snooping
display igmp-snooping group
display igmp-snooping router-port
display igmp-snooping static-group
display igmp-snooping static-router-port
display igmp-snooping statistics
display ike proposal
display ike sa
display info-center
display install package
display interface
display interface
display interface inloopback
display interface loopback
display interface null
display interface range
display interface vlan-interface
display ip http
display ip https
display ip interface
display ip interface brief
display ip policy-based-route
display ip policy-based-route interface
display ip policy-based-route local
display ip policy-based-route setup
display ip routing-table
display ip routing-table acl
display ip routing-table ip-address
display ip routing-table protocol
display ip routing-table statistics
display ip source binding
display ip statistics
display ipsec { ipv6-policy | policy }
display ipsec { ipv6-policy-template | policy-template }
display ipsec sa
display ipsec statistics
display ipsec transform-set
display ipsec tunnel
display ip-subnet-vlan interface
display ip-subnet-vlan vlan
display ipv6 dhcp client
display ipv6 dhcp client statistics
display ipv6 dhcp duid
display ipv6 dhcp pool
display ipv6 dhcp prefix-pool
display ipv6 dhcp relay server-address
display ipv6 dhcp relay statistics
display ipv6 dhcp server
display ipv6 dhcp server conflict
display ipv6 dhcp server expired
display ipv6 dhcp server ip-in-use
display ipv6 dhcp server pd-in-use
display ipv6 dhcp server statistics
display ipv6 dhcp snooping binding
display ipv6 dhcp snooping binding database
display ipv6 dhcp snooping packet statistics
display ipv6 dhcp snooping trust
display ipv6 dns server
display ipv6 fib
display ipv6 icmp statistics
display ipv6 interface
display ipv6 interface prefix
display ipv6 l2-multicast ip
display ipv6 l2-multicast ip forwarding
display ipv6 l2-multicast mac
display ipv6 l2-multicast mac forwarding
display ipv6 multicast-vlan
display ipv6 multicast-vlan forwarding-table
display ipv6 multicast-vlan group
display ipv6 nd detection statistics
display ipv6 nd snooping
display ipv6 nd snooping count
display ipv6 neighbors
display ipv6 neighbors count
display ipv6 pathmtu
display ipv6 pim-snooping neighbor
display ipv6 pim-snooping router-port
display ipv6 pim-snooping routing-table
display ipv6 pim-snooping statistics
display ipv6 policy-based-route
display ipv6 policy-based-route interface
display ipv6 policy-based-route local
display ipv6 policy-based-route setup
display ipv6 prefix
display ipv6 rawip
display ipv6 rawip verbose
display ipv6 rib attribute
display ipv6 rib nib
display ipv6 route-direct nib
display ipv6 route-static nib
display ipv6 route-static routing-table
display ipv6 routing-table
display ipv6 routing-table acl
display ipv6 routing-table ipv6-address
display ipv6 routing-table protocol
display ipv6 routing-table statistics
display ipv6 source binding
display ipv6 statistics
display ipv6 tcp
display ipv6 tcp verbose
display ipv6 udp
display ipv6 udp verbose
display irf
display irf configuration
display irf link
display irf topology
display irf-port load-sharing mode
display kernel deadloop
display kernel deadloop configuration
display kernel exception
display kernel reboot
display kernel starvation
display kernel starvation configuration
display l2-multicast ip
display l2-multicast ip forwarding
display l2-multicast mac
display l2-multicast mac forwarding
display lacp system-id
display ldap scheme
display line
display link-aggregation load-sharing mode
display link-aggregation member-port
display link-aggregation summary
display link-aggregation verbose
display lldp local-information
display lldp neighbor-information
display lldp statistics
display lldp status
display lldp tlv-config
display local-proxy-arp
display local-user
display logbuffer
display logbuffer summary
display logfile summary
display loopback-detection
display mac-address
display mac-address aging-time
display mac-address mac-learning
display mac-address mac-move
display mac-address multicast
display mac-address statistics
display mac-authentication
display mac-authentication connection
display mac-forced-forwarding interface
display mac-forced-forwarding vlan
display mac-vlan
display mac-vlan interface
display mad
display memory
display memory-threshold
display mirroring-group
display mld-snooping
display mld-snooping group
display mld-snooping router-port
display mld-snooping static-group
display mld-snooping static-router-port
