Deploy a VDI desktop pool
After you create a VDI desktop pool, you can deploy desktops in the desktop pool and authorize users and endpoints to use the desktops deployed in the pool.
Bulk deploy desktops
Perform this task to deploy desktops depending on the business requirements.
  1. From the navigation pane, select Desktop Pools & Groups > Desktop Pools.
  1. Select a desktop pool, and then click Bulk Deploy.
  1. Configure basic deployment settings, and then click Next: Configure NIC.
  1. Configure the network settings, and then click Next: Confirm Configuration.
  1. Verify that the deployment configuration is correct, and then click Finish.
Basic deployment settings
Network settings
Preauthorize users/OUs to use the desktop pool
To automatically assign idle desktops to users when they log in to their VDI clients, add their usernames, endpoints, or OUs to the preauthorization list.
If a VDI desktop pool is for endpoint users, authorization is performed on a per-endpoint basis. Users can access the desktops in the VDI desktop pool from preauthorized endpoints, without providing user account information.
·          To avoid errors, do not add teacher users or user groups, or student users or user groups to the preauthorization list in an office and education hybrid scenario.
·          To avoid errors, do not add endpoints or endpoint groups with Learningspace clients installed to the preauthorization list in an office and education hybrid scenario.
·          In a desktop pool for endpoint users, you can add only endpoints or endpoint groups whose authentication mode is endpoint authentication to the preauthorization list.
  1. Select a desktop pool, and then click Preauthorize.
  1. Add users, user groups, and OUs to the preauthorization list:
To add users to the preauthorization list:
  1. Click Select Users.
  1. Select one or multiple users, select their respective authorization policies, and then click OK.
To add user groups to the preauthorization list:
  1. Click Select User Groups.
  1. Select one or multiple user groups, select their respective authorization policies, and then click OK.
To add OUs for domain users to the preauthorization list:
  1. Click Select OU.
  1. Select one or multiple OUs, select their respective authorization policies, and then click OK.
  1. To change authorization policies for preauthorized objects (users, user groups, or OUs of domain users):
  1. Select the target authorized objects, and then click Change Authorization Policy.
  1. In the dialog box that opens, select the desired authorization policy, and then click OK.
To use the default authorization policy for the pool, do not select any policy.
  1. To remove preauthorized objects from the preauthorization list:
  1. Select one or multiple preauthorized objects, and then click Delete Authorizations.
  1. In the dialog box that opens, click OK.
The users or endpoints will be unable to access any cloud desktops in the desktop pool.
Authorize a user or endpoint to use a desktop
·          You can perform only direct authorization for a shared desktop pool.
·          To avoid errors, do not authorize teacher users or student users to use the desktops in an office and education hybrid scenario.
·          To avoid errors, do not authorize endpoints with Learningspace clients installed to use the desktops in an office and education hybrid scenario.
·          In a desktop pool for endpoint users, you can configure only endpoints whose authentication mode is endpoint authentication to use the desktops.
Perform this task to manually authorize a user or endpoint to use a desktop.
  1. From the left navigation pane, select Desktop Pools & Groups > Desktop Pools.
  1. Select the target VDI desktop pool.
  1. Perform one of the following tasks:
  • You cannot enable the authorization policy for a shared desktop pool.
  • A shared desktop pool is not applicable to local users and endpoint users.
