Manage storage volumes
About storage volume management
For a local file directory, shared file system, network file system (not supported by ARM hosts), or network file system, a storage volume is a file created in a storage pool. The system supports the following storage volume formats:
For a storage pool of the LVM logical storage volume type, a storage volume is a logical volume in a volume group. VMs mount logical volumes as block devices.
For a storage pool of the iSCSI network storage or FC network storage, a storage volume is a LUN on a storage server. VMs mount LUNs as block devices.
For an RBD storage pool, a storage volume is an RBD on distributed storage. RBDs use the raw disk format and support snapshots and online clone.
Configuration workflow
  1. Add a storage volume—Add storage volumes to a storage pool.
  1. Upload files to a storage pool—Add files to a storage pool.
  1. Manage storage volumes—Delete and download storage volumes.
Make sure the host is configured with a storage pool.
  1. From the navigation pane, select Data Center > Virtualization > Cluster name > Host name.
  1. Click the Storage tab.
  1. Click the target storage pool. The Storage Volumes list will display storage volumes in the storage pool.
  1. Click Add Storage Volume.
  1. Configure storage volume parameters as needed, and then click OK.
  1. Click Upload Files.
  1. Drag files to the Upload area, or click Upload and select files.
  1. Click OK.
Delete a storage volume
  1. Perform either of the following tasks:
Download a storage volume
  1. Click Download for the target storage volume.
  1. Click OK.