display mld-snooping statistics
display monitor-link group
display multicast-vlan
display multicast-vlan forwarding-table
display multicast-vlan group
display mvrp running-status
display mvrp state
display mvrp statistics
display nqa history
display nqa reaction counters
display nqa result
display nqa server
display nqa statistics
display ntp-service ipv6 sessions
display ntp-service sessions
display ntp-service status
display ntp-service trace
display oam
display oam configuration
display oam critical-event
display oam link-event
display packet-drop
display packet-filter
display packet-filter statistics
display packet-filter statistics sum
display packet-filter verbose
display password-control
display password-control blacklist
display pim-snooping neighbor
display pim-snooping router-port
display pim-snooping routing-table
display pim-snooping statistics
display pki certificate access-control-policy
display pki certificate attribute-group
display pki certificate domain
display pki certificate request-status
display pki crl
display port
display portal interface
display portal packet statistics
display portal rule
display portal server
display portal user
display portal web-server
display port-isolate group
display port-security
display port-security mac-address block
display port-security mac-address security
display power
display private-vlan
display process
display process cpu
display process log
display process memory
display process memory heap
display process memory heap address
display process memory heap size
display protocol-vlan interface
display protocol-vlan vlan
display proxy-arp
display public-key local public
display public-key peer
display qinq
display qos car name
display qos gts interface
display qos lr interface
display qos map-table
display qos policy
display qos policy control-plane
display qos policy control-plane pre-defined
display qos policy global
display qos policy interface
display qos queue sp
display qos queue wfq interface
display qos queue wrr interface
display qos queue-statistics interface outbound
display qos trust interface
display qos vlan-policy
display qos-acl resource
display radius scheme
display radius statistics
display rawip
display rawip verbose
display rib attribute
display rib nib
display rmon alarm
display rmon event
display rmon eventlog
display rmon history
display rmon prialarm
display rmon statistics
display role
display role feature
display role feature-group
display route-direct nib
display route-static nib
display route-static routing-table
display rrpp brief
display rrpp ring-group
display rrpp statistics
display rrpp verbose
display rtm environment
display rtm policy
display saved-configuration
display scheduler job
display scheduler logfile
display scheduler reboot
display scheduler schedule
display security-logfile summary
display sflow
display sftp client source
display smart-link flush
display smart-link group
display snmp-agent community
display snmp-agent context
display snmp-agent group
display snmp-agent local-engineid
display snmp-agent mib-node
display snmp-agent mib-view
display snmp-agent remote
display snmp-agent statistics
display snmp-agent sys-info
display snmp-agent trap queue
display snmp-agent trap-list
display snmp-agent usm-user
display sntp ipv6 sessions
display sntp sessions
display ssh client source
display ssh server
display ssh user-information
display ssl client-policy
display ssl server-policy
display startup
display storm-constrain
display stp
display stp abnormal-port
display stp bpdu-statistics
display stp down-port
display stp history
display stp region-configuration
display stp root
display stp tc
display supervlan
display tcp
display tcp statistics
display tcp verbose
display telnet client
display this
display time-range
display track
display traffic behavior
display traffic classifier
display transceiver alarm
display transceiver diagnosis
display transceiver interface
display transceiver manuinfo
display udp
display udp statistics
display udp verbose
display udp-helper interface
display user-group
display user-interface
display user-profile
display users
display version
display version
display version-update-record
display vlan
display vlan brief
display vlan mapping
display vlan-group
display voice-vlan mac-address
display voice-vlan state
display web menu
display web users
dldp authentication-mode
dldp authentication-password
dldp delaydown-timer
dldp enable
dldp global enable
dldp interval
dldp unidirectional-shutdown
dns domain
