Manage domain users and groups
Use this feature to manage domain users and groups, including editing and deleting domain users and groups, adding domain users to the denylist, enabling or disabling third-party login, and setting the user expiration time.
Edit a domain user
  1. From the navigation pane, select Users > Domain Users.
  1. On the Users tab of the Overview page, the page of an OU, or the page of a user group, click Edit in the Actions column for a domain user.
  1. In the dialog box that opens, edit domain user information.
  1. Click OK.
Delete domain users
  1. On the Users tab of the Overview page, the page of an OU, or the page of a user group, use one of the following methods to delete domain users:
Edit the access policy for domain users
  1. Select users or user groups, and then click Edit Access Policy.
  1. Select an access policy, and then click OK.
Add domain users to the denylist
The Denylist page displays the users added to the denylist.
To add domain users to the denylist:
  1. On the Users tab of the Overview page, the page of an OU, or the page of a user group, select multiple domain users and click More. Then, select Add to Denylist from the pop-up menu.
  1. In the dialog box that opens, click OK.
Move domain users between domain user groups
  1. Select one or multiple users, click More, and then select Move User Group.
  1. Select a domain user group, and then click OK.
Enable private disk
  1. On the Users tab of the Overview page or the Users tab on the page of a user group, select one or multiple domain users and click More. Then, select Enable Private Disk from the pop-up menu.
  1. In the dialog box that opens, set the private disk size. By default, the size is 10 GB.
  1. Click OK.
Enable or disable third-party login
  1. On the Users tab of the Overview page or the Users tab on the page of a user group, select one or multiple domain users and click More. Then, select Enable Third-Party Login or Disable Third-Party Login from the pop-up menu.
Enable or disable QuantumCTek authentication
This feature is available only when QuantumCTek authentication is configured.
  1. On the Users tab of the Overview page or the Users tab on the page of a user group, select one or multiple domain users and click More. Then, select Enable QuantumCTek Auth or Disable QuantumCTek Auth from the pop-up menu.
Set the user expiration time
  1. On the Users tab of the Overview page, the page of an OU, or the page of a user group, select one or multiple domain users and click More. Then, select Set User Expiration Time from the pop-up menu.
  1. In the dialog box that opens, set the user expiration time. If this field is empty, the users will never expire.
  1. Click OK.
Configure scheduled user clearing
  1. On the Users tab of the Overview page, the page of an OU, or the page of a user group, click More. Then, select Configure Scheduled User Clearing from the pop-up menu.
  1. In the dialog box that opens, select whether to enable expired user clearing.
  1. Click OK.
Edit the user type (education scenario)
You can change the user type to student for a user only if the group to which the user belongs is a class.
In the current software version, ARM hosts do not support editing the user type.
  1. On the Users tab of the Overview page, the page of an OU, or the page of a user group, select one or multiple domain users and click More. Then, select Edit User Type from the pop-up menu.
  1. In the dialog box that opens, select a user type.
  1. Click OK.
Edit a domain user group
  1. On the Overview page or on the page of an OU, click the User Groups tab.
  1. Use one of the following method to open the Edit Domain Group dialog box of a domain user group:
  1. In the dialog box that opens, edit domain user group parameters.
  1. Click OK.
Delete domain user groups
  1. Use one of the following methods to delete domain user groups:
Change the grade level (education scenario)
In the current software version, ARM hosts do not support changing the grade level.
  1. Click Change Grade Level.
  1. Select All or Custom in the Target Grade Levels field and specify the change type. If you select Custom, you must also specify a group (a class).
  1. Click OK.
