From the navigation pane, select Data Center > Virtualization > Cluster name.
Click the Storage tab.
Perform one of the following tasks:
To start or suspend shared storage for the cluster, click Start or Suspend for the shared storage entry.
To start or suspend shared storage for multiple hosts, select one or multiple hosts, click Bulk Operation, and then select Start Storage Pool or Suspend Storage Pool.
Click OK.
To delete shared storage for the cluster, click Delete for the shared storage entry.
To detach shared storage from multiple hosts, select one or multiple hosts, click Bulk Operation, and then select Delete Storage Pool.
Click OK.
