Publish a VOI desktop image
A desktop image can be published through cloning an image source VM or converting an image source VM. A published desktop image can be distributed to the VOI endpoints in a desktop pool.
Clone an image source VM as a desktop image
After an image source VM is cloned as a desktop image, the image source VM is still retained and can still be edited.
  1. From the navigation pane, select Images > Desktop Images.
  1. Click the Image Source VMs tab. Click Clone as Desktop Image in the Actions column for an image source VM.
  1. In the dialog box that opens, enter the name of the desktop image to publish, select the storage path for the desktop image, and click OK to clone the image source VM as a desktop image.
Convert the image source VM to a desktop image
After an image source VM is converted to a desktop image, the image source VM is deleted.
  1. Click the Image Source VMs tab. Click Convert to Desktop Image in the Actions column for an image source VM.
  1. In the dialog box that opens, enter the name of the desktop image to publish, select the storage pool for the desktop image, and click OK to convert the image source VM to a desktop image.