dns dscp
dns proxy enable
dns server
dns source-interface
dns spoofing
dns trust-interface
dns-list
dns-server
domain
domain default enable
domain ring
domain-name
domain-name
dot1p-priority (IGMP-Snooping view)
dot1p-priority (MLD-Snooping view)
dot1x
dot1x authentication-method
dot1x auth-fail vlan
dot1x critical vlan
dot1x ead-assistant enable
dot1x ead-assistant free-ip
dot1x ead-assistant url
dot1x guest-vlan
dot1x handshake
dot1x handshake secure
dot1x mandatory-domain
dot1x max-user
dot1x multicast-trigger
dot1x port-control
dot1x port-method
dot1x quiet-period
dot1x re-authenticate
dot1x re-authenticate server-unreachable keep-online
dot1x retry
dot1x timer
dot1x unicast-trigger
downlink up-delay
dpd
duplex
E
eee enable
enable (IGMP-Snooping view)
enable (MLD-Snooping view)
enable log updown
enable snmp trap updown
encapsulation-mode
encryption-algorithm
entry-limit (IGMP-Snooping view)
entry-limit (MLD-Snooping view)
escape-key
esp authentication-algorithm
esp encryption-algorithm
event cli
event hotplug
event interface
event process
event snmp oid
event snmp-notification
event syslog
exception filepath
exchange-mode
exit
expect data
expect ip
expect ipv6
expect status
expired
F
fast-detection enable
fast-edge-timer
fast-leave (IGMP-Snooping view)
fast-leave (MLD-Snooping view)
fast-timer
feature
file prompt
filename
filter
fips mode enable
fips self-test
fixdisk
flow-control
flow-control
flow-control receive enable
flow-interval
flush enable
forbidden-ip
format
format
fqdn
free ftp user
free ftp user-ip
free ftp user-ip ipv6
free line
free user-interface
free web users
frequency
ftp
ftp client ipv6 source
ftp client source
ftp ipv6
ftp server acl
ftp server dscp
ftp server enable
ftp server ipv6 dscp
ftp timeout
G
gateway-list
get
get
gratuitous-arp-learning enable
gratuitous-arp-sending enable
group
group-policy (IGMP-Snooping view)
group-policy (MLD-Snooping view)
gunzip
gzip
H
header
help
help
history-command max-size
history-record enable
history-record keep-time
history-record number
host-aging-time (IGMP-Snooping view)
host-aging-time (MLD-Snooping view)
hotkey
hwtacacs nas-ip
hwtacacs scheme
I
idle-timeout
if-match
if-match
if-match acl
if-match acl
igmp-snooping
igmp-snooping dot1p-priority
igmp-snooping drop-unknown
igmp-snooping enable
igmp-snooping fast-leave
igmp-snooping general-query source-ip
igmp-snooping group-limit
igmp-snooping group-policy
igmp-snooping host-aging-time
igmp-snooping host-join
igmp-snooping last-member-query-interval
igmp-snooping leave source-ip
igmp-snooping max-response-time
igmp-snooping overflow-replace
igmp-snooping querier
igmp-snooping query-interval
igmp-snooping report source-ip
igmp-snooping router-aging-time
igmp-snooping router-port-deny
igmp-snooping source-deny
igmp-snooping special-query source-ip
igmp-snooping version
ike dpd
ike identity
ike invalid-spi-recovery enable
ike keepalive interval
ike keepalive timeout
ike keychain
ike limit
ike nat-keepalive
ike profile
ike proposal
ike signature-identity from-certificate
ike-profile
import
info-center diagnostic-logfile directory
info-center diagnostic-logfile enable
info-center diagnostic-logfile frequency
info-center diagnostic-logfile quota
info-center enable
info-center format
info-center logbuffer
info-center logbuffer size
info-center logfile directory
info-center logfile enable
info-center logfile frequency
info-center logfile overwrite-protection
info-center logfile size-quota
info-center logging suppress duplicates
info-center loghost
info-center loghost source
info-center security-logfile alarm-threshold
info-center security-logfile directory
info-center security-logfile enable
info-center security-logfile frequency
info-center security-logfile size-quota
info-center source
info-center synchronous
info-center timestamp
info-center timestamp loghost
info-center trace-logfile quota
install load
instance
interface
interface bridge-aggregation
interface loopback
interface null
interface policy deny
interface range
interface range name
ip
ip
ip
ip address
ip address bootp-alloc
ip address dhcp-alloc
ip forward-broadcast
ip host
ip http acl
ip http enable
ip http port
ip https acl
ip https certificate access-control-policy
ip https enable
ip https port
ip https ssl-server-policy
ip icmp error-interval
ip icmp fragment discarding
ip icmp source
ip irdp
ip irdp address
ip irdp interval
ip irdp lifetime
ip irdp multicast
ip irdp preference
ip local policy-based-route
ip mtu
ip redirects enable
ip route-static
