Use this feature to manage local users and groups, including editing, deleting, and exporting local users and groups, enabling or disabling third-party login, and setting the user expiration time.
From the navigation pane, select Users > Local Users.
On the Users tab of the Overview page or the Users tab on the page of a user group, click Edit in the Actions column for a local user.
In the dialog box that opens, edit local user information.
Click OK.
On the Users tab of the Overview page or the Users tab on the page of a user group, use one of the following methods to delete local users:
Delete a local user—Click Delete in the Actions column for the target local user. In the dialog box that opens, click OK.
Bulk delete local users—Select multiple local users and click More. Then, select Delete from the pop-up menu and click OK in the dialog box that opens.
Delete all local users—Click More, and then select Delete All Local Users from the pop-up menu. In the dialog box that opens, click OK.
Select users or user groups, and then click Edit Access Policy.
Select an access policy, and then click OK.
Perform this task to synchronize user accounts on a third-party platform to the Space Console. Before configuring this feature, complete third-platform settings from the System > Advanced Settings > Server Settings > Third-party account docking page.
To synchronize user accounts:
On the Users tab of the Overview page or the Users tab on the page of a user group, click user.syncThirdAuth.
In the dialog box that opens, select the target local group, and then click OK.
On the Users tab of the Overview page or the Users tab on the page of a user group, use one of the following methods to reset user passwords:
Reset the password of a local user—Click Reset Password in the Actions column for the target local user. In the dialog box that opens, enter a new password and click OK.
Bulk reset local user passwords—Select multiple local users and click More. Then, select Reset Password from the pop-up menu. In the dialog box that opens, enter a new password and click OK.
On the Users tab of the Overview page or the Users tab on the page of a user group, select one or multiple local users and click Export.
The local users will be exported to an Excel file.
If you do not select local users, the system exports all local users. |
The Denylist page displays the users added to the denylist.
To add local users to the denylist:
On the Users tab of the Overview page or the Users tab on the page of a user group, select one or multiple local users and click More. Then, select Add to Denylist from the pop-up menu.
Select one or multiple users, click More, and then select Move User Group.
Select a user group, and then click OK.
On the Users tab of the Overview page or the Users tab on the page of a user group, select one or multiple local users and click More. Then, select Enable Private Disk from the pop-up menu.
In the dialog box that opens, set the private disk size. By default, the size is 10 GB.
Click OK.
On the Users tab of the Overview page or the Users tab on the page of a user group, select one or multiple local users and click More. Then, select Enable Third-Party Login or Disable Third-Party Login from the pop-up menu.
This feature is available only when QuantumCTek authentication is configured.
On the Users tab of the Overview page or the Users tab on the page of a user group, select one or multiple local users and click More. Then, select Enable QuantumCTek Auth or Disable QuantumCTek Auth from the pop-up menu.
On the Users tab of the Overview page or the Users tab on the page of a user group, select one or multiple local users and click More. Then, select Set User Expiration Time from the pop-up menu.
In the dialog box that opens, set the user expiration time. If this field is empty, the users will never expire.
Click OK.
Perform this task to select whether to enable scheduled user clearing. If this feature is enabled, a user account will be cleared when it expires.
To configure scheduled user clearing:
On the Users tab of the Overview page or the Users tab on the page of a user group, click More. Then, select Configure Scheduled User Clearing from the pop-up menu.
In the dialog box that opens, enable or disable expired user clearing.
Click OK.
If a user has not logged in to the cloud desktop within the specified validity period, the user will be disabled. A user in disabled state cannot log in to the client or the self-service system.
To set the user validity period:
On the Users tab of the Overview page or the Users tab on the page of a user group, click More. Then, select Set User Validity Period from the pop-up menu.
In the dialog box that opens, set the user validity period. Value 0 indicates no user validity limit.
Click OK.
In the current software version, ARM hosts do not support changing the user type.
You can change the user type to student for a user only if the group to which the user belongs is a class.
On the Users tab of the Overview page or the Users tab on the page of a user group, select one or multiple local users and click More. Then, select Edit User Type from the pop-up menu.
In the dialog box that opens, select a user type.
Click OK.
Use one of the following methods to edit a local user group:
Click the name of a local user group to enter the page of that local user group. Then, click Edit in the User Group Info area. In the dialog box that opens, edit user group information and click OK.
Click the User Groups tab on the Overview page, and then click Edit in the Actions column for a local user group. In the dialog box that opens, edit user group information and click OK.
Use one of the following methods to delete local user groups:
Delete a local user group—Use one of the following methods to delete a local user group:
Click the name of a local user group to enter the page of that local user group. Then, click Delete in the User Group Info area. In the dialog box that opens, click OK.
On the User Groups tab of the Overview page, click Delete in the Actions column for a local user group. In the dialog box that opens, click OK.
Bulk delete local user groups—Click the User Groups tab on the Overview page. Select multiple local user groups and click Delete above the user group list. In the dialog box that opens, click OK.
On the Overview page, click the User Groups tab.
Select the user groups to be exported and click Export.
The user groups are exported to an Excel file.
In the current software version, ARM hosts do not support changing the grade level.
Click the User Groups tab.
Click Change Grade Level.
Select All or Custom in the Target Grade Levels field and specify the change type. If you select Custom, you must also specify a group (a class).
Click OK.
Target Grade Levels: Options are All and Custom. To change the grade level of all classes, select All. To change the grade level of one class, select Custom and specify the group name of the class.
Type: Options are Upgrade and Downgrade.
To change the class to its higher-level grade, select Upgrade. If the class is the highest-level grade, it cannot be upgraded.
