Manage VDI desktop images
Perform this task to edit, delete, deploy, download, and distribute VDI desktop images.
Deploy VMs
  1. From the navigation pane, select Images > Desktop Images.
  1. Click Deploy in the Actions column for the desktop image to be deployed.
  1. Configure VM deployment parameters, and click OK.
Edit a VDI desktop image
  1. Click More in the Actions column for the desktop image to be edited. From the dropdown menu, select Edit.
  1. In the dialog box that opens, edit the CPU and memory settings for the desktop image, and click OK.
Delete a VDI desktop image
  1. Click More in the Actions column for the desktop image to be deleted. From the dropdown menu, select Delete.
  1. Click OK in the confirmation dialog box that opens.
Download a VDI desktop image
  1. Click More in the Actions column for the desktop image to be downloaded. From the dropdown menu, select Download.
  1. In the dialog box that opens, click Download to start downloading the desktop image.
The desktop image is downloaded to the path set for the browser.
Perform an integrity check and source track for a VDI desktop image
Perform this task to view the creation and usage of a desktop image.
  1. Click More in the Actions column for the desktop image to be checked and tracked. From the dropdown menu, select Integrity Check and Source Track.
The integrity check and source track dialog box opens to start integrity check.
  1. After the check is completed, view the parameters in the dialog box, and click OK to close the dialog box.
Distribute a VDI desktop image
  1. Click More in the Actions column for the desktop image to be distributed. From the dropdown menu, select Distribute.
  1. In the dialog box that opens, configure the distribution information and click OK.
Migrate a VDI desktop image
For migration to succeed, do no migrate an image that is being edited, downloaded, distributed, or deployed.
  1. Click More in the Actions column for the desktop image to be migrated. From the dropdown menu, select Migrate.
  1. In the dialog box that opens, select the migration destination address, click OK.
Destination Address: Destination IP address of the desktop image migration.