ip route-static default-preference
ip source binding(interface view)
ip source binding(system view)
ip ttl-expires enable
ip unreachables enable
ip verify source
ipsec { ipv6-policy | policy } isakmp template
ipsec { ipv6-policy | policy } local-address
ipsec { ipv6-policy-template | policy-template } policy-template
ipsec anti-replay check
ipsec anti-replay window
ipsec apply
ipsec decrypt-check enable
ipsec df-bit
ipsec global-df-bit
ipsec logging packet enable
ipsec redundancy enable
ipsec sa global-duration
ipsec sa idle-time
ipsec transform-set
ip-subnet-vlan
ipv6
ipv6
ipv6 address
ipv6 address anycast
ipv6 address auto
ipv6 address auto link-local
ipv6 address dhcp-alloc
ipv6 address eui-64
ipv6 address link-local
ipv6 dhcp client dscp
ipv6 dhcp client pd
ipv6 dhcp client stateless enable
ipv6 dhcp dscp
ipv6 dhcp pool
ipv6 dhcp select
ipv6 dhcp server
ipv6 dhcp server apply pool
ipv6 dhcp server forbidden-address
ipv6 dhcp server forbidden-prefix
ipv6 dhcp snooping binding database filename
ipv6 dhcp snooping binding database update interval
ipv6 dhcp snooping binding database update now
ipv6 dhcp snooping binding record
ipv6 dhcp snooping check request-message
ipv6 dhcp snooping deny
ipv6 dhcp snooping enable
ipv6 dhcp snooping max-learning-num
ipv6 dhcp snooping option interface-id enable
ipv6 dhcp snooping option interface-id string
ipv6 dhcp snooping option remote-id enable
ipv6 dhcp snooping option remote-id string
ipv6 dhcp snooping rate-limit
ipv6 dns dscp
ipv6 dns server
ipv6 dns spoofing
ipv6 hop-limit
ipv6 hoplimit-expires enable
ipv6 host
ipv6 icmpv6 error-interval
ipv6 icmpv6 source
ipv6 local policy-based-route
ipv6 mtu
ipv6 multicast-vlan
ipv6 multicast-vlan entry-limit
ipv6 nd autoconfig other-flag
ipv6 nd check log enable
ipv6 nd dad attempts
ipv6 nd detection enable
ipv6 nd detection trust
ipv6 nd mac-check enable
ipv6 nd ns retrans-timer
ipv6 nd nud reachable-time
ipv6 nd ra halt
ipv6 nd ra hop-limit unspecified
ipv6 nd ra interval
ipv6 nd ra no-advlinkmtu
ipv6 nd ra prefix
ipv6 nd ra router-lifetime
ipv6 nd router-preference
ipv6 nd snooping enable global
ipv6 nd snooping enable link-local
ipv6 nd snooping glean source
ipv6 nd snooping max-learning-num
ipv6 neighbor
ipv6 neighbor stale-aging
ipv6 neighbors max-learning-num
ipv6 option drop enable
ipv6 pathmtu
ipv6 pathmtu age
ipv6 pim-snooping enable
ipv6 pim-snooping graceful-restart join-aging-time
ipv6 pim-snooping graceful-restart neighbor-aging-time
ipv6 policy-based-route (interface view)
ipv6 policy-based-route (System view)
ipv6 port multicast-vlan
ipv6 prefer temporary-address
ipv6 prefix
ipv6 redirects enable
ipv6 route-static
ipv6 route-static default-preference
ipv6 source binding(interface view)
ipv6 source binding(system view)
ipv6 temporary-address
ipv6 unreachables enable
ipv6 verify source
irf auto-update enable
irf domain
irf link-delay
irf mac-address persistent
irf member description
irf member priority
irf member renumber
irf-port
irf-port global load-sharing mode
irf-port-configuration active
J
job
jumboframe enable
K
key (HWTACACS scheme view)
key (RADIUS scheme view)
keychain
L
lacp period short
lacp system-priority
last-listener-query-interval (MLD-Snooping view)
last-member-query-interval (IGMP-Snooping view)
lcd
ldap scheme
ldap server
ldap-server
line
line class
link-aggregation bfd ipv4
link-aggregation global load-sharing mode
link-aggregation ignore vlan
link-aggregation lacp traffic-redirect-notification enable
link-aggregation load-sharing mode local-first
link-aggregation mode
link-aggregation port-priority
link-aggregation selected-port maximum
link-aggregation selected-port minimum
link-delay
lldp admin-status
lldp check-change-interval
lldp compliance admin-status cdp
lldp compliance cdp
lldp enable
lldp encapsulation snap
lldp fast-count
lldp global enable
lldp hold-multiplier
lldp management-address-format string
lldp max-credit
lldp mode
lldp notification med-topology-change enable
lldp notification remote-change enable
lldp timer fast-interval
lldp timer notification-interval
lldp timer reinit-delay
lldp timer tx-interval
lldp tlv-enable
local-address
local-identity
locality
local-proxy-arp enable
local-proxy-nd enable
local-user
lock
logfile save
login-dn
login-password
loopback
loopback-detection action
loopback-detection enable
loopback-detection global action
loopback-detection global enable
loopback-detection interval-time
ls
ls
lsr-path
M
mac-address (interface view)
mac-address (system view)
