Configure VM/host groups
Application scenarios
You can use VM or host groups to limit the scope of VM-VM affinity rules or VM-host rules.
Configuration workflow
  1. Add a VM/host group.
  1. Apply a VM/host group—Specify a VM group and a host group when you configure a VM-host affinity rule. For more information, see "Configure affinity rules."
  1. Manage VM/host groups.
Add a VM/host group
  1. From the navigation pane, select Data Center > Virtualization > Cluster name.
  1. Click More, and then select VM/Host Groups.
  1. Click Add.
  1. Configure the parameters, and then click OK.
Edit a VM/host group
  1. Click Edit for a VM/host group.
  1. Edit the parameters, and then click OK.
Delete a VM/host group
  1. Click Delete for a VM/host group.
  1. Click OK.
