Manage storage adapters
Introduction
About storage adapters
A host uses storage adapters to access different types of storage devices. Space Console supports SCSI, iSCSI, FC HBA, and FCoE HBA storage adapters.
A host has a default local-SCSI storage adapter and a default open-iSCSI storage adapter. The local-SCSI storage adapter is used to access local disks. The open-iSCSI storage adapter is used to access iSCSI storage.
If the host is configured with hardware FC HBAs or FCoE HBAs (for example, CNA) for accessing FC storage, the storage adapter list also displays detailed information about the FC HBAs or FCoE HBAs.
The system also supports software FCoE adapters. The FCoE protocol stack of the host processes protocols for software FCoE adapters, and the NIC forwards FCoE. Software FCoE adapters must work with NICs that support data center bridging and I/O offloading.
About multipath storage policies
If multiple paths exist between a host and a SAN storage, traffic can be switched to an available physical link when any element in the SAN network fails, for example, an adapter, switch, or cable. Besides link switchover, the paths can load balance the traffic to reduce or even eliminate potential bottlenecks.
By default, the system applies the multipath policies defined by vendors to their respective storage devices. The system provides four multipath policy types, including most recently used, fixed, round robin, and optimal. You can select a multipath policy for a storage device as needed after enabling multipathing on the storage device.
You can configure multipathing for different storage pools on a host as follows:
About storage adapter scanning
Administrators can scan storage adapters on Space Console to discover available LUNs after carving LUNs and configuring LUN mappings on storage servers.
Before you configure software FCoE adapters, complete FCoE configuration on switches.
Set the IQN of a storage adapter
  1. From the left navigation pane, select Data Center >Virtualization > Cluster name > Host name.
  1. Click the Storage Adapters tab.
  1. Click Set IQN for an open-iSCSI storage adapter.
  1. Enter an IQN, and then click OK.
Scan storage devices
Space Console supports the following scanning modes:
·          Normal Scanning: Scan storage devices. This type does not reset HBA ports.
·          Forced Scanning: Scan storage devices and reset storage interconnects. To be discovered after storage assignment, some HBAs require a forced scan. The forced scan operation is disruptive and might cause I/O operation timeout.
  1. Click Scan for a storage adapter or click Scan All.
  1. Select a scan mode and click OK.