mac-address information enable (interface view)
mac-address information enable (system view)
mac-address information interval
mac-address information mode
mac-address information queue-length
mac-address mac-learning enable
mac-address mac-move fast-update
mac-address mac-roaming enable
mac-address max-mac-count
mac-address max-mac-count enable-forwarding
mac-address notification mac-move
mac-address notification mac-move suppression
mac-address notification mac-move suppression interval
mac-address notification mac-move suppression threshold
mac-address static source-check enable
mac-address timer
mac-authentication
mac-authentication critical vlan
mac-authentication domain
mac-authentication guest-vlan
mac-authentication max-user
mac-authentication re-authenticate server-unreachable keep-online
mac-authentication timer
mac-authentication timer auth-delay
mac-authentication user-name-format
mac-forced-forwarding gateway probe
mac-forced-forwarding network-port
mac-forced-forwarding server
mac-vlan enable
mac-vlan mac-address
mac-vlan trigger enable
mad arp enable
mad bfd enable
mad enable
mad exclude interface
mad ip address
mad nd enable
mad restore
match local address (IKE keychain view)
match local address (IKE profile view)
match remote
max-response-time (IGMP-Snooping view)
max-response-time (MLD-Snooping view)
md5sum
mdix-mode
memory-threshold
memory-threshold usage
mirroring-group
mirroring-group mirroring-port (interface view)
mirroring-group mirroring-port (system view)
mirroring-group monitor-egress
mirroring-group monitor-port (interface view)
mirroring-group monitor-port (system view)
mirroring-group reflector-port
mirroring-group remote-probe vlan
mirror-to
mkdir
mkdir
mkdir
mkdir
mld-snooping
mld-snooping done source-ip
mld-snooping dot1p-priority
mld-snooping drop-unknown
mld-snooping enable
mld-snooping fast-leave
mld-snooping general-query source-ip
mld-snooping group-limit
mld-snooping group-policy
mld-snooping host-aging-time
mld-snooping host-join
mld-snooping last-listener-query-interval
mld-snooping max-response-time
mld-snooping overflow-replace
mld-snooping querier
mld-snooping query-interval
mld-snooping report source-ip
mld-snooping router-aging-time
mld-snooping router-port-deny
mld-snooping source-deny
mld-snooping special-query source-ip
mld-snooping version
mode
monitor cpu-usage enable
monitor cpu-usage interval
monitor cpu-usage threshold
monitor kernel deadloop enable
monitor kernel deadloop exclude-thread
monitor kernel deadloop time
monitor kernel starvation enable
monitor kernel starvation exclude-thread
monitor kernel starvation time
monitor process
monitor thread
monitor-link group
more
more
move
move
mrp timer join
mrp timer leave
mrp timer leaveall
mrp timer periodic
mtu
multicast-suppression
multicast-vlan
mvrp enable
mvrp global enable
mvrp gvrp-compliance enable
mvrp registration
N
name
nas-id bind vlan
nas-ip (HWTACACS scheme view)
nas-ip (RADIUS scheme view)
nbns-list
nest top-most
netbios-type
netconf soap http enable
netconf soap https enable
netconf ssh server enable
netconf ssh server port
network
network
newer
next-hop
next-server
nqa
nqa agent enable
nqa schedule
nqa server enable
nqa server tcp-connect
nqa server udp-echo
nqa template
ntp-service acl
ntp-service authentication enable
ntp-service authentication-keyid
ntp-service broadcast-client
ntp-service broadcast-server
ntp-service dscp
ntp-service enable
ntp-service inbound enable
ntp-service ipv6 acl
ntp-service ipv6 dscp
ntp-service ipv6 inbound disable
ntp-service ipv6 multicast-client
ntp-service ipv6 multicast-server
ntp-service ipv6 source
ntp-service ipv6 unicast-peer
ntp-service ipv6 unicast-server
ntp-service max-dynamic-sessions
ntp-service multicast-client
ntp-service multicast-server
ntp-service refclock-master
ntp-service reliable authentication-keyid
ntp-service source
ntp-service unicast-peer
ntp-service unicast-server
O
oam enable
oam errored-frame threshold
oam errored-frame window
oam errored-frame-period threshold
oam errored-frame-period window
oam errored-frame-seconds threshold
oam errored-frame-seconds window
oam errored-symbol-period threshold
oam errored-symbol-period window
oam global errored-frame threshold
oam global errored-frame window
oam global errored-frame-period threshold
oam global errored-frame-period window
oam global errored-frame-seconds threshold
oam global errored-frame-seconds window
oam global errored-symbol-period threshold
oam global errored-symbol-period window
oam global timer hello
