Create an IDV image source VM
The system supports creating IDV image source VMs with the default C102V, C103V, C105V configurations to adapt to IDV endpoints with the corresponding models. The system also allows you to select the IDV endpoint configuration customized in Flavor configuration to adapt to non-default IDV endpoints.
ARM hosts do not support IDV desktop images in current software version.
  1. From the navigation pane, select Images > Desktop Images.
  1. Click the Image Source VMs tab. Click Create.
  1. On the page that opens, select image type IDV, configure the image source VM parameters, and click OK.
