Expand a storage volume
  1. From the navigation pane, select ONEStor > Block Storage.
  1. Select Volume Management > Volumes.
  1. Select a node pool, a disk pool, and a storage pool.
  1. Click Expand in the Actions column for a storage volume.
  1. Enter the size of capacity to add.
  1. Click OK.