oam global timer keepalive
oam mode
oam remote-failure action
oam remote-loopback
oam remote-loopback interface
oam remote-loopback reject-request
oam timer hello
oam timer keepalive
open
operation (FTP test type view)
operation (HTTP test type view)
option
option
organization
organization-unit
overflow-replace (IGMP-Snooping view)
overflow-replace (MLD-Snooping view)
P
packet-filter
packet-filter default deny
parity
passive
password
password
password-control { aging | composition | history | length } enable
password-control aging
password-control alert-before-expire
password-control complexity
password-control composition
password-control enable
password-control expired-user-login
password-control history
password-control length
password-control login idle-time
password-control login-attempt
password-control super aging
password-control super composition
password-control super length
password-control update-interval
password-recovery enable
peer-public-key end
permit interface
permit vlan
pfs
pim-snooping enable
ping
ping ipv6
pki abort-certificate-request
pki delete-certificate
pki domain
pki entity
pki export
pki import
pki request-certificate
pki retrieve-certificate
pki retrieve-crl
pki storage
pki validate-certificate
pki-domain (SSL client policy view)
pki-domain (SSL server policy view)
policy-based-route
port
port
port
port
port (IPv6 multicast-VLAN view)
port (multicast-VLAN view)
port access vlan
port auto-power-down
port group interface
port hybrid ip-subnet-vlan
port hybrid protocol-vlan
port hybrid pvid
port hybrid vlan
port link-aggregation group
port link-type
port monitor-link group
port multicast-vlan
port private-vlan host
port private-vlan promiscuous
port private-vlan trunk promiscuous
port private-vlan trunk secondary
port pvid forbidden
port smart-link group
port smart-link group track
port trunk permit vlan
port trunk pvid
port up-mode
portal { bas-ip | bas-ipv6 }
portal apply web-server
portal delete-user
portal domain
portal enable method
portal fail-permit server
portal free-all except destination
portal free-rule
portal free-rule source
portal ipv6 free-all except destination
portal ipv6 layer3 source
portal ipv6 user-detect
portal layer3 source
portal max-user
portal nas-id-profile
portal roaming enable
portal server
portal user-detect
portal web-server
port-isolate enable
port-isolate group
port-security authorization ignore
port-security authorization-fail offline
port-security enable
port-security intrusion-mode
port-security mac-address aging-type inactivity
port-security mac-address dynamic
port-security mac-move permit
port-security max-mac-count
port-security nas-id-profile
port-security ntk-mode
port-security oui
port-security port-mode
port-security timer autolearn aging
port-security timer disableport
preemption delay
preemption mode
prefer-cipher
prefix-pool
pre-shared-key
primary accounting (HWTACACS scheme view)
primary accounting (RADIUS scheme view)
primary authentication (HWTACACS scheme view)
primary authentication (RADIUS scheme view)
primary authorization
priority (IKE keychain view)
priority (IKE profile view)
private-vlan community
private-vlan isolated
private-vlan primary
private-vlan(VLAN interface view)
private-vlan(VLAN view)
probe count
probe packet-interval
probe packet-number
probe packet-timeout
probe timeout
process core
proposal
protected-vlan
protected-vlan
protocol
protocol inbound
protocol lifetime
protocol-version
protocol-vlan
proxy-arp enable
proxy-nd enable
public-key dsa
public-key local create
public-key local destroy
public-key local export dsa
public-key local export ecdsa
public-key local export rsa
public-key peer
public-key peer import sshkey
public-key rsa
put
put
pwd
pwd
pwd
pwd
Q
qinq enable
qinq ethernet-type customer-tag
qinq ethernet-type service-tag
qinq transparent-vlan
qos apply policy (interface view, control plane view)
qos apply policy (user-profile view)
qos apply policy global
qos bandwidth queue
qos car
qos gts
qos lr
qos map-table
qos policy
qos pre-classify
qos priority
qos sp
qos trust
qos vlan-policy
qos wfq
qos wfq { byte-count | weight }
qos wfq group sp
qos wrr
qos wrr { byte-count | weight }
qos wrr group sp
R
radius nas-ip
radius scheme
radius session-control enable
raw-request
reaction checked-element { jitter-ds | jitter-sd }
reaction checked-element { owd-ds | owd-sd }
reaction checked-element icpif
reaction checked-element mos
reaction checked-element packet-loss
reaction checked-element probe-duration
reaction checked-element probe-fail (for trap)
