Create a VDI image source VM based on an OVF file
Open Virtualization Format (OVF) defines the open-source VM file format specifications. An OVF template enables VMs to be compatible with different virtualization management platforms. In the current software version, the system supports OVS templates exported from virtualization platforms such as H3C CAS CVM, VMware vSphere, Oracle VM, and ZTE iECS.
  1. From the navigation pane, select Images > Desktop Images.
  1. Click the Image Source VMs tab. Click Deploy VMs from OVF Template.
  1. Select the host where the image source VM resides, and upload the OVF file. After the file is successfully uploaded, set the VM alias, CPUs, and memory, and click Next to configure the VM disks.
  1. Select the target storage file and bus type for the VM, and click Next to configure the NIC.
  1. After completing the configuration, click OK.
Basic Info
Disks
NIC
