On the top navigation bar, click Resources.
From the left navigation pane, select Compute > Host Pool Name > Host Name > VM Name or Compute > Host Pool Name > Cluster Name > Host Name > VM Name.
Click Edit.
Click Add Hardware.
Select Network as the hardware type, select SR-IOV Passthrough NIC as the device model, select an SR-IOV resource pool, and enter a VLAN ID.