reaction checked-element probe-fail (for trigger)
reaction checked-element rtt
reaction trap
reaction trigger probe-fail
reaction trigger probe-pass
reboot
reboot
redirect
redundancy replay-interval
reget
region-name
remark customer-vlan-id
remark dot1p
remark dscp
remark ip-precedence
remark local-precedence
remark qos-local-id
remark service-vlan-id
remote-address
remove
rename
rename
rename
report-aggregation (IGMP-Snooping view)
report-aggregation (MLD-Snooping view)
reset
reset acl counter
reset arp
reset arp detection statistics
reset arp snooping
reset bfd session statistics
reset cfd dm one-way history
reset cfd tst
reset counters interface
reset counters interface loopback
reset counters interface null
reset crypto-engine statistics
reset dhcp relay client-information
reset dhcp relay statistics
reset dhcp server conflict
reset dhcp server expired
reset dhcp server ip-in-use
reset dhcp server statistics
reset dhcp snooping binding
reset dhcp snooping packet statistics
reset dldp statistics
reset dns host
reset dot1x guest-vlan
reset dot1x statistics
reset ethernet statistics
reset exception context
reset hwtacacs statistics
reset igmp-snooping group
reset igmp-snooping router-port
reset igmp-snooping statistics
reset ike sa
reset ike statistics
reset ip policy-based-route statistics
reset ip routing-table statistics protocol
reset ip statistics
reset ipsec sa
reset ipsec statistics
reset ipv6 dhcp client statistics
reset ipv6 dhcp relay statistics
reset ipv6 dhcp server conflict
reset ipv6 dhcp server expired
reset ipv6 dhcp server ip-in-use
reset ipv6 dhcp server pd-in-use
reset ipv6 dhcp server statistics
reset ipv6 dhcp snooping binding
reset ipv6 dhcp snooping packet statistics
reset ipv6 multicast-vlan group
reset ipv6 nd detection statistics
reset ipv6 nd snooping
reset ipv6 neighbors
reset ipv6 pathmtu
reset ipv6 pim-snooping statistics
reset ipv6 policy-based-route statistics
reset ipv6 routing-table statistics protocol
reset ipv6 statistics
reset kernel deadloop
reset kernel exception
reset kernel reboot
reset kernel starvation
reset lacp statistics
reset logbuffer
reset mac-authentication critical-vlan
reset mac-authentication guest-vlan
reset mac-authentication statistics
reset mld-snooping group
reset mld-snooping router-port
reset mld-snooping statistics
reset multicast-vlan group
reset mvrp statistics
reset oam
reset packet-drop interface
reset packet-filter statistics
reset password-control blacklist
reset password-control history-record
reset pim-snooping statistics
reset portal packet statistics
reset qos car name
reset qos policy control-plane
reset qos policy global
reset qos vlan-policy
reset radius statistics
reset recycle-bin
reset rrpp statistics
reset saved-configuration
reset scheduler logfile
reset smart-link statistics
reset stp
reset tcp statistics
reset udp statistics
reset udp-helper statistics
reset version-update-record
resolve-target
resolve-type
restart
restore factory-default
restore startup-configuration
retry
retry realtime-accounting
return
revision-level
rhelp
rib
ring
ring enable
rmdir
rmdir
rmdir
rmdir
rmon alarm
rmon event
rmon history
rmon prialarm
rmon statistics
role
role default-role enable
role feature-group
root-certificate fingerprint
route-option bypass-route
router-aging-time (IGMP-Snooping view)
router-aging-time (MLD-Snooping view)
rrpp domain
rrpp enable
rrpp ring-group
rstatus
rtm cli-policy
rtm environment
rtm scheduler suspend
rtm tcl-policy
rule
rule
rule (Ethernet frame header ACL view)
rule (IPv4 advanced ACL view)
rule (IPv4 basic ACL view)
rule (IPv6 advanced ACL view)
rule (IPv6 basic ACL view)
rule comment
running-time
S
sa duration
sa duration
sa hex-key authentication
sa hex-key encryption
sa idle-time
sa spi
sa string-key
save
scheduler job
scheduler logfile size
scheduler reboot at
scheduler reboot delay
scheduler schedule
scp
scp ipv6
scp server enable
screen-length
screen-length disable
search-base-dn
search-scope
secondary accounting (HWTACACS scheme view)
secondary accounting (RADIUS scheme view)
secondary authentication (HWTACACS scheme view)
secondary authentication (RADIUS scheme view)
secondary authorization
security acl
security-logfile save
security-policy-server
send
server-detect (portal server view)
server-detect (portal web-server view)
server-timeout
server-verify enable
service-type
session cachesize
set authentication password
sflow agent
sflow collector
sflow counter collector
sflow counter interval
sflow flow collector
