Edit an image
  1. On the top navigation bar, click Cloud Services.
  1. From the left navigation pane, select Compute & Storage > Images.
  1. Click the  icon for an image.
  1. In the dialog box that opens, edit image parameters as described in Table-1.
  1. Click OK.
Table-1 Configuring image parameters
Parameter
Hypervisor
Select a hypervisor type.
OS Type
Select the operating system that is contained in the image file.
Operating System Version
Select an operating system version that matches the image file.
Min CPUs (Cores)
Specify the minimum number of CPUs to be assigned to a VM when the image is used to create the VM.
Min Memory (MB)
Specify the minimum memory size to be assigned to a VM when the image is used to create the VM.
Min Disk Size (GB)
Specify the minimum disk size to be assigned to a VM when the image is used to create the VM.
