Perform this task to create a VOI desktop pool for deployment of desktops accessible to one user, multiple users, or anonymous users.
Make sure you have completed the following tasks in Space Console:
Add hosts and cluster resources.
Add users.
Create desktop images.
Add authorization policies.
From the navigation pane, select Desktop Pools & Groups > Desktop Pools.
Click Create Desktop Pool or Create.
Select the VOI desktop type, configure basic desktop pool information, and then click Next: Login Info.
Configure settings for desktop login, and then click Next: Configuration.
Configure the desktop pool, and then click Next: Confirm Configuration.
Verify that the desktop pool configuration is correct, and then click Finish.
Authorization Type: Select an authorization type. The following are available options:
Dedicated User: To have each desktop accessible to only one user account, select this option. With this option, you must bind each desktop client to one user.
Multiple Users: To allow multiple users to share a desktop, select this option. With this option, you bind the entire pool to users or user groups. Then, the selected users and user groups can access any idle clients in the pool.
Anonymous Users: To allow anyone to access a VOI client as a guest without having to provide user account information, select this option. With this option, you do not need to bind users or user groups to the pool or clients.
Client User Type: Select a user type.
Local Users: To create desktops for users managed in the local database of Space Console and LDAP users, select this option. Desktop pools for local users can be authorized only to local users and LDAP users.
Domain Users: To create desktops for domain users that are managed by a domain server, select this option. Desktop pools for domain users can be authorized only to domain users.
Authentication Server: Specify the authentication server name. This parameter is required for domain users, and you must select a Microsoft AD authentication server. For LDAP users, use of an authentication server is optional, and you can select a generic LDAP authentication server.
SSO Password Type:
Authorized User: Users log in to their desktops by using their assigned usernames and passwords.
Fixed Login Name:
Login Account: Configure the account used to log in to a desktop from a client. The password used for login is the password of the account assigned to a user.
Fixed Login Name and Password:
Fixed Password: Configure the password used to log in to a desktop from a client., A user can access a desktop without entering any password if you leave this field empty.
Restoration Mode: Select a mode for restoration of a desktop to its initial state. ARM hosts do not support these parameters.
Not Restore: To prevent the system from restoring the desktop system image on a client to its initial state when the user session ends or the desktop restarts, select this option.
Full Restore: To restore the full desktop image on a client to its initial state when the user session ends or the desktop restarts, select this option.
System Restore: To restore the desktop system disk of a client to its initial state when the user session ends or the desktop restarts, select this option. A system disk refers to a disk file where the guest operating system is saved. If you have partitioned the system disk, all data on the partitions such as drive D and drive E will also be restored.
Offline Use Time: Set the amount of time that a user can continue to use a VOI client after the client goes offline because of network disconnection or disconnection from Space Console.
Configure: Select a resource flavor for the desktops depending on the required performance. Each flavor represents a set of CPU, memory, and system disk resources for each desktop. You can self-define resource flavors as described in "Flavors."
Select Image: Select a VOI desktop image for bulk deployment of desktops in the pool.
Authorization Policy: Specify the default authorization policy applied to desktop users that do not have a user-specific authorization policy. If you do not specify a default authorization policy, the predefined VOI-Default authorization policy applies to those desktop users.
Authentication Server: For local users, use of an authentication server is optional. If you use one, you can only select a general-purpose LDAP server. For domain users, you must use an authentication server and the server type must be Microsoft AD.
OU: Specify the distinguished name (DN) of the organizational unit (OU) to which the domain users belong on the specified authentication server. This option is required if you configure the pool for domain users. When you specify this option, use the ou=value,dc=value,dc=value format. For example, to specify the test OU in the example.com domain, enter the ou=test,dc=example,dc=com string.