sflow flow max-header
sflow sampling-mode
sflow sampling-rate
sflow source
sftp
sftp client ipv6 source
sftp client source
sftp ipv6
sftp server enable
sftp server idle-timeout
sha256sum
shell
shutdown
shutdown
shutdown
shutdown
shutdown-interval
sip-server
smart-link flush enable
smart-link group
snmp-agent
snmp-agent { inform | trap } source
snmp-agent calculate-password
snmp-agent community-map
snmp-agent context
snmp-agent group
snmp-agent log
snmp-agent mib-view
snmp-agent packet max-size
snmp-agent port
snmp-agent remote
snmp-agent sys-info contact
snmp-agent sys-info location
snmp-agent sys-info version
snmp-agent target-host
snmp-agent trap enable
snmp-agent trap enable arp
snmp-agent trap enable ike
snmp-agent trap enable ipsec
snmp-agent trap enable mac-address
snmp-agent trap enable radius
snmp-agent trap if-mib link extended
snmp-agent trap life
snmp-agent trap log
snmp-agent trap queue-size
snmp-agent usm-user { v1 | v2c }
snmp-agent usm-user v3
sntp authentication enable
sntp authentication-keyid
sntp enable
sntp ipv6 unicast-server
sntp reliable authentication-keyid
sntp unicast-server
source
source interface
source ip
source ipv6
source port
source-deny (IGMP-Snooping view)
source-deny (MLD-Snooping view)
speed
speed
ssh client ipv6 source
ssh client source
ssh server acl
ssh server authentication-retries
ssh server authentication-timeout
ssh server compatible-ssh1x enable
ssh server dscp
ssh server enable
ssh server ipv6 acl
ssh server ipv6 dscp
ssh server rekey-interval
ssh user
ssh2
ssh2 ipv6
ssl client-policy
ssl client-policy
ssl server-policy
startup saved-configuration
state
state primary
state secondary
state(ISP domain view)
state(Local user view)
static-bind
static-bind
statistics hold-time
statistics interval
statistics max-group
status
step
stopbits
storm-constrain
storm-constrain control
storm-constrain enable log
storm-constrain enable trap
storm-constrain interval
stp bpdu-protection
stp bridge-diameter
stp compliance
stp config-digest-snooping
stp cost
stp edged-port
stp enable
stp global config-digest-snooping
stp global enable
stp global mcheck
stp loop-protection
stp max-hops
stp mcheck
stp mode
stp no-agreement-check
stp pathcost-standard
stp point-to-point
stp port priority
stp port-log
stp priority
stp role-restriction
stp root primary
stp root secondary
stp root-protection
stp tc-protection
stp tc-protection threshold
stp tc-restriction
stp tc-snooping
stp timer forward-delay
stp timer hello
stp timer max-age
stp timer-factor
stp transmit-limit
stp vlan enable
subvlan
subvlan (IPv6 multicast-VLAN view)
subvlan (multicast-VLAN view)
super
super authentication-mode
super default role
super password
supervlan
sysname
system
T
tar create
tar extract
tar list
target-only
tclquit
tclsh
tcp mss
tcp path-mtu-discovery
tcp syn-cookie enable
tcp timer fin-timeout
tcp timer syn-timeout
tcp window
telnet
telnet client source
telnet ipv6
telnet server acl
telnet server dscp
telnet server enable
telnet server ipv6 acl
telnet server ipv6 dscp
temperature-limit
temporary address range
terminal debugging
terminal logging level
terminal monitor
terminal type
tftp
tftp client ipv6 source
tftp client source
tftp ipv6
tftp-server acl
tftp-server domain-name
tftp-server ip-address
tftp-server ipv6 acl
time at
time once
time repeating
timer
timer quiet (HWTACACS scheme view)
timer quiet (RADIUS scheme view)
timer realtime-accounting (HWTACACS scheme view)
timer realtime-accounting (RADIUS scheme view)
timer response-timeout (HWTACACS scheme view)
timer response-timeout (RADIUS scheme view)
time-range
tos
tracert
tracert ipv6
track bfd
track cfd
track interface
track interface protocol
track nqa
traffic behavior
traffic classifier
transform-set
ttl
type
U
udp-helper broadcast-map
udp-helper enable
udp-helper port
udp-helper server
undelete
unicast-suppression
url
url
url-parameter
usage
user
user-group
user-interface
user-interface class
username
user-name-format (HWTACACS scheme view)
user-name-format (RADIUS scheme view)
user-parameters
user-profile
user-role
user-role
user-role
user-sync
V
verbose
version
version
version (IGMP-Snooping view)
version (MLD-Snooping view)
virtual-cable-test
vlan
vlan mapping
vlan policy deny
vlan precedence
vlan-group
vlan-list
vlan-mapping modulo
voice-config
voice-vlan aging
voice-vlan enable
voice-vlan mode auto
voice-vlan qos
voice-vlan qos trust
voice-vlan security enable
voice-vlan track lldp
W
web captcha
web https-authorization mode
web idle-timeout
X
xml
Y
