Add shared storage
Before you add shared storage based on a shared file system, make sure the target iSCSI SAN or FC SAN storage is readable, writable, and reachable to hosts. If you fail to do so, configuration might fail or the shared file system storage pool might become unavailable.
  1. From the navigation pane, select Data Center > Virtualization > Cluster name.
  1. Click the Storage tab.
  1. Click Add.
  1. Configure the parameters, and then click OK.
