This task allows you to download, edit, or delete a system image.
From the navigation pane, select Data Center > System Images.
Click Download in the Actions column to download a system image.
Click OK.
Click Edit in the Actions column to edit a system image.
Enter a new image name, and click OK.
Click Delete in the Actions column to delete a system image.
